仿真原理图如下
单片机源程序如下:
#include
* 定时器初值
#define T0HIGH 0xec
#define T0LOWW 0x8a
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
typedef bit BOOL;
* 单片机管脚定义
sbit KEY_ON_PIN = P2^0;
sbit KEY_INC_PIN = P2^1;
sbit KEY_DEC_PIN = P2^2;
sbit MOTO_LEFT = P3^6;
sbit MOTO_RIGHT = P3^7;
* 按键定义
#define KEY_NULL 0xff
#define KEY_LONG_PERIOD 25
#define KEY_CONTINUE_PERIOD 20
#define KEY_DOWN 0x80
#define KEY_CONTINUE 0x40
#define KEY_UP 0x20
#define KEY_STATE_INIT 0
#define KEY_STATE_WOBBLE 1
#define KEY_STATE_PRESS 2
#define KEY_STATE_LONG 3
#define KEY_STATE_CONTINUE 4
#define KEY_STATE_RELEASE 5
#define KEY_ON_VALUE 1
#define KEY_INC_VALUE 2
#define KEY_DEC_VALUE 3
#define KEY_ON (KEY_ON_VALUE | KEY_DOWN)
#define KEY_INC (KEY_INC_VALUE | KEY_DOWN)
#define KEY_INC_CON (KEY_INC_VALUE | KEY_CONTINUE)
#define KEY_DEC (KEY_DEC_VALUE | KEY_DOWN)
#define KEY_DEC_CON (KEY_DEC_VALUE | KEY_CONTINUE)
* 常量定义
#define true 1
#define false 0
#define MOTO_ON MOTO_LEFT = false;
MOTO_RIGHT = true
#define MOTO_OFF MOTO_LEFT = true;
MOTO_RIGHT = true
* 全局变量定义
code u8 DisCode[] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0xff};
u8 PWMpercent = 0;
u8 DisNum[4] = {0x0a, 0x0a, 0x0a, 0x00};
u8 DisPosition = 0;
u8 SecCount = 0;
u8 u10msNum = 0;
BOOL b10msEvent = false;
BOOL b100msEvent = false;
BOOL b1secEvent = false;
BOOL MotoStart = false;
BOOL MotoRun = false;
void Key_Prosess(void);
void Dynamic_Display(void);
void Speed_Display(void);
* 主函数
main()
TMOD = 0x01;
TH0 = T0HIGH;
TL0 = T0LOWW;
TR0 = 1;
ET0 = 1;
EA = 1;
P1 = 0x00;
while(1)
if(true == b10msEvent) //10毫秒定时标志
b10msEvent = false;
Key_Prosess(); //按键扫描
Dynamic_Display(); //动态显示
if(true == MotoStart) //如果电机启动
if(true == MotoRun)
if(--u10msNum == 0) //如果电机转动时间到,停止电机
MotoRun = false;
MOTO_OFF;
if(true == b1secEvent) //PWM周期为1秒,1秒钟时间到,开始下一个周期
b1secEvent = false;
MotoRun = true;
MOTO_ON;
u10msNum = PWMpercent;
* 清显示
void Num_Clear(void)
u8 i;
for(i=0; i<3; i++)
DisNum[i] = 0x0a;
DisNum[3] = 0x00;
* 读键值
u8 Key_Scan(void)
if(KEY_ON_PIN == false)
return KEY_ON_VALUE;
if(KEY_INC_PIN == false)
return KEY_INC_VALUE;
if(KEY_DEC_PIN == false)
return KEY_DEC_VALUE;
return KEY_NULL;
* 按键状态扫描
u8 GetKey(void)
static u8 KeyState = KEY_STATE_INIT;
static u8 KeyTimeCount = 0;
static u8 LastKey = KEY_NULL; //保存按键释放时候的键值
u8 KeyTemp = KEY_NULL ;
KeyTemp = Key_Scan();
switch(KeyState)
case KEY_STATE_INIT: //初始状态
if(KEY_NULL != KeyTemp) //有键按下
KeyState = KEY_STATE_WOBBLE; //进入消抖
break;
case KEY_STATE_WOBBLE: //消抖
KeyState = KEY_STATE_PRESS;
break;
