要求:扫描矩阵键盘,并将对应按键的值显示在LED上
方法一(传统检测):
#include
#define uint unsigned int
#define uchar unsigned char
sbit dula=P2^6;
sbit wela=P2^7;
//sbit key1=P3^4;
uchar code table[]={ //共阳极LED数码管显示数字0~F
0xc0,0xf9,0xa4,0xb0,
0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,
0xc6,0xa1,0x86,0x8e
uchar num,temp,num1;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
uchar keyscan();
void display(uchar aa);
void main()
while(1)
display(keyscan());
/*先送数,后选通,延时以后,将所有端口都不选通,这样,拖影就消失了*/
dula=1;
P0=table[aa-1];
dula=0;
wela=1;
P0=0x01;
wela=0;
delay(5);
wela=1;
P0=0x00;
wela=0;
uchar keyscan()
P3=0xfe;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xee:num=1;
break;
case 0xde:num=2;
break;
case 0xbe:num=3;
break;
case 0x7e:num=4;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xfd;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xed:num=5;
break;
case 0xdd:num=6;
break;
case 0xbd:num=7;
break;
case 0x7d:num=8;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xfb;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xeb:num=9;
break;
case 0xdb:num=10;
break;
case 0xbb:num=11;
break;
case 0x7b:num=12;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xf7;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xe7:num=13;
break;
case 0xd7:num=14;
break;
case 0xb7:num=15;
break;
case 0x77:num=16;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
return num;
方法二(技巧检测):
#include
#include
sbit dula=P2^6;
sbit wela=P2^7;
//uchar code table[10] = {0x03, 0x9f, 0x25, 0x0d, 0x99, 0x49, 0x41, 0x1f, 0x01, 0x09};
0xc6,0xa1,0x86,0x8e
uchar Key_Value;
void Delay_1ms(uint x)
uchar i, j;
for(i = 0; i
void Getkey()
uchar i, j, temp,num,Key_Temp1, Key_Temp2, Buffer[4] = {0xfe, 0xfd, 0xfb, 0xf7};
for(j = 0; j
P3 = Buffer[j];
_nop_();
_nop_();
temp = 0x10;
for(i = 0; i
if(!(P3 & temp))
num=i + j * 4; //返回取得的按键值
temp <<= 1; //换左边一位
P3 = 0xff;
Key_Temp1 = num; //读入按键
if(Key_Temp1
Delay_1ms(5); //延时消抖
Key_Temp2 =num; //再读一次
if (Key_Temp1 == Key_Temp2)//两次相等
Key_Value = Key_Temp1; //就确认下来
void Display(uchar k)
dula=1;
P0=table[k];
dula=0;
wela=1;
P0=0x01;
wela=0;
Delay_1ms(5);
wela=1;
P0=0x00;
wela=0;
void Main(void)
while(1)
Getkey();
Display(Key_Value); //显示键值
