//复位定时器1所有寄存器
TIM_TimeBaseStructure.TIM_Prescaler = 0; //预分频数为0,不分频
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //计数方式为顺序计数模式,增大型
//TIM_TimeBaseStructure.TIM_Period = 5625-1; //设置计数器溢出后的重载初值
TIM_TimeBaseStructure.TIM_Period = Period-1; //设置计数器溢出后的重载初值
TIM_TimeBaseStructure.TIM_ClockDivision = 0; //配置时钟分隔值
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; //循环计数次数值
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //用以上参数初始化定时器时间基础模块
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse = Pulse;//127;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OC1Init(TIM1, &TIM_OCInitStructure);
TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
TIM_BDTRInitStructure.TIM_DeadTime = 5;
TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;
TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;
TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
//清中断
TIM_ClearFlag(TIM1, TIM_FLAG_Update);
TIM_ClearFlag(TIM2, TIM_FLAG_Update);
//TIM1中断源设置,开启相应通道的捕捉比较中断
TIM_Cmd(TIM1, ENABLE); //使能定时器1
TIM_CtrlPWMOutputs(TIM1, ENABLE);//使能定时器1的PWM输出
void TIM2_Configuration (uint Period)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //用以上参数初始化定时器时间基础模块
TIM_DeInit(TIM2); //复位定时器1所有寄存器
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
//清中断
TIM_ITConfig( //使能或者失能指定的TIM中断
TIM2, //TIM2
TIM_IT_Update | //TIM 中断源
TIM_IT_Trigger, //TIM 触发中断源
ENABLE //使能
TIM_Cmd(TIM2, ENABLE); //使能定时器1
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM //中断向量表存放位置选择
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); //中断向量表存放于RAM中0x00
#else
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); //中断向量表存放于FLASH中0x00
#endif
//中断NVIC设置:允许中断,设置优先级//中断向量设置
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置优先级分组:先占优先级2位,从优先级2位
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; //更新事件
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //抢占优先级0
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; //响应优先级1
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //允许中断
NVIC_Init(&NVIC_InitStructure); //写入设置
关键字:TIM 配置 定时器
