对STM32进行软件开发时,最基本的就是对STM32芯片进行时钟和端口配置,然后是对项目所用到的片上资源进行配置并驱动,下面给出时钟和端口配置代码,该代码几乎涵盖了片上所有时钟和端口配置项目,可根据自己需要进行删除不必要的配置项:
* Function Name : RCC_Configuration 复位时钟控制配置
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
void RCC_Configuration(void)
/* system clocks configuration -----------------系统时钟配置-------------------*/
/* RCC system reset(for debug purpose) */
RCC_DeInit(); //将外设RCC寄存器重设为缺省值
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON); //开启外部高速晶振(HSE)
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp(); //等待HSE起振
if(HSEStartUpStatus == SUCCESS) //若成功起振,(下面为系统总线时钟设置)
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //使能FLASH预取指缓存
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2); //设置FLASH存储器延时时钟周期数(根据不同的系统时钟选取不同的值)
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1); //设置AHB时钟=72 MHz
/* PCLK2 = HCLK/2 */
RCC_PCLK2Config(RCC_HCLK_Div2); //设置APB1时钟=36 MHz(APB1时钟最大值)
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div1); //设置APB2时钟=72 MHz
/* Configure ADCCLK such as ADCCLK = PCLK2/2 */
RCC_ADCCLKConfig(RCC_PCLK2_Div2); //RCC_PCLK2_Div2,4,6,8
/* PLLCLK = 8MHz * 9 = 72 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); //PLL必须在其激活前完成配置(设置PLL时钟源及倍频系数)
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
/* Enable peripheral clocks -----------------外设时钟使能-------------------*/
/* Enable AHB peripheral clocks -----------------AHB外设时钟使能-------------------*/
/* Enable DMA clock */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);//使能DMA时钟
/* Enable SRAM clock */
// RCC_AHBPeriphClockCmd(RCC_AHBPeriph_SRAM, ENABLE);//使能SRAM时钟
/* Enable FLITF clock */
// RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FLITF, ENABLE);//使能FLITF时钟
/* Enable APB1 peripheral clocks -----------------APB1外设时钟使能-------------------*/
/* TIM2,3,4 clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);//使能TIM2时钟 if (APB1 prescaler="1") x1
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);//使能TIM3时钟 else x2
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);//使能TIM4时钟
/* WWDG clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG, ENABLE);//使能WWDG时钟
/* Enable SPI2 clocks */
// RCC_APB1PeriphClockCmd(RCC_APB2Periph_SPI2, ENABLE);//使能SPI2时钟
/* USART2,3 clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);//使能USART2时钟(对应万利开发板上的USART1)
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);//使能USART3时钟(万利开发板上未接该串口)
/* I2C1,2 clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);//使能I2C1时钟
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);//使能I2C2时钟
/* USB clock enable / PLL clock divided by 1.5 used as USB clock source */
// RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5); //根据不同PLLCLK选择分频比,必须确保USBCLK始终是48MHz
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_USB, ENABLE);//使能USB时钟
/* CAN clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN, ENABLE);//使能CAN时钟
/* BKP clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_BKP, ENABLE);//使能BKP时钟
/* PWR clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);//使能PWR时钟
/* APB1Periph_ALL clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_ALL, ENABLE);//使能APB1Periph_ALL时钟
/* Enable APB2 peripheral clocks -----------------APB2外设时钟使能-------------------*/
/* Enable GPIOA,B,C,D,E clocks */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能GPIOA时钟
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能GPIOB时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能GPIOC时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//使能GPIOD时钟
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);//使能GPIOE时钟
/* AFIO clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);////使能AFIO时钟
/* Enable ADC1,2clocks */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);//使能ADC1时钟
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);//使能ADC2时钟
/* TIM1 clock enable */
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//使能TIM1时钟
/* Enable SPI1 clocks */
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);//使能SPI1时钟
/* USART1 clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);//使能USART1时钟(对应万利开发板上的USART0)
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_ALL, ENABLE);//使能APB2Periph_ALL时钟
/* Enable no peripheral clocks -----------------非总线上外设时钟配置-------------------*/
/* Enable Internal High Speed oscillator */
//RCC_HSICmd(ENABLE);
/* Enable the Internal Low Speed oscillator */
//RCC_LSICmd(ENABLE); //给IWDG提供时钟信号(如果IWDG运行的话,LSI不能被失能)
/* Configure RTCCLK such as ADCCLK = PCLK2/2 */
// RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);///* Select the LSE as RTC clock source */
// RCC_RTCCLKCmd(ENABLE);///* Enable the RTC clock */
/* Enable the Clock Security System */
//RCC_ClockSecuritySystemCmd(ENABLE);
/* Output PLL clock divided by 2 on MCO pin */
//RCC_MCOConfig(RCC_MCO_PLLCLK_Div2);// 警告:当选中系统时钟作为MCO管脚的输出时,注意它的时钟频率不超过50MHz(最大I/O速率)。
关键字:STM32芯片 时钟 配置『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
