本程序所用的原理图下载: 点这里 ,单片机芯片使用的stc89c52;找到相应部分即可.这是一整个单片机开发板的电路图其他的忽略.
hex文件及其工程文件下载:http://www.51hei.com/f/juzhen.rar 以下是通过测试的源代码:
*功能:使用矩阵按键使得按键按下时数码管上显示各自对应的数字(0 ~ F);
*日期:2013-05-03-17:51;
*作者:徐冉
*特别说明:本程序代码已经通过调试,仅供学习使用;
/***********AT89C52-RC 单片机51hei 实验板***********/
/*****************51hei-开发板*********************/
#include
typedef unsigned int uint;
typedef unsigned char uchar;
sbit wela = P2^7;
sbit dula = P2^6;
sbit FM = P2^3;
uchar code table[] = {
0x3F, //"0"
0x06, //"1"
0x5B, //"2"
0x4F, //"3"
0x66, //"4"
0x6D, //"5"
0x7D, //"6"
0x07, //"7"
0x7F, //"8"
0x6F, //"9"
0x77, //"A"
0x7C, //"B"
0x39, //"C"
0x5E, //"D"
0x79, //"E"
0x71, //"F"
0x76, //"H"
0x38, //"L"
0x37, //"n"
0x3E, //"u"
0x73, //"P"
0x5C, //"o"
0x40, //"-"
0x00, //熄灭
0x00 //自定义
uchar key, temp;
void display(uchar num);
void Marix_keyscan();
void delay(uint xms);
void main()
dula = 1;
P0 = 0x00;
dula = 0;
wela = 1;
P0 = 0xea;
wela = 0;
while(1)
Marix_keyscan();
display(key);
dula = 1;
P0 = table[num];
dula = 0;
uint i, j;
for(i = xms; i > 0; i--)
for(j = 125; j > 0; j--);
P3 = 0xfe;
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
delay(5);
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
FM = 0;
temp = P3;
switch(temp)
case 0xee: key = 0;
break;
case 0xde: key = 1;
break;
case 0xbe: key = 2;
break;
case 0x7e: key = 3;
break;
default:
break;
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
delay(5);
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
FM = 1;
P3 = 0xfd;
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
delay(5);
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
FM = 0;
temp = P3;
switch(temp)
case 0xed:key = 4;
break;
case 0xdd:key = 5;
break;
case 0xbd:key = 6;
break;
case 0x7d:key = 7;
break;
default:
break;
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
delay(5);
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
FM = 1;
P3 = 0xfb;
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
delay(5);
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
FM = 0;
temp = P3;
switch(temp)
case 0xeb: key = 8;
break;
case 0xdb: key = 9;
break;
case 0xbb: key = 10;
break;
case 0x7b: key = 11;
break;
default:
break;
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
delay(5);
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
FM = 1;
P3 = 0xf7;
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
delay(5);
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
FM = 0;
temp = P3;
switch(temp)
case 0xe7: key = 12;
break;
case 0xd7: key = 13;
break;
case 0xb7: key = 14;
break;
case 0x77: key = 15;
break;
default:
break;
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
delay(5);
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
FM = 1;
关键字:51单片机 矩阵键盘检测 数码管显示『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
