__create_page_tables:
pgtbl r4, r5 @ page table address
/* Clear the 16K level 1 swapper page table */
mov r0, r4
mov r3, #0
add r2, r0, #0x4000
1: str r3, [r0], #4
str r3, [r0], #4
str r3, [r0], #4
str r3, [r0], #4
teq r0, r2
bne 1b
* Create identity mapping for first MB of kernel to
* cater for the MMU enable. This identity mapping
* will be removed by paging_init()
krnladr r2, r4, r5 @ start of kernel
add r3, r8, r2 @ flags + kernel base
str r3, [r4, r2, lsr #18] @ identity mapping
* Now setup the pagetables for our kernel direct
* mapped region. We round TEXTADDR down to the
* nearest megabyte boundary.
add r0, r4, #(TEXTADDR & 0xff000000) >> 18 @ start of kernel
bic r2, r3, #0x00f00000
str r2, [r0] @ PAGE_OFFSET + 0MB
add r0, r0, #(TEXTADDR & 0x00f00000) >> 18
str r3, [r0], #4 @ KERNEL + 0MB
add r3, r3, #1 << 20
str r3, [r0], #4 @ KERNEL + 1MB
str r3, [r0], #4 @ KERNEL + 2MB
str r3, [r0], #4 @ KERNEL + 3MB
* Ensure that the first section of RAM is present.
* we assume that:
* 1. the RAM is aligned to a 32MB boundary
* 2. the kernel is executing in the same 32MB chunk
* as the start of RAM.
bic r0, r0, #0x01f00000 >> 18 @ round down
and r2, r5, #0xfe000000 @ round down
add r3, r8, r2 @ flags + rambase
str r3, [r0]
bic r8, r8, #0x0c @ turn off cacheable
@ and bufferable bits
代码创建页表目录。首先清空从0xA0004000开始的16K页表项。然后,为了可以访问从0xA0000000开始的内核的1M空间,将该地址对应的页表项赋值。接着映射从TEXTADDR开始的4M的虚拟地址空间,这需要4个页表项。最后,由于SDRAM开始的第一MB的空间存放有启动时的一些参数,所以也需要映射。在这里,该映射和前面的虚拟地址的映射在地址上是相等的。
在创建页表目录完成后,代码通过前面主程序的最后一句add pc, r10, #12跳转到实际的CPU的设置子程序__xscale_setup。
__xscale_setup:
mov r0, #F_BIT|I_BIT|SVC_MODE
msr cpsr_c, r0
mcr p15, 0, ip, c7, c7, 0 @ invalidate I, D caches & BTB
mcr p15, 0, ip, c7, c10, 4 @ Drain Write (& Fill) Buffer
mcr p15, 0, ip, c8, c7, 0 @ invalidate I, D TLBs
mcr p15, 0, r4, c2, c0, 0 @ load page table pointer
mov r0, #0x1f @ Domains 0, 1 = client
mcr p15, 0, r0, c3, c0, 0 @ load domain access register
mov r0, #1 @ Allow user space to access
mcr p15, 0, r0, c15, c1, 0 @ ... CP 0 only.
#if CACHE_WRITE_THROUGH
mov r0, #0x20
#else
Mov r0, #0x00
#endif
mcr p15, 0, r0, c1, c1, 0 @ set auxiliary control reg
mrc p15, 0, r0, c1, c0, 0 @ get control register
bic r0, r0, #0x0200 @ ......R.........
bic r0, r0, #0x0082 @ ........B.....A.
orr r0, r0, #0x0005 @ .............C.M
orr r0, r0, #0x3900 @ ..VIZ..S........
#ifdef CONFIG_XSCALE_CACHE_ERRATA
bic r0, r0, #0x0004 @ see cpu_xscale_proc_init
#endif
mov pc, lr
主要是操作协处理器,设置页表目录项基地址,对CACHE和BUFFER的控制位进行一些操作。具体大家可以看看介绍ARM编程的书。
.type __switch_data, %object
__switch_data: .long __mmap_switched
.long SYMBOL_NAME(__bss_start)
.long SYMBOL_NAME(_end)
.long SYMBOL_NAME(processor_id)
.long SYMBOL_NAME(__machine_arch_type)
.long SYMBOL_NAME(cr_alignment)
.long SYMBOL_NAME(init_task_union)+8192
.type __ret, %function
__ret: ldr lr, __switch_data
mcr p15, 0, r0, c1, c0
mov r0, r0
mov r0, r0
mov r0, r0
mov pc, lr
.align 5
__mmap_switched:
adr r3, __switch_data + 4
ldmia r3, {r4, r5, r6, r7, r8, sp} @ r2 = compat
@ sp = stack pointer
mov fp, #0 @ Clear BSS (and zero fp)
1: cmp r4, r5
strcc fp, [r4],#4
bcc 1b
str r9, [r6] @ Save processor ID
str r1, [r7] @ Save machine type
#ifdef CONFIG_ALIGNMENT_TRAP
orr r0, r0, #2 @ ...........A.
#endif
bic r2, r0, #2 @ Clear 'A' bit
stmia r8, {r0, r2} @ Save control register values
b SYMBOL_NAME(start_kernel)
最后这段代码的作用主要是在进入C函数前先做一些变量的初始化和保存工作。首先清空BSS区域,然后保存处理器ID和机器类型到各自变量地址,接着保存cr_alignment,最后跳转到init/main.c中的start_kernel函数运行。
以上介绍的是head-armv.S文件的主要内容和功能,它是linux运行的第一个文件,具有非常重要的意义。很好的阅读该文件,对于我们理解ARM处理器的工作方式有很大的帮助。同时,在许多linux系统的移植工作中,往往需要对该文件透彻的理解。
关键字:ARM Linux 启动分析
