DSL Line Driver
EL1517A
xDSL Differential Line Driver
EL1517
VDSL CO/CPE Line Driver
EL1509
ADSL CPE Line Driver
EL1510
EL1511
ADSL/VDSL Line Driver
EL1519
ISL1556
ISL1557
USB Hot Plug
ISL6118
2.5V to 5V Dual Power Supply CONTROLLER with 0.6A INTEGRATED Current Regulation and Timed Delay to Latch-off
ISL6119
USB Dual Port Power Supply Controller
ISL6121
SINGLE Supply Integrated Current Limiting Controller
RS-232
ISL4221E
QFN Packaged, +/-15kV ESD Protected, +2.7V to +5.5V, 150Nanoamp, 250kBps, RS-232 Transmitters/Receivers
ISL4238E
QFN Packaged, 115kV ESD Protected, +2.7V to +5.5V, 10Nanoamp, 250kbps/ 1Mbps, RS-232 Transceivers with Enhanced Automatic Powerdown
ICL3238E
+/-15kV ESD Protected, +3V To +5.5V, 1microamp, 250kbps, RS-232 Transceivers With Enhanced Automatic Powerdown
ICL3221E
+/-15kV ESD Protected, +3V to +5.5V, 1Microamp, 250kbps, RS-232 Transmitters/Receivers
ICL3232E
HDMI
ISL54101
Single Channel TMDS Regenerator
Composite Video Amp
ISL59112
40MHz RAIL-TO-RAIL Video Buffer
ISL59111
8MHz Rail-to-Rail Composite Video Driver
ISL59110
EL5360
Low-Power, 200MHZ Current Feedback Amplifiers
EL8100
200MHz Rail-to-Rail Amplifiers
EL8101
Component Video Amp
ISL59830
True Single Supply Video Driver
EL5367
1GHz Triple Current Feedback Amplifier
EL5306
350MHZ Fixed Gain Amplifiers with Enable
EL5300
200MHz Slew Enhanced VFA
EL5302
400MHZ Slew Enhanced VFA
EL5304
700MHz Slew Enhanced VFA
EL5362
500MHz Low Power Current Feedback Amplifiers with Enable
EL5364
600MHz Current Feedback Amplifiers with Enable
SYSTEM Power Management
ISL6442
2.5MHZ Dual, 1800 Out-of-Phase, Step-Down PWM and Single LINEAR Controller
ISL88550A
Synchronous Step Down Controller with Sourcing and Sinking LDO REGULATOR
ISL6420A
PWM Controller with Wide VIN, Start-Up into Pre-Bias Load
ISL6443
300kHz Dual, 1800 Out-of-Phase, Step-Down PWM and Single Linear Controller
ISL6441
1.4MHz Dual, 1800 Out-of-Phase, Step-Down PWM and Single Linear Controller
ISL6549
Single 12V Input Supply Dual Regulator - Synchronous Rectified Buck PWM and Linear Power Controller
ISL6420
ADVANCED Single Synchronous Buck Pulse-Width Modulation (PWM) Controller
ISL6534
Dual PWM with Linear
ISL6529A
Dual Regulator-Synchronous Rectified Buck PWM and Linear Power Controller
ISL6529
Dual Regulator Synchronous Rectified Buck PWM and Linear Power Controller
ISL6528
Dual Regulator - STANDARD Buck PWM and Linear Power Controller
MEMORY Power Management
ISL6535
Synchronous Buck Pulse-Width Modulator (PWM) Controller
ISL6548
ACPI Regulator/Controller for Dual Channel DDR Memory Systems
ISL6539
Wide Input Range Dual PWM Controller with DDR Option
ISL6534
ISL6537
ISL6531
Dual 5V Synchronous Buck Pulse-Width Modulator (PWM) Controller for DDRAM Memory VDDQ and VTT Termination
ISL6530
Dual 5V Synchronous Buck Pulse-Width Modulator (PWM) Controller for DDRAM Memory VDDQ and VTTTermination
ISL6545
5V or 12V VIN Single Synchronous PWM Buck Controller
WLAN Power Management
ISL6455
0.6A PWM Regulator and Dual 0.3A LDOs and Reset
ISL6455A
ISL6416
Triple OUTPUT, Low-Noise LDO Regulator with Integrated Reset CIRCUIT
ISL6410
Single Synchronous Buck Regulator with Integrated FET for WLAN Chipsets
ISL6410A
ISL6412
Triple Output, Low-Noise LDO Regulator with Integrated Reset Circuit
ISL6413
Triple Output Regulator with Single Synchronous Buck and Dual LDO
uP/Voltage Supervisor
ISL88021
Triple Voltage MONITOR with Adjustable Power-On Reset and Undervoltage/Overvoltage Monitoring Capability
ISL88022
Triple Voltage Monitor with Adjustable Power-On Reset and Undervoltage/Overvoltage Monitoring Capability
ISL88031
Quintuple Voltage Monitor
ISL88041
Quad Voltage Monitor with Enable Feature
