#define ADDR_24CXX 0xA0
void I2C_24CXX_Write(u16 nAddr, u8* pDat, u16 nLen)
u16 i = 0;
/* Enable I2C1 acknowledgement if it is already disabled by other function */
//I2C_AcknowledgeConfig(I2C1, ENABLE);
STM32_I2c1_Regs->cr1.bit.ACK=1; // ACK:应答使能 1:在接收到一个字节后返回一个应答(匹配的地址或数据)
/* Send I2C1 START condition */
//I2C_GenerateSTART(I2C1, ENABLE);
STM32_I2c1_Regs->cr1.all|= I2C_EN|I2C_START;
/* Test on I2C1 EV5 and clear it */
// 【SB=1 起始条件已发送 读SR1,然后写数据DR 清零 】 MSL="1主模式" BUSY="1" 在总线上正在进行数据通讯 )
// while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)){;} /* EV5 */
while(!(STM32_I2c1_Regs->sr1.bit.SB & I2C_SB)) ;
/* Send slave address for write */
//I2C_Send7bitAddress(I2C1, ADDR_24CXX, I2C_Direction_Transmitter);
STM32_I2c1_Regs->dr.bit.DR=ADDR_24CXX;
/* Test on I2C1 EV6 and clear it */
// 【ADDR=1 地址发送结束;读SR1和SR2来清零 】。 TXE="1" 数据寄存器空 MSL="1" BUSY="1", TRA="1" 数据已发送
//while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)){;} /* EV6 */
while(!(STM32_I2c1_Regs->sr1.all & I2C_ADDR)) ;
STM32_I2c1_Regs->sr2.all;
/* Send the low part of memory address */
//I2C_SendData(I2C1, (u8)nAddr);
STM32_I2c1_Regs->dr.bit.DR=(u8)nAddr;
/* Test on I2C1 EV8 and clear it */
// 【TXE=1 数据寄存器空; 写数据DR清除,START,STOP】 BTF="1:" 字节发送结束 TRA="数据已发送" BUSY="在总线上正在进行数据通讯" MSL="主模式"
//while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)){} /* EV8 */
while(!(STM32_I2c1_Regs->sr1.all & I2C_TXE));
for(i=0;i
/* Send I2C1 data */
//I2C_SendData(I2C1, pDat[i]);
STM32_I2c1_Regs->dr.bit.DR=pDat[i];
//while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)){;} /* EV8 */
/* Send I2C1 STOP Condition */
//I2C_GenerateSTOP(I2C1, ENABLE);
STM32_I2c1_Regs->cr1.all|= I2C_EN|I2C_STOP;
while(STM32_I2c1_Regs->sr2.bit.MSL); // 0:从模式
}//end sub
void I2C_24CXX_Read(u16 nAddr, u8* pDat, u16 nLen)
u16 i = 0;
//while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)){;} /* EV5 */
/* Send 24CXX slave address for write */
/* Test on EV5 and clear it */
/* Send 24CXX slave address for read */
//I2C_Send7bitAddress(I2C1, ADDR_24CXX, I2C_Direction_Receiver);
STM32_I2c1_Regs->dr.bit.DR=(u8)ADDR_24CXX|((u8)0x01);
/* Test on EV6 and clear it */
//while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)){;} /* EV6 */
for(i=0;i
if((i+1)>=nLen)
/* Disable I2C1 acknowledgement */
//I2C_AcknowledgeConfig(I2C1, DISABLE);
STM32_I2c1_Regs->cr1.bit.ACK=0; // ACK:应答使能 关闭
/* Test on EV7 and clear it */
// 【RXNE=1 数据寄存器非空; 读写DR清零 】 BUSY="1" 在总线上正在进行数据通讯 MSL="1" 主模式
//while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED)){;} /* EV7 */
while(!(STM32_I2c1_Regs->sr1.all & I2C_RXNE)) ;
/* Store I2C1 received data */
//pDat[i] = I2C_ReceiveData(I2C1);
pDat[i] = STM32_I2c1_Regs->dr.bit.DR;
}//end sub
