rt-thread中已经部分实现了rtc的内容 ---> rtc.c ,调用rt_hw_rtc_init()函数即可使用msh设置date和time等
rtc时钟来源有三个:
HSE, LSE, LSI, 实现如下: 在原RTC_Configuration(void)进行替换即可
/* Enable LSE */
#ifdef USE_LSE
RCC_LSEConfig(RCC_LSE_ON);
/* Wait till LSE is ready */
while ( (RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET) && (--count) );
#else
#ifdef USE_HSE
#else
RCC_LSICmd(ENABLE);
while ( (RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET) && (--count) );
#endif
#endif
if ( count == 0 )
return -1;
/* Select LSE as RTC Clock Source */
#ifdef USE_LSE
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
#else
#ifdef USE_HSE
RCC_RTCCLKConfig(RCC_RTCCLKSource_HSE_Div128);
#else
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);
#endif
#endif
/* Enable RTC Clock */
RCC_RTCCLKCmd(ENABLE);
/* Wait for RTC registers synchronization */
RTC_WaitForSynchro();
/* Wait until last write operation on RTC registers has finished */
RTC_WaitForLastTask();
/* Set RTC prescaler: set RTC period to 1sec */
#ifdef USE_LSE
RTC_SetPrescaler(32767); /* RTC period = RTCCLK/RTC_PR = (32.768 KHz)/(32767+1) */
#else
#ifdef USE_HSE
RTC_SetPrescaler(93749); /* 72 MHz / 128 */
#else
RTC_SetPrescaler(40000); /* 40 KHz */
#endif
#endif
注意:/* Note:If the HSE divided by 128 is used as the RTC clock, this bit must remain set to 1. */
秒中断和ALARM中断实现:
rt_hw_rtc_navi_init();
RTC_SetAlarm(RTC_GetCounter()+25); //当前RTC值的基础上加时间
RTC_ITConfig(RTC_IT_SEC, ENABLE); //使能秒中断
RTC_ITConfig(RTC_IT_ALR,ENABLE); //使能arlarm中断
void rt_hw_rtc_navi_init(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void RTC_IRQHandler(void)
/* enter interrupt */
rt_interrupt_enter();
if(RTC_GetITStatus(RTC_IT_ALR) == SET)
rt_kprintf("RTCAlarm_IRQHandler1~~~rn");
RTC_ClearITPendingBit(RTC_IT_ALR);
if(RTC_GetITStatus(RTC_IT_SEC) == SET)
RTC_ClearITPendingBit(RTC_IT_SEC);
rt_kprintf("RTCAlarm_IRQHandler2~~~rn");
/* leave interrupt */
rt_interrupt_leave();
ps:RTCAlarm_IRQn = 41, /*!< RTC Alarm through EXTI Line Interrupt */ 这个不是alarm的中断函数哟
