嵌入式 > 技术百科 > 详情
ST引擎管理系统解决方案
发布时间:2023-10-07 发布时间:
Variable Valve Drive
The sophistication of today’s modern engine management systems are driven by strict governmental regulation mandating increased fuel economy and engine performance while lowering harmful emissions. This has driven the industry need to develop improvements to gasoline engine CONTROL systems, such as electronic throttle control, variable valve timing, electronic stability, and REMOTE starting, to name a few. ST, with a strong portfolio of ADVANCED TECHNOLOGIES (BCD for combining PRECISION ANALOG, power, DIGITAL and non-volatile MEMORY functions; VIPower for driving high current loads; Embedded FLASH 8/16/32-bit Microcontrollers for real-time control) coupled with extensive STANDARD product offering, is ready to meet the changing market demands. A sampling of ST PRODUCTS that are applicable to Variable Valve Drive Systems can be found in the following block diagram.
1 VOLTAGE REGULATOR
(1) Very Low-Drop [1]
L4925
(2) Low-Drop [2]
L4979
L4989
2 Bus Transceiver
(1) Data INTERFACE - Bus Transceivers [2]
L9615
L9616
(2) Data Interface - Bus Transceivers [1]
L9638
3 Control Unit
ST10F269D
4 Memory
(1) Serial EEPROM, I2C Bus, M24 [4]
M24C04-W
M24C16-W
M24C32-W
(2) Serial EEPROM, SPI Bus, M95 [5]
M95040
M95040-W
M95160
(3) Serial EEPROM, SPI Bus, M95 [11]
M95010-W
M95020-W
M95080
(4) Industry Standard, 5V, M29F [10]
M29F002BB
M29F002BT
M29F010B
(5) Automotive, Burst Mode, M58B [1]
M58BW032
(6) Industry Standard, 3V, M29W [21]
M29W008D
M29W008EB
M29W040B
(7) Serial EEPROM, I2C Bus, M24 [14]
M24128-BR
M24128-BW
M24256-BW
(8) Industry Standard, 3V, M29W [1]
M29W010B
(9) Automotive, Burst Mode, M58B [1]
M58BW016D
(10) Industry Standard, 5V, M29F [3]
M29F200BB
M29F400BB
M29F400BT
5 BRIDGE Controller
L9904
(1) Low Voltage N Channel [5]
STB190NF04
STB200NF04
STP100NF04
(2) Low Voltage N Channel [1]
STB100NF04
浅谈IP技术在网络电视中的应用
