主文件代码:
/* This file is part of the uVision/ARM development tools */
/* Copyright KEIL ELEKTRONIK GmbH 2002-2004 */
/* HELLO.C: Hello World Example */
#include
#include
/* main program */
int main (void) { /* execution starts here */
/* initialize the serial interface */
PINSEL0 = 0x00050000; /* Enable RxD1 and TxD1 */
U1LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */
U1DLL = 97; /* 9600 Baud Rate @ 15MHz VPB Clock */
U1LCR = 0x03; /* DLAB = 0 */
printf ("Hello World\n"); /* the 'printf' function call */
while (1) { /* An embedded program does not stop and */
; /* ... */ /* never returns. We've used an endless */
} /* loop. You may wish to put in your own */
} /* code were we've printed the dots (...). */
串口程序代码:
/* SERIAL.C: Low Level Serial Routines */
#include
#define CR 0x0D
int putchar (int ch) { /* Write character to Serial Port */
if (ch == '\n') {
while (!(U1LSR & 0x20));
U1THR = CR; /* output CR */
return (U1THR = ch);
int getchar (void) { /* Read character from Serial Port */
while (!(U1LSR & 0x01));
return (U1RBR);
