//以下为TIM配置程序
void TIM1_PWM_INIT(void) //TIM1配置PWM输出参数
u32 temp_fre,temp_duty;
TempC = 60; //设置频率初始值
TempD = 4; //设置初始占空比1 / 2
temp_fre = (1000000 / TempC) - 1;
temp_duty = ((temp_fre + 1) / TempD);
TIM_TimeBaseStructure.TIM_Prescaler = 72;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseStructure.TIM_Period = temp_fre;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse = temp_duty;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OC1Init(TIM1, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
/* TIM1 counter enable */
TIM_ARRPreloadConfig(TIM1, ENABLE);
TIM_Cmd(TIM1, ENABLE);
/* TIM1 Main Output Enable */
TIM_CtrlPWMOutputs(TIM1, ENABLE);
void TIM2_PWM_INIT(void)
TIM_TimeBaseStructure.TIM_Period = 65535;
TIM_TimeBaseStructure.TIM_Prescaler = 71;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* Output Compare Toggle Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;
TIM_OCInitStructure.TIM_Pulse = T1_H;
TIM_OC1Init(TIM2, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable);
/* Output Compare Toggle Mode configuration: Channel2 */
TIM_OCInitStructure.TIM_Pulse = T2_H;
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Disable);
/* Output Compare Toggle Mode configuration: Channel3 */
TIM_OCInitStructure.TIM_Pulse = T3_H;
TIM_OC3Init(TIM2, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Disable);
/* Output Compare Toggle Mode configuration: Channel4 */
TIM_OCInitStructure.TIM_Pulse = T4_H;
TIM_OC4Init(TIM2, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Disable);
/* TIM enable counter */
TIM_Cmd(TIM2, ENABLE);
/* TIM IT enable */
TIM_ITConfig(TIM2, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3 | TIM_IT_CC4, ENABLE);
void TIM3_PWM_IN_INIT(void)
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_ICInitTypeDef TIM_ICInitStructure;
TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
TIM_ICInitStructure.TIM_ICFilter = 0x0;
TIM_PWMIConfig(TIM3, &TIM_ICInitStructure);
/* Select the TIM2 Input Trigger: TI2FP2 */
TIM_SelectInputTrigger(TIM3, TIM_TS_TI2FP2);
/* Select the slave Mode: Reset Mode */
TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Reset);
/* Enable the Master/Slave Mode */
TIM_SelectMasterSlaveMode(TIM3, TIM_MasterSlaveMode_Enable);
TIM_Cmd(TIM3, ENABLE);
/* Enable the CC2 Interrupt Request */
TIM_ITConfig(TIM3, TIM_IT_CC2, ENABLE);
// 以下为中断处理程序
void TIM2_IRQHandler(void)
/* TIM2_CH1 toggling with frequency = 183.1 Hz */
static u8 i1,i2,i3,i4;
if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
i1++;
TIM_ClearITPendingBit(TIM2, TIM_IT_CC1 );
capture = TIM_GetCapture1(TIM2);
if(i1 % 2 == 1)
TIM_SetCompare1(TIM2, capture + T1_L);
else
TIM_SetCompare1(TIM2, capture + T1_H);
/* TIM2_CH2 toggling with frequency = 366.2 Hz */
if (TIM_GetITStatus(TIM2, TIM_IT_CC2) != RESET)
i2++;
TIM_ClearITPendingBit(TIM2, TIM_IT_CC2);
capture = TIM_GetCapture2(TIM2);
if(i2 % 2 == 1)
TIM_SetCompare2(TIM2, capture + T2_L);
else
TIM_SetCompare2(TIM2, capture + T2_H);
/* TIM2_CH3 toggling with frequency = 732.4 Hz */
if (TIM_GetITStatus(TIM2, TIM_IT_CC3) != RESET)
i3++;
TIM_ClearITPendingBit(TIM2, TIM_IT_CC3);
capture = TIM_GetCapture3(TIM2);
if(i3 % 2 == 1)
TIM_SetCompare3(TIM2, capture + T3_L);
else
TIM_SetCompare3(TIM2, capture + T3_H);
/* TIM2_CH4 toggling with frequency = 1464.8 Hz */
if (TIM_GetITStatus(TIM2, TIM_IT_CC4) != RESET)
i4++;
TIM_ClearITPendingBit(TIM2, TIM_IT_CC4);
capture = TIM_GetCapture4(TIM2);
if(i4 % 2 == 1)
TIM_SetCompare4(TIM2, capture + T4_L);
else
TIM_SetCompare4(TIM2, capture + T4_H);
* Function Name : TIM3_IRQHandler
* Description : This function handles TIM3 global interrupt request.
* Input : None
* Output : None
* Return : None
void TIM3_IRQHandler(void)
TIM_ClearITPendingBit(TIM3, TIM_IT_CC2);
IC2Value = TIM_GetCapture2(TIM3);
if (IC2Value != 0)
DutyCycle = (TIM_GetCapture1(TIM3) * 100) / IC2Value; //占空比
TempB = 1000000 / IC2Value; //输入PWM频率
TempA = IC2Value / 1000; //输入PWM脉宽
else
DutyCycle = 0;
TempB = 0;
TempA = 0;
