开发板:FL2440
芯片:S3C2440
功能:程序运行时点亮一个LED,然后利用PC机通过串口发送一个数,开发板读到这个数后点亮另外一个LED。最基本的串口控制。
代码:
Init.s
AREA |DATA|,CODE,READONLY
ENTRY
ldr r13, =0x1000
IMPORT WuqiMain
b WuqiMain
END
include.h
1 #define rUTRSTAT0 (*(volatile unsigned *)0x50000010) //UART 0 Tx/Rx status
2 #define rULCON0 (*(volatile unsigned *)0x50000000) //UART 0 Line control
3 #define rUCON0 (*(volatile unsigned *)0x50000004) //UART 0 Control
4 #define rUFCON0 (*(volatile unsigned *)0x50000008) //UART 0 FIFO control
5 #define rUBRDIV0 (*(volatile unsigned *)0x50000028) //UART 0 Baud rate divisor
6 #define WrUTXH0(ch) (*(volatile unsigned char *)0x50000020)=(unsigned char)(ch)
7 #define RdURXH0() (*(volatile unsigned char *)0x50000027)
8 #define rURXH0 (*(volatile unsigned *)0X50000024)
9 #define rUTXH0 (*(volatile unsigned *)0X50000020)
10 #define rURXH0 (*(volatile unsigned *)0X50000024)
11
12 #define GPBCON (*(volatile unsigned *)0x56000010)
13 #define GPBDAT (*(volatile unsigned *)0x56000014)
14 #define GPBUP (*(volatile unsigned *)0x56000018)
15
16 #define uchar unsigned char
17 #define uint unsigned int
18 #define U32 unsigned int
19 #define U16 unsigned short
20 #define S32 int
21 #define S16 short int
22 #define U8 unsigned char
23 #define S8 char
24
25 #define TRUE 1
26 #define FALSE 0
27
28 #define OK 1
29 #define FAIL 0
30
31 #define ESC_KEY 0x1b
uart.h
1 #include "include.h"
2 #include
6 void Uart_Init(int baud)
7 {
8 int i;
9 rUFCON0 = 0x0; //UART channel 0 FIFO control register, FIFO disable
10
11
12 //UART0
13 rULCON0 &=0XFFFFFF00;
14 rULCON0 |=0X03; //1位起始位,8位数据位
15 rUCON0 =0X0805; //串口时钟PCLK,查询方式
16 rUBRDIV0 =0X1A;
17 for(i=0;i<100;i++);
18 }
19
20
21
22 //=====================================================================
23 void Uart_SendByte(int data)
24 {
25
26 if(data=='n')
27 {
28 while(!(rUTRSTAT0 & 0x2));
29 // Delay(1); //because the slow response of hyper_terminal
30 WrUTXH0('r');
31 }
32 while(!(rUTRSTAT0 & 0x2)); //Wait until THR is empty.
33 // Delay(1);
34 WrUTXH0(data);
35
36
37 }
38
39 //====================================================================
40 void Uart_SendString(S8 *pt)
41 {
42 while(*pt)
43 Uart_SendByte(*pt++);
44 }
45
46 //=====================================================================
47 //If you don't use vsprintf(), the code size is reduced very much.
48 void Uart_Printf(S8 *fmt,...)
49 {
50 va_list ap;
51 S8 str[255];
52
53 va_start(ap,fmt);
54 vsprintf(str,fmt,ap);
55 Uart_SendString(str);
56 va_end(ap);
57 }
58
59 //=====================================================================
60
61 /*
62 char Uart_GetKey(void)
63 {
64
65 if(rUTRSTAT0 & 0x1) //Receive data ready
66 return rURXH0 ;
67 else
68 return 0;
69
70 }
71 */
main.c
#include"include.h"
#include "uart.h"
void Delay(int count)
unsigned int i;
while (--count != 0)
for (i=0; i<255; i++); // ";" 表示空语句,CPU空转。
void WuqiMain(void)
char buf;
GPBUP = 0x00;
GPBCON &= ~(1<<13);
GPBCON |= (1<<12);
GPBCON &= ~(1<<21);
GPBCON |= (1<<20);
while(1)
GPBDAT &= ~(1<<6);
GPBDAT &= 0xffe;
if(rUTRSTAT0 & 0X01) //接收是否完毕 =1结束
buf=rURXH0; //读取数据
while(!(rUTRSTAT0 & 0X04));//是否允许发送 =1允许
rUTXH0=buf;
if(buf=='1')
GPBDAT &= ~(1<<10);
测试一下,vc6,file——new——projects——win32consoleApplication——a simple application
1 #include "stdafx.h"
2 #include
3 #include
6 int main(int argc, char* argv[])
7 {
8 char lpBuf[]="1";
9 FILE * pFile=fopen("COM1","w");
10 if(pFile==NULL)
11 {
12 return 1;
13 }
14 fwrite(lpBuf,sizeof(char),strlen(lpBuf),pFile);
15 fclose(pFile);
16 return 0;
运行后开发板两个LED亮,也可用串口调试助手发送“1”来测试。
关键字:串口控制 FL2440 S3C2440 LED『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
