嵌入式 > 技术百科 > 详情
30MHz 8MHz频率的滤波器
发布时间:2023-03-07 发布时间:
三通道视频重建滤波器YUV/RGB过滤器多个rgb/yuv输入的2:1 mux输入可选8MHz或30MHz六阶滤波器对于rgb(yuv)应用程序8MHz 6阶Y,C滤波器,带复合夏季直流耦合输入,交流耦合输出所有输出可驱动交流耦合150Ω负载和提供6dB增益双多路输入0.6%差分增益,0.2°差分相位所有通道上的36dB/倍频程衰减。
应用
有线机顶盒卫星机顶盒DVD播放器高清晰度电视个人录像机(PVR)视频点播(VOD)FMS6419为机顶盒提供全面过滤或DVD应用程序。这部分由三个6阶组成可选择30MHz或8MHz频率的滤波器。在每个滤波器信道上提供2对1多路复用器。这个三重滤波器适用YUV或RGB信号。所有信道接受直流耦合接地参考1V信号。滤波器将2vpp信号提供给交流耦合终端荷载。低通滤波器由3.3v供电,输出为5.0v。
标准定义典型性能特征(tc=25°C,vi)=1vpp;vcca=3.3v,vcco=5.0v,fsel=0,所有输入交流耦合0.1μf,所有输出AC与220μF耦合到150Ω,参考400kHz;除非另有说明)
高清晰度典型性能特征(tc=25°C,vi)=1vpp;vcca=3.3v,vcco=5.0v,fsel=1,所有输入交流耦合0.1μf,所有输出AC与220μF耦合到150Ω,参考400kHz;除非另有说明)
一般描述
The FMS6419 Offers Comprehensive Filtering for Set Top Box或DVD应用。This part consists of triple 6th order有选择30MHZ或8MHZ频率和Dual filter for filtering Y,C with a composite summer.页1Multipletxers are provided on the triple filters as well asProvisions for auxiliary input to the composite channel.TheTriple filters are intended for either yuv or rgb signals.All channels accept DC coupled ground-referenced 1VSignals.The Filters outputs 2vpp signals into AC coupledThe lowpass filters are powered by 3.3vAnd output buffers are powered by 5.0V.The FMS6419 is a next generation filter solution from费尔柴尔德半导体公司最棒的拳击需要和DVD播放器The ProductProvides selectable filtering from 30MHZ to 8MHZ on theRGB ChannelsThus,the FMS6419 addresses the requirement for a single set top box to be company with a varietyof resolution standards.Additionally,the product providesY,C,and composite video(CV)outputs.Multipletxers on the RGB and CV channels provideFurther Flexity.For DVD applications,the product provides filtering and6.Output drive extension for 6 channels of outputs.These包括R,G,B,Y,C,and CV outputs.For set top boxes,this product provides for 2 channels of视频是可以被过滤的,就像被选择的灵活性High order filtering for multiple resolution standards.Additional flexibility is provided by the Y(Luma)and C(Chloma)Filters with a composite summer.All channels provide 6DB gain,accept 1V ground referenced注射,和驱动器AC coupled loads。The Filters for the R,G,B,Y,C,and CV channels are powered from a 3.3V supplyand the outputs from 5V.
应用
直流电平在任何给定的时间,输入信号的直流电平必须是在0.0V和1.3V之间,利用最佳的净空高度和以避免对输出进行剪裁。Y通道应该名义上同步端在地上,是1V信号。C通道应在0.5伏左右。本遗嘱确保过滤器利用最佳的净空高度避免剪接。直流耦合输出应用220μf电容器与150Ω终端耦合形成高通滤波器,在通过视频频率和避免倾斜。较低的值,例如10微F会产生问题。通过交流耦合,平均直流电平为零。因此,所有通道的输出电压将以零为中心。或者,直流耦合允许输出FMS6419,但不建议输出。有几个折衷方案:输出端的平均直流电平为2V。每个输出端将消耗额外的名义上是40兆瓦。应用程序将需要适应一个1V直流偏移同步提示。另外,建议限制一个每个输出150Ω负载。用3.3v驱动数字管脚或5V逻辑只要VIH和VIL。
iPhone 6S摄像头全面提升!苹果力度吓人
