// GPIO 位操作
#include "stm32f4xx.h"
// 这里只定义了GPIO ODR和IDR这两个寄存器的位带别名区地址,其他寄存器没有定义
//SRAM 位带区: 0X2000 0000~0X200F 0000
//SRAM 位带别名区: 0X2200 0000~0X23FF FFFF
//外设位带区: 0X4000 0000~0X400F FFFF
//外设位带别名区: 0X4200 0000~0X43FF FFFF
// 把“位带地址+位序号”转换成别名地址的宏
#define BITBAND(addr, bitnum) ((addr & 0xF0000000)+0x02000000+((addr & 0x000FFFFF)<<5)+(bitnum<<2))
// 把一个地址转换成一个指针
#define MEM_ADDR(addr) *((volatile unsigned long *)(addr))
// 把位带别名区地址转换成指针
#define BIT_ADDR(addr, bitnum) MEM_ADDR(BITBAND(addr, bitnum))
// GPIO ODR 和 IDR 寄存器地址映射
#define GPIOA_ODR_Addr (GPIOA_BASE+20)
#define GPIOB_ODR_Addr (GPIOB_BASE+20)
#define GPIOC_ODR_Addr (GPIOC_BASE+20)
#define GPIOD_ODR_Addr (GPIOD_BASE+20)
#define GPIOE_ODR_Addr (GPIOE_BASE+20)
#define GPIOF_ODR_Addr (GPIOF_BASE+20)
#define GPIOG_ODR_Addr (GPIOG_BASE+20)
#define GPIOH_ODR_Addr (GPIOH_BASE+20)
#define GPIOI_ODR_Addr (GPIOI_BASE+20)
#define GPIOJ_ODR_Addr (GPIOJ_BASE+20)
#define GPIOK_ODR_Addr (GPIOK_BASE+20)
#define GPIOA_IDR_Addr (GPIOA_BASE+16)
#define GPIOB_IDR_Addr (GPIOB_BASE+16)
#define GPIOC_IDR_Addr (GPIOC_BASE+16)
#define GPIOD_IDR_Addr (GPIOD_BASE+16)
#define GPIOE_IDR_Addr (GPIOE_BASE+16)
#define GPIOF_IDR_Addr (GPIOF_BASE+16)
#define GPIOG_IDR_Addr (GPIOG_BASE+16)
#define GPIOH_IDR_Addr (GPIOH_BASE+16)
#define GPIOI_IDR_Addr (GPIOI_BASE+16)
#define GPIOJ_IDR_Addr (GPIOJ_BASE+16)
#define GPIOK_IDR_Addr (GPIOK_BASE+16)
// 单独操作GPIO的某一个IO口,(n=0,...15)
#define PAout(n) BIT_ADDR(GPIOA_ODR_Addr,n) //输出
#define PAin(n) BIT_ADDR(GPIOA_IDR_Addr,n) //输入
#define PBout(n) BIT_ADDR(GPIOB_ODR_Addr,n)
#define PBin(n) BIT_ADDR(GPIOB_IDR_Addr,n)
#define PCout(n) BIT_ADDR(GPIOC_ODR_Addr,n)
#define PCin(n) BIT_ADDR(GPIOC_IDR_Addr,n)
#define PDout(n) BIT_ADDR(GPIOD_ODR_Addr,n)
#define PDin(n) BIT_ADDR(GPIOD_IDR_Addr,n)
#define PEout(n) BIT_ADDR(GPIOE_ODR_Addr,n)
#define PEin(n) BIT_ADDR(GPIOE_IDR_Addr,n)
#define PFout(n) BIT_ADDR(GPIOF_ODR_Addr,n)
#define PFin(n) BIT_ADDR(GPIOF_IDR_Addr,n)
#define PGout(n) BIT_ADDR(GPIOG_ODR_Addr,n)
#define PGin(n) BIT_ADDR(GPIOG_IDR_Addr,n)
#define PHout(n) BIT_ADDR(GPIOH_ODR_Addr,n)
#define PHin(n) BIT_ADDR(GPIOH_IDR_Addr,n)
#define PIout(n) BIT_ADDR(GPIOI_ODR_Addr,n)
#define PIin(n) BIT_ADDR(GPIOI_IDR_Addr,n)
#define PJout(n) BIT_ADDR(GPIOJ_ODR_Addr,n)
#define PJin(n) BIT_ADDR(GPIOJ_IDR_Addr,n)
#define PKout(n) BIT_ADDR(GPIOK_ODR_Addr,n)
#define PKin(n) BIT_ADDR(GPIOK_IDR_Addr,n)
void LED_GPIO_Config(void);
void SOFT_Delay(__IO uint32_t nCount);
int main(void)
/* LED 端口初始化 */
LED_GPIO_Config();
while (1)
// PH10 = 0,点亮LED
PHout(10)= 0;
SOFT_Delay(0x0FFFFF);
// PH10 = 1,熄灭LED
PHout(10)= 1;
* 初始化LED用到的IO口
RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_GPIOH, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOH, &GPIO_InitStructure);
GPIO_SetBits(GPIOH, GPIO_Pin_10);
// 简单的延时函数
for(; nCount != 0; nCount--);
/*********************************************END OF FILE**********************/
