timer驱动API非常简单,就只有几个,开始计时,停止计时,获得计数值。认识初始化参数结构体即可
typdef struct {
Timer_Mode timerMode; //模式
Timer_PeriodUnits periodUnits; //计数周期单位
Timer_CallBackFxn timerCallback; //回调函数
uint32_t period; //计数周期,联系periodUnits
//下面记录一下具体的数据结构参数
//模式结构体 注意,某些定时器可以被配置为向上计数和向下计数模式,通过Timer_getCount()得到计数值
typedef enum{
Timer_ONESHOT_CALLBACK, //非阻塞,只会产生一次到时中断,再次用Timer_start()可以再次生成一次定时
Timer_ONESHOT_BLOCKING, //一次阻塞型
Timer_CONTINUOUS_CALLBACK, //周期性定时
Timer_FREE_RUNNING //非阻塞,一直计数,不会产生中断,一般与Timer_getCount()配套使用
}Timer_Mode;
//计数单位
typedef enum{
Timer_PERIOD_US, //微秒级计数
Timer_PERIOD_HZ, //秒级计数
Timer_PERIOD_COUNTS //自定义
}Timer_PeriodUnits;
//中断回调函数
typedef void (*Timer_CallBackFxn)(Timer_Handle handle);
仅仅知道上面并不能完全使用定时器的驱动库,还需要去了解MSP_EXP432P401R.c与.h文件关于定时器的使用以及定时器相关头文件的地址、时钟等参数定义
共有六个定时器,2个32位
TIMER32_1
TIMER32_2
TIMER_A0
TIMER_A1
TIMER_A2
TIMER_A3
#include
#include
TimerMSP432_Object timerMSP432Objects[MSP_EXP432P401R_TIMERCOUNT];
const TimerMSP432_HWAttrs timerMSP432HWAttrs[MSP_EXP432P401R_TIMERCOUNT] = {
/* Timer32_0 */
.timerBaseAddress = TIMER32_0_BASE,
.clockSource = TIMER_A_CLOCKSOURCE_SMCLK,
.intNum = INT_T32_INT1,
.intPriority = ~0
.timerBaseAddress = TIMER32_1_BASE,
.intNum = INT_T32_INT2,
.intPriority = ~0
/* Timer_A1 */
.timerBaseAddress = TIMER_A1_BASE,
.clockSource = TIMER_A_CLOCKSOURCE_ACLK,
.intNum = INT_TA1_0,
.intPriority = ~0
/* Timer_A2 */
.timerBaseAddress = TIMER_A2_BASE,
.intNum = INT_TA2_0,
.intPriority = ~0
/* Timer_A3 */
.timerBaseAddress = TIMER_A3_BASE,
.intNum = INT_TA3_0,
.intPriority = ~0
const Timer_Config Timer_config[MSP_EXP432P401R_TIMERCOUNT] = {
.fxnTablePtr = &TimerMSP432_Timer32_fxnTable,
.object = &timerMSP432Objects[MSP_EXP432P401R_TIMER_T32_0],
.hwAttrs = &timerMSP432HWAttrs[MSP_EXP432P401R_TIMER_T32_0]
.object = &timerMSP432Objects[MSP_EXP432P401R_TIMER_T32_1],
.hwAttrs = &timerMSP432HWAttrs[MSP_EXP432P401R_TIMER_T32_1]
.fxnTablePtr = &TimerMSP432_Timer_A_fxnTable,
.object = &timerMSP432Objects[MSP_EXP432P401R_TIMER_TA_1],
.hwAttrs = &timerMSP432HWAttrs[MSP_EXP432P401R_TIMER_TA_1]
.object = &timerMSP432Objects[MSP_EXP432P401R_TIMER_TA_2],
.hwAttrs = &timerMSP432HWAttrs[MSP_EXP432P401R_TIMER_TA_2]
.object = &timerMSP432Objects[MSP_EXP432P401R_TIMER_TA_3],
.hwAttrs = &timerMSP432HWAttrs[MSP_EXP432P401R_TIMER_TA_3]
const uint_least8_t Timer_count = MSP_EXP432P401R_TIMERCOUNT;
