LCD12864.h
#define LCD12864_RS PORTA.0
#define LCD12864_RW PORTA.1
#define LCD12864_EN PORTA.2
#define LCD12864_PortOut DDRA|=0x07 //P3口的低三位设置为输出
#define LCD12864_Data DDRB
#define LCD12864_Read PINB
#define LCD12864_Write PORTB
void lcd12864_init(void);
void lcd12864_cleardd(void);
void lcd12864_cursoron(void);
void lcd12864_cursoroff(void);
void lcd12864_gotoxy(unsigned char x,unsigned char y);
void lcd12864_putchar(unsigned char temp);
void lcd12864_puts(unsigned char *str);
void lcd12864_cleargd(void);
void lcd12864_picture(flash unsigned char *ptr);
lcd12864.c
#include "lcd12864.h"
#include
#include
static void Write_Cmd(unsigned char cmd)
unsignedchar temp,i;
LCD12864_RS=0;
LCD12864_RW=1;
LCD12864_Data=0x00;
do
LCD12864_EN=1;
for(i=0;i<24;i++);
temp=LCD12864_Read;
LCD12864_EN=0;
while(temp& 0x80);
LCD12864_Data=0xff;
LCD12864_RW=0;
LCD12864_Write = cmd;
LCD12864_EN=1;
for(i=0;i<24;i++);//延时
LCD12864_EN=0;
static void Write_Data(unsigned chardat)
LCD12864_RS=0;
LCD12864_RW=1;
LCD12864_Data=0x00;
do
LCD12864_EN=1;
temp=LCD12864_Read;
LCD12864_EN=0;
while(temp& 0x80);
LCD12864_Data=0xff;
LCD12864_RS=1;
LCD12864_RW=0;
LCD12864_Write = dat;
LCD12864_EN=1;
LCD12864_EN=0;
LCD12864_PortOut; //液晶控制端口设置为输出
Write_Cmd(0x30); //基本指令集
delay_ms(1);
Write_Cmd(0x02); // 地址归位
delay_ms(1);
Write_Cmd(0x0c); //整体显示打开,游标关闭
delay_ms(1);
Write_Cmd(0x01); //清除显示
delay_ms(1);
Write_Cmd(0x06); //游标右移
delay_ms(1);
Write_Cmd(0x80); //设定显示的起始地址
delay_ms(1);
Write_Cmd(0x01);
delay_ms(5);
lcd12864_gotoxy(0,0);
Write_Cmd(0x0f); //整体显示开,游标开,游标位置开
Write_Cmd(0x0c); //整体显示开,游标关,游标位置关
switch(y)
case0:Write_Cmd(0x080+x);break;
case1:Write_Cmd(0x090+x);break;
case2:Write_Cmd(0x088+x);break;
case3:Write_Cmd(0x098+x);break;
default:break;
Write_Data(temp);
for(;*str !='';lcd12864_putchar(*(str++)));
unsignedchar i,j,k;
Write_Cmd(0x34); //打开扩展指令集
i =0x80;
for(j = 0;j< 32;j++)
Write_Cmd(i++);
Write_Cmd(0x80);
for(k = 0;k < 16;k++)
Write_Data(0x00);
i =0x80;
for(j = 0;j < 32;j++)
Write_Cmd(i++);
Write_Cmd(0x88);
Write_Data(0x00);
Write_Cmd(0x30); //回到基本指令集
unsigned char i,j,k;
i =0x80;
Write_Cmd(i++);
Write_Cmd(0x80);
Write_Data(*ptr++);
i =0x80;
Write_Cmd(i++);
Write_Cmd(0x88);
Write_Data(*ptr++);
Write_Cmd(0x36); //打开绘图显示
