1,开发环境
1,适用芯片:STM32F4全部芯片
2,固件库:STM32F4xx_DSP_StdPeriph_Lib_V1.8.0
3,IDE:MDK517
2,驱动源码
Delay.h文件
* Copyright (C) 2016, XinLi, all right reserved.
* File name: Delay.h
* Date: 2016.03.22
* Description: Delay Driver
#ifndef __DELAY_H
#define __DELAY_H
* Header include
#include "stm32f4xx.h"
* Macro definition
* Type definition
* Structure definition
#ifdef __cplusplus
extern "C" {
#endif /* __cplusplus */
* Variable declaration
* Function declaration
void Delay_us(uint64_t nus);
void Delay_ms(uint64_t nms);
void Delay_s(uint64_t ns);
#ifdef __cplusplus
#endif /* __DELAY_H */
Delay.c文件
* File name: Delay.c
* Date: 2016.03.22
* Header include
#include "Delay.h"
* Global variables
static void Delay_Init(void);
* Function definition
* Function: Delay_Init
* Description: Delay Configuration.
* Input:
* Output:
* Return:
static uint8_t first = 0;
if(first == 0)
first = 1;
SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);
SysTick->CTRL &= ~SysTick_CTRL_ENABLE_Msk; /* Disability SysTick counter */
* Function: Delay_us
* Description: Microsecond delay.
* Input: nus
* Output:
* Return:
uint32_t temp = 0;
uint64_t nms = 0;
Delay_Init();
if(nus == 0)
return;
nms = nus / 1000;
nus = nus % 1000;
if(nms > 0)
Delay_ms(nms);
if(nus > 0)
SysTick->LOAD = SystemCoreClock / 8000000 * nus; /* Time load (SysTick-> LOAD is 24bit) */
SysTick->VAL = 0x000000; /* Empty counter */
SysTick->CTRL |= SysTick_CTRL_ENABLE_Msk; /* Start the countdown */
do
temp = SysTick->CTRL;
while(temp&0x01 && !(temp&(1<<16))); /* Wait time is reached */
SysTick->CTRL &= ~SysTick_CTRL_ENABLE_Msk; /* Close Counter */
* Function: Delay_ms
* Description: Millisecond delay.
* Input: nms
* Output:
* Return:
uint32_t temp = 0;
Delay_Init();
if(nms == 0)
return;
while(nms > 500)
SysTick->LOAD = SystemCoreClock / 8000 * 500; /* Time load (SysTick-> LOAD is 24bit) */
do
nms -= 500;
SysTick->LOAD = SystemCoreClock / 8000 * nms; /* Time load (SysTick-> LOAD is 24bit) */
do
* Function: Delay_s
* Description: Second delay.
* Input: ns
* Output:
* Return:
while(ns > 0)
Delay_ms(1000);
ns--;
