@* @ File:head.S @ 功能:设置SDRAM,将程序到SDRAM,然后跳到SDRAM继续执行 @* .equ MEM_CTL_BASE, 0x48000000 .equ SDRAM_BASE, 0x30000000 .text .global _start _start: bl disable_watch_dog @ 关闭WATCHDOG,否则CPU会不断重启 bl memsetup @ 设置存储控制器 bl copy_steppingstone_to_sdram @ 到SDRAM中 ldr pc, =on_sdram @ 跳到SDRAM中继续执行 on_sdram: ldr sp, =0x34000000 @ 设置堆栈 bl main halt_loop: b halt_loop disable_watch_dog: @ 往WATCHDOG寄存器写0即可 mov r1, #0x53000000 mov r2, #0x0 str r2, [r1] mov pc, lr @ 返回 copy_steppingstone_to_sdram: @ 将Steppingstone的4K数据全部到SDRAM中去 @ Steppingstone起始地址为0x00000000,SDRAM中起始地址为0x30000000 mov r1, #0 ldr r2, =SDRAM_BASE mov r3, #4*1024 1: ldr r4, [r1],#4 @ 从Steppingstone读取4字节的数据,并让源地址加4 str r4, [r2],#4 @ 将此4字节的数据到SDRAM中,并让目地地址加4 cmp r1, r3 @ 判断是否完成:源地址等于Steppingstone的未地址? bne 1b @ 若没有完,继续 mov pc, lr @ 返回 memsetup: @ 设置存储控制器以便使用SDRAM等外设 mov r1, #MEM_CTL_BASE @ 存储控制器的13个寄存器的开始地址 adrl r2, mem_cfg_val @ 这13个值的起始存储地址 add r3, r1, #52 @ 13*4 = 54 1: ldr r4, [r2], #4 @ 读取设置值,并让r2加4 str r4, [r1], #4 @ 将此值写入寄存器,并让r1加4 cmp r1, r3 @ 判断是否设置完所有13个寄存器 bne 1b @ 若没有写成,继续 mov pc, lr @ 返回 .align 4 mem_cfg_val: @ 存储控制器13个寄存器的设置值 .long 0x22011110 @ BWSCON .long 0x00000700 @ BANKCON0 .long 0x00000700 @ BANKCON1 .long 0x00000700 @ BANKCON2 .long 0x00000700 @ BANKCON3 .long 0x00000700 @ BANKCON4 .long 0x00000700 @ BANKCON5 .long 0x00018005 @ BANKCON6 .long 0x00018005 @ BANKCON7 .long 0x008C07A3 @ REFRESH .long 0x000000B1 @ BANKSIZE .long 0x00000030 @ MRSRB6 .long 0x00000030 @ MRSRB7
#define GPBCON (*(volatile unsigned long *)0x56000010) #define GPBDAT (*(volatile unsigned long *)0x56000014) #define GPB5_out (1< 0; dly--); } int main(void) { unsigned long i = 0; GPBCON = GPB5_out|GPB6_out|GPB7_out|GPB8_out; // 将LED1-4对应的GPB5/6/7/8四个引脚设为输出 while(1){ wait(30000); GPBDAT = (~(i<<5)); // 根据i的值,点亮LED1-4 if(++i == 16) i = 0; } return 0; }
all : head.S leds.c arm-linux-gcc -c -g -o head.o head.S arm-linux-gcc -c -g -o leds.o leds.c arm-linux-ld -Ttext 0x00000000 head.o leds.o -o sdram_elf arm-linux-objcopy -O binary -S sdram_elf sdram.bin arm-linux-objdump -D -m arm sdram_elf > sdram.dis clean: rm -f sdram.dis sdram.bin sdram_elf *.o
