Exhaust Gas Recirculation
The EGR valve has been around since tail-pipe emissions were a concern in cars. Electronically controlling this valve provides the engine control designer with that much more control over the air-fuel stoichiometry making this world a cleaner place to live. ST’s PRODUCTS are used in this application to improve fuel economy and lower vehicle exhaust gas emissions. Providing solutions from the embedded MICROCONTROLLER to the power SWITCHES, from VOLTAGE regulation to the serial communications physical layer, ST has the answer for your EGR control needs.
1 Voltage REGULATOR
(1) Low-Drop [2]
L4979
L4989
(2) Very Low-Drop [1]
L4925
2 Bus Transceiver
L9616
3 Bus Transceiver
L9637
4 Control Unit
ST72324BJ2
ST72324BJ4
ST72324BJ6
5 MEMORY
(1) Serial EEPROM, I2C Bus, M24 [4]
M24C04-W
M24C16-W
M24C32-W
(2) Serial EEPROM, I2C Bus, M24 [14]
M24128-BR
M24128-BW
M24256-BW
(3) Serial EEPROM, SPI Bus, M95 [5]
M95040
M95040-W
M95160
(4) Serial EEPROM, SPI Bus, M95 [11]
M95010-W
M95020-W
M95080
(5) Serial Flash for Code Storage, M25P [9]
M25P05-A
M25P10-A
M25P128
