程序功能:控制8个LED闪烁,控制灯的流向以及流速
#include
/*下面关闭所有的IO口*/
#define close_IO P1DIR = 0XFF;P1OUT = 0XFF; P2DIR = 0XFF;P2OUT = 0XFF;P3DIR = 0XFF;P3OUT = 0XFF;P4DIR = 0XFF;P4OUT = 0XFF; P5DIR = 0XFF;P5OUT = 0XFF; P6DIR = 0XFF;P6OUT = 0XFF;
typedef unsigned int uint;
uint i = 0,j = 0,dir = 0;
uint flag = 0,speed = 0; //flag--灯光流动方式,speed--灯光流动速度
/****************主函数****************/
void main(void)
void P_setting();
close_IO;
P_setting();
_EINT(); //使能全局中断
LPM0; //CPU进入LPM0模式
/*将设置进行封装*/
void P_setting(void){
WDTCTL = WDTPW + WDTHOLD; //关闭看门狗
P6DIR |= BIT2;P6OUT |= BIT2; //关闭电平转换
P5OUT &= ~BIT7;
CCTL0 = CCIE; //使能CCR0中断
CCR0 = 50000;
TACTL = TASSEL_2 + ID_3 + MC_1; //定时器A的时钟源选择SMCLK,增计数模式
P2DIR = 0xff; //设置P2口方向为输出
P2OUT = 0xff;
函数名称:Timer_A
功 能:定时器A的中断服务函数,在这里通过标志
控制流水灯的流动方向和流动速度
#pragma vector = TIMERA0_VECTOR
__interrupt void Timer_A (void)
if(flag == 0)
P2OUT = ~(0x80>>(i++)); //灯的点亮顺序D8 -> D1
else if(flag == 1)
P2OUT = ~(0x01< D8
else
if(dir) //灯的点亮顺序 D8 -> D1,D1 -> D8,循环绕圈
else
P2OUT = ~(0x01< }
if(i == 8)
i = 0;
dir = ~dir;
j++;
if(j == 40)
i = 0;
j = 0;
flag++;
if(flag == 4) flag = 0;
switch(speed)
case 0:
TACTL &=~ (ID0 + ID1); //增计数模式
TACTL |= ID_3; //8分频
break;
case 1:
TACTL |= ID_2; //4分频
break;
case 2:
TACTL |= ID_1; //2分频
break;
case 3:
TACTL |= ID_0; //1分频
break;
default:
break;
if(flag != 3) speed++;
if(speed == 4) speed = 0;
《经过测试适用于f149系列》
