//该程序例程是使用的GDstm32f130的芯片,使用TIM1的通道2和通道3输出波形
int main(void)
u16 led0pwmval=0;
u8 dir=1;
SystemOn_Init();
InitRFChip();
PWM_TIM1(899,0); //?μ?ê?a48MHZ/(999+1)/(1+99)=24KHZ
while (1)
Delay_MS(1);
if(dir)led0pwmval+=1;
else led0pwmval-=1;
if(led0pwmval>800)dir=0;
if(led0pwmval==0)dir=1;
TIM_SetCompare2(TIM1,led0pwmval);
TIM_SetCompare3(TIM1,led0pwmval);
//IO口初始化
void USART1_GPIO_Configuration(void)
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_2); //TIM1channel2
GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_2); //TIM1channel3
//PA9(UART Tx)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
//PA10(UART Rx)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
//定时器TIM1的初始化
void PWM_TIM1(uint16_t arr,uint16_t psc)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); //ê±?óê1?ü
USART1_GPIO_Configuration();
TIM_DeInit(TIM1);
TIM_TimeBaseStructure.TIM_Period =arr; //éè???ú??ò????üD?ê??t×°è????ˉμ?×??ˉ??×°????′??÷?ü?úμ??μ
TIM_TimeBaseStructure.TIM_Prescaler =psc; //éè??ó?à′×÷?aTIMxê±?ó?μ?ê3yêyμ??¤·??μ?μ,10Khzμ???êy?μ?ê
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //éè??ê±?ó·???:TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //?òé???êy?£ê?
//TIM_TimeBaseStructure.TIM_RepetitionCounter=0; //???′??′??÷
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //?ù?YTIM_TimeBaseInitStruct?D???¨μ?2?êy3?ê??ˉ
//TIM1μ?channel2 PWMê?3?
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //ê?3?±è??ê1?ü
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //ê?3?±è????D??a??μ???
TIM_OC2Init(TIM1, &TIM_OCInitStructure); //3?ê??ˉ
TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable);
TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_High; //éè???¥21??ê?3???D?
TIM_OCInitStructure.TIM_Pulse=30;
TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Disable; //ê1?ü?¥21????D?
TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Reset; //?à??oóê?3?×′ì?
TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset; //?à??oó?¥21??ê?3?×′ì?
TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Disable;//??DD?£ê???ê?3?
TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Disable;//???D?£ê???ê?3?????
TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF; //???¨éè??
TIM_BDTRInitStructure.TIM_DeadTime = 0x90; //?à??ê±??
TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable; //é23μ1|?üê1?ü
TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;//é23μê?3???D?
TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;// ×??ˉê?3?ê1?ü
TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
//TIM1μ?channel3 PWMê?3?
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //TIM1ê?3?±è??′¥·¢?£ê?
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //ê1?üê?3?±è??×′ì?
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //éè??ê?3???D??a??μ???
TIM_OC3Init(TIM1, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable); //ê1?ü?¤×°????′??÷
TIM_ARRPreloadConfig(TIM1,ENABLE);
TIM_Cmd(TIM1, ENABLE); //ê1?üTIM1
TIM_CtrlPWMOutputs(TIM1,ENABLE);
