(1)内部时钟(CK_INT)
(2)外部时钟模式1:外部输入脚(TIx)
(3)外部时钟模式2:外部触发输入(ETR)
(4)内部触发输入(ITRx)
时钟源(CK_INT)经预分频(PSC)后得到定时时钟(CK_CNT),每个定时时钟计数寄存器计数(可设向上/向下/中央对齐模式),计数寄存器计数至捕获比较寄存器(CCR),则产生CC中断;计数寄存器计数至预装载值(ARR),则产生UPDATE中断,并重装预载值。
举个例子:(以向上计数为例,每40us中断一次)
void TIM2_Configuration(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); // for 36MHz
TIM_DeInit(TIM2);
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Period = 1200; // 预装初值
TIM_TimeBaseStructure.TIM_Prescaler = 36-1; // 预分频
TIM_TimeBaseStructure.TIM_ClockDivision = 0x00; // 时钟分频因子(用于ETR,TIX)
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; // 向上计数
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; // 重复计数
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 40; //40us中断一次
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC1Init(TIM2, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable);
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Disable;
TIM_OCInitStructure.TIM_Pulse = 800; //PWM 800/1200
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Disable);
// TIM_SelectSlaveMode(TIM2, TIM_SlaveMode_Gated);
// TIM_SelectInputTrigger(TIM2, TIM_TS_ITR0);
TIM_ARRPreloadConfig(TIM2, DISABLE);
TIM_ITConfig(TIM2, TIM_IT_CC1|TIM_IT_CC2|TIM_IT_Update, ENABLE);
TIM_Cmd(TIM2, ENABLE);
/*--------------中断程序-------------------*/
void TIM2_IRQHandler(void)
uint16_t capture = 0;
if(TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
if((timer_cnt1++)>49)
timer_cnt1 = 0;
f_2ms = 1;
TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
capture = TIM_GetCapture1(TIM2);
if(capture==1200)
TIM_SetCompare1(TIM2, 40);
else
TIM_SetCompare1(TIM2, capture + 40);
if(TIM_GetITStatus(TIM2, TIM_IT_CC2) != RESET)
GPIO_SetBits(P_LCDBK, LCDBK);
if(TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
GPIO_ResetBits(P_LCDBK, LCDBK);
TIM2->SR = 0x00;
