单片机 > 单片机程序设计 > 详情
S3C2410 LED驱动程序
发布时间:2025-08-29 发布时间:
编写驱动程序代码:
#include
#include
#include
#include
#include
#include
#include
#include
#undef DEBUG
#define DEBUG
#ifdef DEBUG
#define DPRINTK(x...)      printk("s3c2410-led:" x)
#else
#endif
#define DEVICE_NAME   "s3c2410-led"
#define DbLedRAW_MINOR
static int DbLedMajor=0;
static char ledstatus=2;
static void Updateled(void)
    if(ledstatus&0x01)
        write_gpio_bit(GPIO_B0,1);   //LED亮
    else
        write_gpio_bit(GPIO_B0,0);   //LED灭
static ssize_t s3c2410_DbLed_write(struct file *file,const char *buffer,size_t count,loff_t *ppos)
    copy_from_user(&ledstatus,buffer,sizeof(ledstatus));
    Updateled();
    DPRINTK("write: led=0x%x,count=%d\n",ledstatus,count);
    return sizeof(ledstatus);
static int s3c2410_DbLed_open(struct inode *inode,struct file *filp)
    MOD_INC_USE_COUNT;
    DPRINTK("open\n");
    return 0;
static int s3c2410_DbLed_release(struct inode *inode,struct file *filp)
    MOD_DEC_USE_COUNT;
    DPRINTK("release\n");
    return 0;
static struct file_operations s3c2410_fops={                                 //***字符设备时调用
    owner:     THIS_MODULE,
    open:       s3c2410_DbLed_open,
 write:       s3c2410_DbLed_write,
    release:     s3c2410_DbLed_release,
#ifdef CONFIG_DEVFS_FS
static  devfs_handle_t devfs_DbLed_dir,devfs_DbLedraw;
#endif
static int __init s3c2410_DbLed_init(void)                                //begin
    int ret;
    set_gpio_ctrl(GPIO_MODE_OUT|GPIO_PULLUP_DIS|GPIO_B0);      //GPIO_B0设为输出无上拉状态
    Updateled();
    ret=register_chrdev(0,DEVICE_NAME,&s3c2410_fops);           //***字符设备驱动
    if(ret<0) {                                                               //小于0,也就是失败
        printk(DEVICE_NAME "can't get major number\n");
        return ret;
    DbLedMajor=ret;
#ifdef CONFIG_DEVFS_FS                                                    //创建文件系统节点
    devfs_DbLed_dir=devfs_mk_dir(NULL,"led",NULL);
    devfs_DbLedraw=devfs_register(devfs_DbLed_dir,"0",DEVFS_FL_DEFAULT,DbLedMajor,0,S_IFCHR|S_IRUSR|S_IWUSR,&s3c2410_fops,NULL);
#endif
    printk(DEVICE_NAME " initialized\n");
    return 0;
static void __exit s3c2410_DbLed_exit(void)
        devfs_unregister(devfs_DbLedraw);
        devfs_unregister(devfs_DbLed_dir);
#endif
    unregister_chrdev(DbLedMajor,DEVICE_NAME);
module_init(s3c2410_DbLed_init);
module_exit(s3c2410_DbLed_exit);
因为LED位字符设备,习惯上将简单的字符设备的驱动程序放在内核跟目录drivers/char目录下
2.
在LED驱动程序中,把驱动程序添加到内核,实现裁剪和编译,需要修改drivers/char/Config.in和drivers/char/Makefile
在drivers/char/Config.in文件中添加:
Dep_tristate ‘S3C2410 LED support’  CONFIG_S3C2410_GPIO_LED
$CONFIG_ARCH_S3C2410
其含义是:只要定义了CONFIG_ARCH_S3C2410位y或m,在内核配置时(make menuconfig),Character devices 分类下,就会出现S3C2410 LED support选项,它对应了CONFIG_S3C2410_GPIO_LED的定义。
在drivers/char/Makefile文件中添加:
obj-$ (CONFIG_S3C2410_GPIO_LED) +=LED.o
Makefile会根据obj-m和obj-y编译并连接对应的源码。这里在配置内核时选择编译为内核可加载的模块。
3.执行编译命令:
Make modules
可以编译内核中所有配置为模块的驱动程序。
或者使用命令:
Make modules SUBDIRS=drivers/char
只编译内核源码中drivers/char目录下的模块。
4.将编译好的LED.o文件复制到网络文件系统文件夹nfsfile(或者复制到开发板),启动开发板,挂载nfsfile文件夹,然后进入nfsfile文件夹,执行insmod命令把驱动程序加载到内核中:
Insmod LED.o
(使用rnmod LED卸载已经加载到内核中的模块)
5.测试LED驱动程序
用echo命令的重定向(>)方法,实现对这个设备的open,close,write等操作。
使用echo –n 1 >/dev/led/0  (-n阻止echo命令自动换行)
向驱动程序写入0x31( 1的ASCII码),LED被点亮
执行echo –n 0 > /dev/led/0,led熄灭
(也可以直接编译进内核)
