*program name:st7920.c
*function: TEST TO st7920(drive)
*Design: qinhao
*Date:2009-01-07
#include
#include
#include
#include
#define uchar unsigned char
#define uint unsigned int
sbit sclk=P3^2;
sbit sid=P3^1;
sbit cs=P3^0;
unsigned char code tab[]={"深圳勤正达液晶显示器"};
void delaym(unsigned int n)
{unsigned int i,j;
for(j=n;j>0;j--);
for(i=112;i>0;i--);
void sendbit(uchar dat1, bitcnt)
unsigned char i;
for(i=0;i
sclk = 0;
dat1=dat1<<1;
sid = CY;
sclk = 1;
sclk = 0;
unsigned char receivebyte(void)
unsigned char i,temp1,temp2;
temp1=temp2=0;
for(i=0;i<8;i++)
temp1=temp1<<1;
sclk = 0;
sclk = 1;
sclk = 0;
if(sid) temp1++;
for(i=0;i<8;i++)
temp2=temp2<<1;
sclk = 0;
sclk = 1;
sclk = 0;
if(sid) temp2++;
return ((0xf0&temp1)+(0x0f&temp2));
void checkbusy( void )
do sendbit(0xfc,8); //11111,RW(1),RS(0),0
while(0x80&receivebyte());
void senddat(uchar dat1)
cs=1;
checkbusy();
sendbit(0xfa,8);
sendbit(dat1&0xf0,8);
sendbit((dat1<<4)&0xf0,8);
cs=0;
void sendcom(uchar com)
cs=1;
checkbusy();
sendbit(0xf8,8);
sendbit(com&0xf0,8);
sendbit((com<<4)&0xf0,8);
cs=0;
void inti()
sendcom(0x30); ///////8位MPU控制界面,基本指令集
sendcom(0x03);
sendcom(0x0c); ////// 开显示,关游标,
sendcom(0x01);
sendcom(0x06);
void display(uchar dat1)
unsigned char i,j;
sendcom(0x34);
sendcom(0x36);
for(i=0;i<32;i++)
sendcom(0x80|i);
sendcom(0x80);
for(j=0;j<32;j++)
senddat(dat1);
void main()
uchar i;
delaym(100);
inti();
for(i=0;i<20;i++)
senddat(tab[i]);
display(0xff);
while(1);
并口:
*program name:并st7920.c
*function: TEST TO FM240128m-12l(drive)
*Design: qinhao
*Date:2009-3-30
#include
#include
#include
#include
sbit e=P3^2;
sbit rs=P3^0;
sbit rw=P3^1;
sbit rst=P3^6;
延时N ms
unsigned int i,j;
for(j=n;j>0;j--)
for(i=112;i>0;i--);
} /////// 精确MS,
检查状态,D7为忙状态位,D6~D0为AC地址
uchar BusyFlag()
uchar BF;
rs=0;
rw=1;
e=1;
_nop_();
_nop_();
BF=P1;
_nop_();
e=0;
_nop_();
return(BF);
发送命令
void SendCommand(uchar command)
// uchar BF;
while(BusyFlag()&0x80);
rs=0;
rw=0;
e=1;
_nop_();
P1=command;
_nop_();
_nop_();
e=0;
_nop_();
_nop_();
发送数据
void SendData(uchar dat)
//uchar BF;
rs=1;
rw=0;
e=1;
_nop_();
P1=dat;
_nop_();
_nop_();
e=0;
_nop_();
_nop_();
读AC地址
uchar ReaDAC()
uchar AC;
AC=BusyFlag()&0x07;
return(AC);
读数据
uchar ReadData()
uchar dat;
rs=1;
rw=1;
e=1;
_nop_();
dat=P1;
_nop_();
_nop_();
e=0;
_nop_();
_nop_();
return(dat);
初始化LCD
void LcdInit()
rst=0;
delaym(10);
rst=1;
SendCommand(0x30);//基本指令集
delaym(10);
SendCommand(0x03);//AC回00H
SendCommand(0x0c);//开显示,关游标
SendCommand(0x01);//清屏,AC返回00H
delaym(10);
SendCommand(0x06);//设定游标显示移位
delaym(10);
void main()
uchar i;
LcdInit();
SendCommand(0x34); 扩充指令
SendCommand(0x04); 反白00行
while(1)
i++;
SendData(i);
delaym(700);
