源程序:
This program was produced by the
CodeWizardAVR V1.23.8c Standard
Automatic Program Generator
?Copyright 1998-2003 HP InfoTech s.r.l.
http://www.hpinfotech.ro
e-mail:office@hpinfotech.ro
Project : SKYT
Version : 0.01
Date : 2006-12-6
Author : hlchen
Company :
Comments:
数控云台
Chip type : ATmega8
Program type : Application
Clock frequency : 3.690000 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 256
typedef unsigned char uchar;
typedef unsigned int uint;
#include
#include
#include "macro.h"
#include "LCD.h"
//#include "sed1565_s.h"
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define Light 5
#define FRAMING_ERROR (1<
#define PARITY_ERROR (1<
#define DATA_OVERRUN (1<
#define DATA_REGISTER_EMPTY (1<
#define RX_COMPLETE (1<
#define sysInitLcd 0
// USART Receiver buffer
#define RX_BUFFER_SIZE 8
char rx_buffer[RX_BUFFER_SIZE];
unsigned char rx_wr_index,rx_rd_index,rx_counter;
// This flag is set on USART Receiver buffer overflow
bit rx_buffer_overflow,b_ComEnable;
uchar uc_syssta;
// USART Receiver interrupt service routine
#pragma savereg-
interrupt [USART_RXC] void uart_rx_isr(void)
char status,data;
#asm
push r26
push r27
push r30
push r31
in r26,sreg
push r26
#endasm
status=UCSRA;
data=UDR;
if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
rx_buffer[rx_wr_index]=data;
if (++rx_wr_index == RX_BUFFER_SIZE) rx_wr_index=0;
if (++rx_counter == RX_BUFFER_SIZE)
rx_counter=0;
rx_buffer_overflow=1;
if ((rx_buffer[0]=='o')&&(rx_buffer[1]=='k')) b_ComEnable=1;
#asm
pop r26
out sreg,r26
pop r31
pop r30
pop r27
pop r26
#endasm
#pragma savereg+
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
char data;
while (rx_counter==0);
data=rx_buffer[rx_rd_index];
if (++rx_rd_index == RX_BUFFER_SIZE) rx_rd_index=0;
#asm("cli")
--rx_counter;
#asm("sei")
return data;
#pragma used-
#endif
// USART Transmitter buffer
#define TX_BUFFER_SIZE 8
char tx_buffer[TX_BUFFER_SIZE];
unsigned char tx_wr_index,tx_rd_index,tx_counter;
// USART Transmitter interrupt service routine
#pragma savereg-
interrupt [USART_TXC] void uart_tx_isr(void)
#asm
push r26
push r27
push r30
push r31
in r26,sreg
push r26
#endasm
if (tx_counter)
--tx_counter;
UDR=tx_buffer[tx_rd_index];
if (++tx_rd_index == TX_BUFFER_SIZE) tx_rd_index=0;
#asm
pop r26
out sreg,r26
pop r31
pop r30
pop r27
pop r26
#endasm
#pragma savereg+
// Write a character to the USART Transmitter buffer
#define _ALTERNATE_PUTCHAR_
#pragma used+
void putchar(char c)
while (tx_counter == TX_BUFFER_SIZE);
#asm("cli")
if (tx_counter || ((UCSRA & DATA_REGISTER_EMPTY)==0))
tx_buffer[tx_wr_index]=c;
if (++tx_wr_index == TX_BUFFER_SIZE) tx_wr_index=0;
++tx_counter;
else UDR=c;
#asm("sei")
#pragma used-
#endif
// Standard Input/Output functions
#include
uchar ucInputValue;
uint uiLastADValue[3];
uchar ucInputParam0;
uchar ucChannelN,uc_ReceiveSta;
bit bInputChange,bMotorSpeed,bLight,bReceiveOpend;
void inputdeal(void);
void TransmitEnable(void);
void ReceiveEnable(void);
void Communication(void);
void LcdShow(void);
#define HighSpeed 0x33
#define SlowSpeed 0x99
#define ADC_VREF_TYPE 0x00
#define RE 0
#define DE 1
// ADC interrupt service routine
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
// Place your code here
TCNT0=0xf0;
interrupt [ADC_INT] void adc_isr(void)
uint adc_data;
// Read the AD conversion result
adc_data=ADCW;
switch (ucChannelN)
case 0:
if (uiLastADValue[0]!=adc_data)
uiLastADValue[0]=adc_data;
ucInputParam0=uiLastADValue[0]*24/1024;
//ucInputParam0 = tmp/100;
//ucInputParam1 = (tmp%100)/10;
//ucInputParam2 = (tmp%100)%10;
bInputChange=1;
ucInputValue=0x01;
ADMUX=0x01;
break;
case 1:
if (uiLastADValue[1]!=adc_data)
uiLastADValue[1]=adc_data;
ucInputParam0=uiLastADValue[1]*12/1024;
bInputChange=1;
ucInputValue=0x02;
ADMUX=0x02;
break;
case 2:
if (uiLastADValue[2]!=adc_data)
uiLastADValue[2]=adc_data;
//ucInputParam0=uiLastADValue[2]*6/1024;
if (abs(uiLastADValue[2]-1023)<100)
ucInputValue=3;
else if (abs(uiLastADValue[2]-465)<50)
ucInputValue=4;
else if (abs(uiLastADValue[2]-292)<25)
ucInputValue=5;
else if (abs(uiLastADValue[2]-204)<25)
ucInputValue=6;
else if (abs(uiLastADValue[2]-146)<12)
ucInputValue=7;
else if (abs(uiLastADValue[2]-93)<12)
ucInputValue=8;
else if (abs(uiLastADValue[2])<6)
ucInputValue=9;
else break;
// else if (abs(uiLastADValue[2]-512
bInputChange=1;
// ucInputValue=ucInputParam0+2;
ADMUX=0x00;
break;
default:
