嵌入式 > 技术百科 > 详情
ST汽车动力传送控制解决方案
发布时间:2023-09-25 发布时间:
Automatic Transmission
GLOBAL market acceptance of automatic transmissions is growing and due in part to the improved drivability, responsiveness and fuel economy provided by electronic controls. In SUPPORT of this trend, ST, with its long history of supplying electronic COMPONENTS into transmission applications, has the right product mix to meet your demanding needs. From solenoid drivers to ADVANCED microcontrollers coupled with an extensive STANDARD product offering, ST has a broad range of solutions to choose from. A sampling of ST PRODUCTS that are applicable to Automatic Transmission Control systems can be found in the following block diagram.
1 VOLTAGE REGULATOR
L4925
2 BUS Transceiver
(1) Data INTERFACE - Bus Transceivers [2]
L9615
L9616
3 Control Unit
16-bit Microcontrollers for Automotive [1]
ST10F269D
4 MEMORY
(1) Serial EEPROM, I2C Bus, M24 [4]
M24C04-W
M24C16-W
M24C32-W
(2) Industry Standard, 3V, M29W [21]
M29W008D
M29W008EB
M29W040B
(3) Industry Standard, 5V, M29F [10]
M29F002BB
M29F002BT
M29F010B
(4) Industry Standard, 3V, M29W [1]
M29W010B
(5) Industry Standard, 5V, M29F [3]
M29F200BB
M29F400BB
M29F400BT
(6) Serial EEPROM, I2C Bus, M24 [14]
M24128-BR
M24128-BW
M24256-BW
(7) Serial EEPROM, SPI Bus, M95 [5]
M95040
M95040-W
M95160
(8) Serial EEPROM, SPI Bus, M95 [7]
M95080
M95080-W
M95128-R
(9) Automotive, Burst Mode, M58B [1]
M58BW016D
(10) Automotive, Burst Mode, M58B [1]
M58BW032
5 Solenoid Drivers
L9822E
L9822N
6 Relay Driver
VNS1NV04
7 Control Unit
(1) ST7 - 8-bit Microcontrollers [45]
ST72321AR6
ST72321AR7
ST72321AR9
(2) ST7 - 8-bit Microcontrollers [13]
ST72521AR6
ST72521AR9
ST72521M9
8 Memory
M24C04-W
M24C16-W
M24C32-W
(2) Serial EEPROM, I2C Bus, M24 [14]
M24128-BR
M24128-BW
M24256-BW
(3) Serial EEPROM, SPI Bus, M95 [5]
M95040
M95040-W
M95160
(4) Serial EEPROM, SPI Bus, M95 [7]
M95080
M95080-W
M95128-R
浅谈IP技术在网络电视中的应用
