源程序如下:
;* 标题: 遥控霓虹灯模拟显示 *
;* 硬件: top-2005 *
;* 文件: REMCONLED.asm *
;* 日期: 2003-1-18 *
;* 版本: 1.0 *
;* 作者: 张绍斌 转载请注明出处www.mcu51av.com
;* 邮箱: shaobinz@163.com *
;* 描述: *
;* 遥控控制发光二极管组花样显示 *
;* P0口为发光二极管的数据口,P3.2口接遥控接收头 *
IRCOM EQU 20H ;20H-23H IR使用
IRIN EQU P3.2
D1 EQU 30H ;流水灯移位数缓存
D2 EQU 31H
NO_M EQU 44H
ORG 0000H
AJMP MAIN
ORG 0003H ;外部中断INT0入口地址
AJMP IR_IN
MAIN:
MOV SP,#60H
MOV PSW,#00H
MOV A,#00H
MOV 20H,#00H
MOV 21H,#00H
MOV 22H,#00H
MOV 23H,#00H
mov 30h,#00h
mov 31h,#00h
MOV IE,#81H ;允许总中断中断,使能 INT0 外部中断
MOV TCON,#01H ;触发方式为脉冲负边沿触发
SETB IRIN
MOV NO_M,#00H
loop1: mov p0,#00h
loop:
MOV A,NO_M
JZ loop1;开机无遥控按键按下点亮所有二极管
RL A;实现1~8倍乘(及1变2,2变4....)
MOV DPTR,#TAB_KEY
NOP
JMP @A+DPTR;散转
TAB_KEY: AJMP LOOP
AJMP TAPE1
AJMP TAPE2
AJMP TAPE3
AJMP TAPE4
AJMP TAPE5
AJMP TAPE6
AJMP TAPE7
AJMP TAPE8
;------------------以下为花样灯显示样式--------------------
TAPE1: MOV D1,#08H;单灯点亮右移
MOV A,#0FEH
QQ0: MOV P0,A
ACALL YS
RL A
DJNZ D1,QQ0
ajmp loop
TAPE2: MOV D1,#08H;单灯点亮左移
MOV A,#7FH
QQ1: MOV P0,A
ACALL YS
RR A
DJNZ D1,QQ1
ajmp loop
TAPE3: MOV D1,#08H;暗点右移
MOV A,#01H
QQ2: MOV P0,A
ACALL YS
RL A
DJNZ D1,QQ2
ajmp loop
TAPE4: MOV D1,#08H;暗点右移
MOV A,#80H
QQ3: MOV P0,A
ACALL YS
RR A
DJNZ D1,QQ3
ajmp loop
TAPE5: MOV D1,#08H;亮点右左往返流动
MOV D2,#08H
MOV A,#0FEH
QQ4: MOV P0,A
ACALL YS
RL A
DJNZ D1,QQ4
AJMP NBA
NBA: RR A
MOV P0,A
ACALL YS
DJNZ D2,NBA
ajmp loop
TAPE6: MOV R5,#00H;全亮后向右檫除,向左点亮
QQ5: INC R5
MOV A,R5
MOV DPTR, #NU_TAB1
MOVC A,@A+DPTR
MOV P0,A
ACALL YS
ACALL YS
CJNE R5,#11H,QQ5
ajmp loop
NU_TAB1: DB 00H
DB 00H,01H,03H,07H,0FH,1FH,3FH,7FH,0FFH
DB 7FH,3FH,1FH,0FH,07H,03H,01H,00h
TAPE7: MOV R5,#00H;模拟队列向左经过显示窗口
QQ7: INC R5
MOV A,R5
MOV DPTR, #NU_TAB2
MOVC A,@A+DPTR
MOV P0,A
ACALL YS
CJNE R5,#0FH,QQ7
ajmp loop
NU_TAB2: DB 00H
DB 7FH,0BFH,5FH,0AFH,57H,0ABH,55H,0AAH,0D5H
DB 0EAH,0F5H,0FAH,0FDH,0FEH,0FFH
TAPE8: MOV R5,#00H;全亮后从两端往中间擦,再从两端往中间点亮
QQ9: INC R5
MOV A,R5
MOV DPTR, #NU_TAB3
MOVC A,@A+DPTR
MOV P0,A
ACALL YS
CJNE R5,#10H,QQ9
ajmp loop
NU_TAB3: DB 00H
DB 00H,81H,0C3H,0E7H,0FFH,0E7H,0C3H,81H,00H
DB 81H,0C3H,0E7H,0FFH,0E7H,0C3H,81H
;----------------------------灯点亮延时---------------------
YS: MOV R7,#250
CBA: MOV R6,#250
DJNZ R6,$
DJNZ R7,CBA
RET
; IR 译码子程序
;转载请注明出处www.mcu51av.com IR_IN:
CLR EA ;暂时关闭CPU的所有中断请求
PUSH ACC
PUSH PSW
SETB PSW.3 ;选择工作寄存器组1
CLR PSW.4
MOV R2,#04H
MOV R0,#IRCOM
I1: JNB IRIN,I2 ;等待 IR 信号出现
DJNZ R2,I1
JMP IR_OUT ;IR信号没出现,退出。
I2: MOV R4,#20
I20: CALL DEL
DJNZ R4,I20
JB IRIN,I1 ;确认IR信号出现
I21: JB IRIN,I3 ;循环等IR变为高电平;变高就过了9MS低电平引导区
CALL DEL
JMP I21
I3: MOV R3,#0 ;8位数清为0
LL: JNB IRIN,I4 ;等IR变为低电平,变低就过了4.5MS结束码
CALL DEL
JMP LL
I4: JB IRIN,I5 ;等 IR 变为高电平,过了0或1的0.56MS低电平区
CALL DEL
JMP I4
I5: MOV R2,#0 ;0.14ms 计数
L1: CALL DEL ;看高电平保持时间,即几个0.14MS
;"0"不超过(1.125-0.56)/0.14=4个
;"1"至少有(2.25-0.56)/0.14=12个
JB IRIN, N1 ;等 IR 变为高电平
;IR=0,检查R2中的计数值
MOV A,#8
CLR C
SUBB A,R2 ;判断高低位,R2小于8,C=0,R2大于8,C=1
;取5,6,7,8,9,10,11都可,中间数最保险
;若C=0说明R2小于8,收到的是"0"位
;若C=1说明R2大于8,收到的是"1"位
MOV A,@R0 ;R0=20H已被清0,及A=0
RRC A ;RRC后A内被一位一位C替代了,低位是第一个C的值
MOV @R0,A ;处理完一位,暂时存到20H
INC R3
CJNE R3,#8,LL ;需处理完8位,1,2,3,4,5,6,7,8位放入20H,第8位是最高位
MOV R3,#0
INC R0 ;换缓存21H,22H,23H,一个缓存存8位0,1组合
CJNE R0,#24H,LL ;收集到4字节了哦(用户反码=21H,键码=22H,键反码=23H)
JMP IR_COMP ;跳出准备处理纠错
N1: INC R2
CJNE R2,#30,L1 ;0.14ms计数过长则时间到自动离开
IR_OUT: POP PSW
POP ACC
SETB EA
RETI
;键值比较与键值数据处理
;22H存入键码,23H存入键码的反码
IR_COMP:
;MOV A,20H
;XRL A,#00H;不同遥控器用户码不同的,加上比较遥控就专用了
;JNZ,IR_OUT
;MOV A,21H
;XRL A,#0DFH;同上,双保险
;JNZ IR_OUT
MOV A,22H
CPL A
XRL A,23H ;将22H取反后和23H比较
JNZ IR_OUT ;如果不等表示接收数据发生错误,放弃
MOV R1,#08H;只用遥控的8个按键,看按下的按键是第几个
MOV DPTR,#TAB_REMOT;指针指向遥控键值表
LOOKUP:
MOV A,R1
MOVC A,@A+DPTR
XRL A,22H
JZ REMBAK
DJNZ R1,LOOKUP
REMBAK:
MOV NO_M,R1
nop
sjmp ir_out
;-------------------------遥控键值表---------------------
TAB_REMOT:;其他6221/6222遥控器要先测码建立此表
DB 00H
DB 10H,03H,01H,06H
DB 09H,1DH,1FH,0DH;只用遥控上排8个按键
; DELAY R5*0.14MS
DEL:
MOV R5,#1 ;IR解码使用
DEL0: MOV R6,#2
DEL1: MOV R7,#32
DEL2: DJNZ R7,DEL2
DJNZ R6,DEL1
DJNZ R5,DEL0
RET
DELAY1: ;数码管延时4MS
MOV R6,#20
DL2: MOV R7,#100
DJNZ R7,$
DJNZ R6,DL2
RET
END ;结束
