start.S源码:
.globl _start
_start:
// 硬件相关的设置
// Peri port setup
ldr r0, =0x70000000
orr r0, r0, #0x13
mcr p15,0,r0,c15,c2,4 @ 256M(0x70000000-0x7fffffff)
// 关看门狗
// 往WTCON(0x7E004000)写0
ldr r0, =0x7E004000
mov r1, #0
str r1, [r0]
// 设置时钟
bl clock_init
// 设置栈
ldr sp, =8*1024
bl main
halt:
b halt
clock.S源码:
//MDIV=250 对应: ARMCLK = 500MHz, HCLK = 100MHz, PCLK = 50MHZ
//MDIV=266 对应: ARMCLK = 532MHz, HCLK = 133MHz, PCLK = 66.5MHZ
.globl clock_init
clock_init:
// 1.设置LOCK_TIME ,等待时钟稳定的时间
ldr r0, =0x7E00F000 // APLL_LOCK
ldr r1, =0x0000FFFF
str r1, [r0]
str r1, [r0, #4] // MPLL_LOCK
str r1, [r0, #8] // EPLL_LOCK
#define OTHERS 0x7e00f900
@ set async mode // 当CPU时钟 != HCLK(内存等)时,要设为异步模式
ldr r0, =OTHERS
ldr r1, [r0]
bic r1, #0xc0
str r1, [r0]
loop1: // 等待,直到CPU进入异步模式
ldr r0, =OTHERS
ldr r1, [r0]
and r1, #0xf00
cmp r1, #0
bne loop1
// SYNC667
// MISC_CON[19] = 0
#define ARM_RATIO 0 // ARMCLK = DOUTAPLL / (ARM_RATIO + 1)
#define HCLKX2_RATIO 1 // HCLKX2 = HCLKX2IN / (HCLKX2_RATIO + 1)
#define HCLK_RATIO 1 // HCLK = HCLKX2 / (HCLK_RATIO + 1)
#define PCLK_RATIO 3 // PCLK = HCLKX2 / (PCLK_RATIO + 1)
#define MPLL_RATIO 0 // DOUTMPLL = MOUTMPLL / (MPLL_RATIO + 1)
ldr r0, =0x7E00F020 // CLK_DIV0
ldr r1, =(ARM_RATIO) | (MPLL_RATIO << 4) | (HCLK_RATIO << 8) | (HCLKX2_RATIO << 9) | (PCLK_RATIO << 12)
str r1, [r0]
// 2.配置时钟
// 2.1 配置APLL
// 2.1.1 设置APLL
// 2.1.2 MUXAPLL
// 2.1.3 SYNC667
// 2.1.4 DIVAPLL
#define APLL_CON_VAL ((1<<31) | (266 << 16) | (3 << 8) | (1))
ldr r0, =0x7E00F00C
ldr r1, =APLL_CON_VAL
str r1, [r0] // APLL_CON, FOUTAPL = MDIV * Fin / (PDIV*2^SDIV) = 266*12/(3*2^1) = 532MHz
// 2.2 配置MPLL
// 2.2.1 设置MPLL
// 2.2.2 MUXMPLL
// 2.2.3 SYNCMUX
// 2.2.4 SYNC667
// 2.2.5 HCLKX2_RATIO
// 2.2.6 PCLK_RATIO
#define MPLL_CON_VAL ((1<<31) | (266 << 16) | (3 << 8) | (1))
ldr r0, =0x7E00F010
ldr r1, =MPLL_CON_VAL
str r1, [r0] // MPLL_CON, FOUTMPL = MDIV * Fin / (PDIV*2^SDIV) = 266*12/(3*2^1) = 532MHz
// 3.选择PLL的输出作为时钟源
ldr r0, =0x7E00F01C
ldr r1, =0x03
str r1, [r0]
mov pc, lr
led.c源码:
void delay()
volatile int i = 0x10000;
while (i--);
int main()
int i = 0;
volatile unsigned long *gpmcon = (volatile unsigned long *)0x7F008820;
volatile unsigned long *gpmdat = (volatile unsigned long *)0x7F008824;
// gpm0,1,2,3设为输出引脚
*gpmcon = 0x1111;
while (1)
*gpmdat = i;
i++;
if (i == 16)
i = 0;
delay();
return 0;
Makefile:
led.bin: start.o clock.o led.o
arm-linux-ld -Ttext 0 -o led.elf start.o clock.o led.o
arm-linux-objcopy -O binary led.elf led.bin
arm-linux-objdump -D led.elf > led.dis
%.o : %.S
arm-linux-gcc -o $@ $< -c
%.o : %.c
clean:
rm *.o led.elf led.bin led.dis
