驱动源码:
#include "linux/module.h"
#include "linux/kernel.h"
#include "linux/fs.h"
#include "linux/init.h"
#include "linux/delay.h"
#include "linux/irq.h"
#include "asm/uaccess.h"
#include "asm/irq.h"
#include "asm/io.h"
#include "asm/arch/regs-gpio.h"
#include "asm/hardware.h"
int major = 0;
static struct class *keydrv_class;
static struct class_device *keydrv_class_dev;
volatile unsigned long *gpfcon;
volatile unsigned long *gpfdat;
volatile unsigned long *gpgcon;
volatile unsigned long *gpgdat;
static irqreturn_t buttons_irq(int irq, void *dev_id)
printk("irq = %d\n",irq);
return IRQ_RETVAL(IRQ_HANDLED);
static int key_drv_open(struct inode *inode, struct file *file)
request_irq(IRQ_EINT0,buttons_irq,IRQT_BOTHEDGE,"S2",1);
request_irq(IRQ_EINT2,buttons_irq,IRQT_BOTHEDGE,"S3",1);
request_irq(IRQ_EINT11,buttons_irq,IRQT_BOTHEDGE,"S4",1);
request_irq(IRQ_EINT19,buttons_irq,IRQT_BOTHEDGE,"S5",1);
return 0;
ssize_t key_drv_read(struct file *file, char __user *buf, size_t size, loff_t *ppos)
unsigned char key_vals[4];
int regval;
if(size != sizeof(key_vals))
return -EINVAL;
regval = *gpfdat;
key_vals[0] = (regval & (1<<0)) ? 1 : 0;
key_vals[1] = (regval & (1<<2)) ? 1 : 0;
regval = *gpgdat;
key_vals[2] = (regval & (1<<3)) ? 1 : 0;
key_vals[3] = (regval & (1<<11)) ? 1 : 0;
copy_to_user(buf, key_vals, sizeof(key_vals));
return sizeof(key_vals);
int key_drv_close(struct inode *inode, struct file *file)
free_irq(IRQ_EINT0, 1);
free_irq(IRQ_EINT2, 1);
free_irq(IRQ_EINT11, 1);
free_irq(IRQ_EINT19, 1);
return 0;
static struct file_operations key_drv_fops = {
.owner = THIS_MODULE,
.open = key_drv_open,
.read = key_drv_read,
.release = key_drv_close,
static int key_drv_init(void)
major = register_chrdev(0, "key_drv", &key_drv_fops);
keydrv_class = class_create(THIS_MODULE, "key_drv");
keydrv_class_dev = class_device_create(keydrv_class, NULL, MKDEV(major, 0), NULL, "buttons");
gpfcon = (volatile unsigned long *)ioremap(0x56000050, 16);
gpfdat = gpfcon + 1;
gpgcon = (volatile unsigned long *)ioremap(0x56000060, 16);
gpgdat = gpgcon + 1;
return 0;
static void key_drv_exit(void)
unregister_chrdev(major, "key_drv");
class_device_unregister(keydrv_class_dev);
class_destroy(keydrv_class);
iounmap(gpfcon);
iounmap(gpgcon);
return 0;
module_init(key_drv_init);
module_exit(key_drv_exit);
MODULE_LICENSE("GPL");
测试命令:
lsmod :检测当前已经安装的驱动程序
insmod ./keydrv.ko :安装keydrv.ko驱动程序
cat /proc/devices :查看当前设备
cat /proc/interrupts :查看当前中断程序
exec 5此时再执行:cat /proc/interrupts 命令就可以看到S2、S3、S4、S5四个中断程序
ps :查看所有进程(770 0 3096 S -sh)
top :查看各进程所占CPU比例
ls -l /proc/770/fd :可以查看到定位到5上面(lr-x-- 1 0 0 64 Jan 1 00:22 5 -> /dev/buttons)
exec 5 :关闭设备(等同于应用程序调用close函数)
