早几年用了SHT10的温湿度传感器,稳定,可靠,就是更新数据时间比较长些,
电路很简单,请看手册,
已经在产品中使用了,请放心使用和指正,
#include
#include
#include
#include "sht.h"
#include "uart.h"
#include "key.h"
#include "IO.h"
#include "Lcd.h"
enum {TEMP,HUMI};
//0: 温度1, 1:湿度1 , 2 : 温度2, 3: 湿度2
float todao[4]; //{temp,rh}; 模拟量寄存器从1到2
float humi_val1; //湿度变量
float temp_val1; //温度变量
unsigned int humi_val; //湿度变量
unsigned int temp_val; //温度变量
unsigned char checksum;
const float C1=-4; // for 12 Bit RH
const float C2=+0.0405; // for 12 Bit RH
const float C3=-0.0000028; // for 12 Bit RH
const float T1=+0.01; // for 12 Bit RH
const float T2=+0.00008; // for 12 Bit RH
const float C1=-2.0468; // for 12 Bit RH
const float C2=+0.0367; // for 12 Bit RH
const float C3=-0.0000015955; // for 12 Bit RH
extern unsigned char wendu1_biaozhi;
extern unsigned char wendu2_biaozhi;
extern unsigned char R_KeyValue1;
** 函数名称: s_write_byte()
** 函数功能: SHT10写单个字节, 写一个字节并输出ACK验证
** 入口参数: 写入单个字节
** 出口参数: ACK验证
** 说 明: writes a byte on the Sensibus and checks the acknowledge
unsigned char s_write_byte(unsigned char value)
unsigned char i,j,error1=0;
SHT10_SDA1_OUT;
for(i=0x80;i>0;i/=2) //shift bit for masking
if (i & value)
SHT10_SDA1_OUT1; //masking value with i , write to SENSI-BUS
else
SHT10_SDA1_OUT0;
SHT10_SCK1_OUT1; //clk for SENSI-BUS
for(j = 0; j<40;j++)
NOP(); //pulswith approx. 5 us
SHT10_SCK1_OUT0;
NOP();
NOP();
