单片机 > 单片机程序设计 > 详情
基于51的LCD1602四数据线驱动
发布时间:2025-11-04 发布时间:
/这个程序已经调试过了
//下面调用实例
//LCD1602读写头文件
//四线驱动方式
#include
#include "LCD1602.h"
管脚定义在液晶头文件中
void main(void){
LCD_init();
p=LCD_PutStr("Hello Lcd1602!\n",-1); //显示一段文字
p=LCD_PutNum(1234,2,p); //显示12.34这个数
while(1);
液晶LCD1602C 使用4条数据线(D4~D7)
LCD引脚定义
1---GND
2---VCC
3---VO
4---RS
5---RW
6---EN
7到14--D0-D7
15--背景灯+
16--背景灯-
#include
#include
#define LCD_DATA P2
sbit LCD1602_RS=P2^2;
sbit LCD1602_EN=P2^3;
int p=0;
函数说明
void LCD_init(void);
void LCD_en_write(void);
void LCD_write_command(unsigned char command) ;
void LCD_write_data(unsigned char Recdata);
void LCD_set_xy (unsigned char x, unsigned char y);
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s);
void LCD_write_char(unsigned char X,unsigned char Y,unsigned char Recdata);
void delay_nus(unsigned int n);
void delay_nms(unsigned int n);
void delay_1us(void)                 //1us延时函数
   _nop_();
void delay_nus(unsigned int n)       //N us延时函数
   unsigned int i=0;
   for (i=0;i   delay_1us();
void delay_1ms(void)                 //1ms延时函数
   unsigned int i;
   for (i=0;i<1140;i++);
void delay_nms(unsigned int n)       //N ms延时函数
   unsigned int i=0;
   for (i=0;i   delay_1ms();
void LCD_init(void)         //液晶初始化
LCD_write_command(0x28);
delay_nus(40);
delay_nus(40);
delay_nus(40);
LCD_en_write();
delay_nus(40);
LCD_write_command(0x28); //4位显示
LCD_write_command(0x0c); //显示开
LCD_write_command(0x01); //清屏
delay_nms(2);
void LCD_en_write(void) //液晶使能
LCD1602_EN=1;
delay_nus(1);
LCD1602_EN=0;
void LCD_write_command(unsigned char command) //写指令
delay_nus(16);
LCD1602_RS=0;        //RS=0
LCD_DATA&=0X0f;         //清高四位
LCD_DATA|=command&0xf0; //写高四位
LCD_en_write();
command=command<<4;          //低四位移到高四位
LCD_DATA&=0x0f;         //清高四位
LCD_DATA|=command&0xf0; //写低四位
LCD_en_write();
void LCD_write_data(unsigned char Recdata) //写数据
delay_nus(16);
LCD1602_RS=1;       //RS=1
LCD_DATA|=Recdata&0xf0; //写高四位
LCD_en_write();
Recdata=Recdata<<4;               //低四位移到高四位
LCD_DATA|=Recdata&0xf0;   //写低四位
LCD_en_write();
void LCD_set_xy( unsigned char x, unsigned char y ) //写地址函数
    unsigned char address;
    if (y == 0) address = 0x80 + x;
    else address = 0xc0 + x;
    LCD_write_command(address);
void LCD_write_char(unsigned char X,unsigned char Y,unsigned char Recdata) //列x=0~15,行y=0,1
LCD_set_xy(X, Y); //写地址
LCD_write_data(Recdata);
int LCD_PutStr(unsigned char *DData,int pos){
unsigned char i;
if(pos==-1){
   delay_nms(2);
   pos=0;
while((*DData)!='\0'){
switch(*DData){
     case '\n': //如果是\n,则换行
     if(pos<17){
       for(i=pos;i<16;i++)
         LCD_write_char(i%16, i/16, ' ');
         pos=16;
         else{
         for(i=pos;i<32;i++) LCD_write_char(i%16, i/16, ' ');
         pos=32;
     break;
     case '\b': //如果是\b,则退格
     if(pos>0) pos--;
     LCD_write_char(pos%16, pos/16, ' ');
     break;
     default:
     if((*DData)<0x20){
     *DData=' ';
     LCD_write_char(pos%16, pos/16,*DData);
     pos++;
     break;
      DData++;
       return(pos);
//----------------------------以下函数用于输出数字---------------------
int LCD_PutNum(unsigned long num,int XS,int pos){    //从右边数,保留几位小数
unsigned long tmp=0;
unsigned char numbits=0;
if(pos==-1){
delay_nms(2);
pos=0;
if(num==0){
   LCD_write_char(pos%16, pos/16, '0');
   pos++;
   else{
   if(num<0){
   LCD_write_char(pos%16, pos/16, '-');
   num*=(-1);
   pos++;
   while(num){
   tmp=tmp*10+(num%10);
   num=num/10;
   numbits++;
   while(tmp){
   LCD_write_char(pos%16, pos/16, (tmp%10)+48);
   tmp=tmp/10;
   pos++;
   numbits--;
   if(numbits==XS) pos=LCD_PutStr(".",pos); //显示小数点
   while(numbits--){
   pos++;
   return(pos);
关键字:51  LCD1602  四数据线驱动
