单片机 > 单片机程序设计 > 详情
LCD1602程序设计4线并口通信源程序
发布时间:2024-10-21 发布时间:
LCD 1602采用4线并口通信,连接方式是DB4-DB7接P1.4-P1.7;RS:P2.7;RW:P2.6
EN:P2.5;注意初始化的设置。
在万利MedWin 3.0开发环境上调试通过!
#include
#define  LCDIO        P1
sbit LCD1602_RS=P2^7;
sbit LCD1602_RW=P2^6;
sbit LCD1602_EN=P2^5;
void LCD_delay(void);
void LCD_en_command(unsigned char command);
void LCD_en_dat(unsigned char temp);
void LCD_set_xy( unsigned char x, unsigned char y );
void LCD_write_char( unsigned x,unsigned char y,unsigned char dat);
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s);
void LCD_init(void);
void delay_nms(unsigned int n);
void main(void)
  LCD_init();
  while(1 )
     LCD_en_command(0x01);
    delay_nms(2);
        LCD_write_string(0,0,"     create by    ");
        LCD_write_string(0,1,"     fenyman      ");
        delay_nms(200);
    delay_nms(2);
        LCD_write_string(0,0,"     LCD1602   ");
        LCD_write_string(0,1,"     test      ");
        delay_nms(200);
/******************** LCD PART *************************************/
  unsigned char i;
  for(i=40;i>0;i--)
  LCD1602_RS=0;
  LCD1602_RW=0;
  LCD1602_EN=0;
  LCDIO=(command & 0xf0);
  LCD1602_EN=1;
  LCD_delay();
  LCD1602_EN=0;
  LCDIO=(command & 0x0f)<<4;
  LCD1602_EN=1;
  LCD_delay();
  LCD1602_EN=0;
void LCD_en_dat(unsigned char dat)
  LCD1602_RS=1;
  LCD1602_RW=0;
  LCD1602_EN=0;
  LCDIO=(dat & 0xf0);
  LCD1602_EN=1;
  LCD_delay();
  LCD1602_EN=0;
  LCDIO=(dat & 0x0f)<<4;
  LCD1602_EN=1;
  LCD_delay();
  LCD1602_EN=0;
  unsigned char address;
  if (y ==0)
   address = 0x80 + x;
  else
      address = 0xC0 + x;
  LCD_en_command(address);
  LCD_set_xy( x, y );
  LCD_en_dat(dat);
    LCD_set_xy( X, Y );    //set address
    while (*s)       // write character
      LCDIO=*s;
      LCD_en_dat(*s);
   s ++;
void LCD_init(void)
  delay_nms(5);
  delay_nms(5);
  LCD_en_command(0x28);
  delay_nms(5);
  delay_nms(5);
  delay_nms(5);
  LCD_en_command(0x0C);
  delay_nms(5);
  LCD_en_command(0x80);
  delay_nms(5);
  delay_nms(5);
    unsigned int i=0,j=0;
    for (i=n;i>0;i--)
     for (j=0;j<1140;j++);
关键字:LCD1602  4线并口通信
