今天通过搜索,整理了proteus 7可以仿真通过的基于51单片机+ADC0832电压采集并通过液晶1602显示电压的C程序及电路连接图,希望对大家有所帮助。
程序是谁写的谁修改的并不主要,主要的是学会并使用单片机AD转换,这才是王道。
电路连接图如下:
C程序如下:
#include
#include
#include
/**********************************8/
/**********LCD1602接口程序**********/
#define DD P2
sbit Rs=P3^0;
sbit Rw=P3^1;
sbit E=P3^2;
sbit busy_p=ACC^7;
void delay_1ms(unsigned char i) //最小延时1ms
{ unsigned char j;
while(i--)
for(j=0;j<125; j++);
void delay_10ns(unsigned char i) //最小延时10ns
{ unsigned char j;
while(i--)
for(j=0;j<10; j++);
void write_com(unsigned char com,bit p) //写指令
{if(p)
delay_10ns(5);
E=0;
Rs=0;
Rw=0;
DD=com;
delay_10ns(50); //>40ns
E=1;
delay_1ms(2); //>150ns
E=0;
delay_10ns(4); //>25+10ns
void write_date(unsigned char DA
delay_10ns(50);
E=0;
Rs=1;
Rw=0;
DD=DA
delay_10ns(50);
E=1;
delay_10ns(50);
E=0;
delay_10ns(4);
void addr_x_y(unsigned char x,bit y) //写坐标,定位置
{ unsigned char temp=0x80;
if(y)
{temp|=0x40;}
temp|=x;
write_com(temp,0);
void desplay_char(unsigned char x,bit y,unsigned char p)
//在指定位置显示一个字符。
{ addr_x_y(x,y);
write_date(p);
void init(void)
{delay_1ms(15);
write_com(0x38,0);
delay_1ms(5);
write_com(0x38,0);
delay_1ms(5);
write_com(0x38,0);
delay_1ms(5);
write_com(0x38,1);
write_com(0x08,1);
write_com(0x01,1);
write_com(0x06,1);
write_com(0x0c,1);
void xs_int(unsigned int shuju,bit t) //显示一个数字
{unsigned char huancun[6]={0};
unsigned char biaozhi=0,i;
if (shuju < 10) biaozhi = 1;
else if(shuju < 100) biaozhi = 2;
else if(shuju < 1000) biaozhi = 3;
else if(shuju < 10000) biaozhi = 4;
else if(shuju < 65535) biaozhi = 5;
switch(biaozhi)
{case 5:huancun[5] = shuju/10000;
case 4:huancun[3] = shuju%10000/1000;
case 3:huancun[2] = shuju%1000/100;
case 2:huancun[1] = shuju%100/10;
case 1:huancun[0] = shuju%10;
break;
default:break;
for(i=6;i>1;i--)
{if(i==5)desplay_char(10,1,'.');
else desplay_char(15-i,t,0x30+huancun[i-1]); }
desplay_char(15,t,'V');
/**********ADC0832接口程序************************************/
sbit ADC_CS =P3^4;
sbit ADC_CLK=P3^5;
sbit ADC_DO =P3^6;
sbit ADC_DI =P3^7;
void Delay(unsigned char j)
unsigned char i;
for(i=0;i
unsigned char ADC0832(void) //把模拟电压值转换成8位二进制数并返回
unsigned char i,da
da
ADC_CS=0;
ADC_DO=0;//片选,DO为高阻态
for(i=0;i<10;i++)
ADC_CLK=0;
Delay(2);
ADC_DI=1;
ADC_CLK=1;
Delay(2); //第一个脉冲,起始位
ADC_CLK=0;
Delay(2);
ADC_DI=1;
ADC_CLK=1;
Delay(2); //第二个脉冲,DI=1表示双通道单极性输入
ADC_CLK=0;
Delay(2);
ADC_DI=1;
ADC_CLK=1;
Delay(2); //第三个脉冲,DI=1表示选择通道1(CH2)
ADC_DI=0;
ADC_DO=1;//DI转为高阻态,DO脱离高阻态为输出数据作准备
ADC_CLK=1;
Delay(2);
ADC_CLK=0;
Delay(2);//经实验,这里加一个脉冲AD便能正确读出数据,
//不加的话读出的数据少一位(最低位d0读不出)
for (i=0; i<8; i++)
ADC_CLK=1;
Delay(2);
ADC_CLK=0;
Delay(2);
da
ADC_CS=1;//取消片选,一个转换周期结束
return(da
void main(void)
unsigned int da
while(1)
{ da
init();
xs_int(196*da
以上经过仿真测试通过。
关键字:51单片机 ADC0832 电压测量 液晶1602『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
