* File: Serial_Comm_1.C
* Description: Serial Communication Example 1
* Created Date: 2007-10-01
* Last Modified: 2007-10-01
* Author: Jeffrey - Schicksal@126.com
* Notes: None
#include "Atmel/AT89X51.h"
unsigned char Read_Keyboard();
void RS232_SendData(unsigned char Sdata);
* Function: delay(unsigned int t)
* Input Variables: t
* Return Variables: None
* Usage: Common Delay Routine, t as the delay time ticks
void delay(unsigned int t)
for(;t>0;t--); // 延时循环
* Function: RS232_Init(void)
* Input Variables: none
* Usage: Init UART
void RS232_Init()
SCON = 0x50; // UART工作于模式1, REN=1
TMOD = 0x20 ; // Timer1 工业于模式2
PCON |= 0x80; // SMOD1 = 1
TH1 = 0xF3; // 波特率9600 Bds at 24MHz
TL1 = 0xF3; // 波特率9600 Bds at 24MHz
TR1 = 1; // 启动Timer1
* Function: main()
* Input Variables: None
* Usage: Program Entry
void main()
unsigned char Keyboard_Status = 0xff; // 定义键值
RS232_Init();
while(1)
Keyboard_Status = Read_Keyboard(); // 读取按键值
//********************主程序部分*********************//
switch(Keyboard_Status)
case (~0x01):
RS232_SendData('A');
break;
case (~0x02):
RS232_SendData('B');
break;
case (~0x04):
RS232_SendData('C');
break;
case (~0x08):
RS232_SendData('D');
break;
case (~0x10):
RS232_SendData('E');
break;
case (~0x20):
RS232_SendData('F');
break;
case (~0x40):
RS232_SendData('G');
break;
case (~0x80):
RS232_SendData('H');
break;
default:
//RS232_SendData('X');
break;
* Function: RS232_SendData(unsigned char Sdata)
* Input Variables: unsigned char Sdata
* Return Variables: none
* Usage: Send a Char to UART
SBUF = Sdata; // 发送数据
while(TI==0); // 等待发送完毕
TI = 0; // 清除发送结束标志
* Function: Read_Keyboard
* Return Variables: Keys Value
* Usage: Read Keyboard Status
unsigned char Keys_Value=0; // 定义键值变量
unsigned char Keys_Temp;
P2=0xff;
Keys_Value=P2;
do
P2 = 0xff; // P2口置高,准备读取按键状态
Keys_Temp = P2; // 读取按键状态
delay(150); // 消抖延时
Keys_Value = P2; // 读取按键状态
while(Keys_Value != Keys_Temp); // 如果读取状态不一致,则重复读取键值
while(P2!=0xff); // 直到按键释放
return Keys_Value; // 返回按键状态值
