一、 综合词汇1、 印制电路:printed circuit2、 印制线路:printed wiring3、 印制板:printed board4、 印制板电路:printed circuit board (PCB)5、 印制线路板:printed wiring board(PWB)6、 印制元件:printed component7、 印制接点:printed contact8、 印制板装配:printed board assembly9、 板:board10、 单面印制板:single-sided printed board(SSB)11、 双面印制板:double-sided printed board(DSB)12、 多层印制板:mulitlayer printed board(MLB)13、 多层印制电路板:mulitlayer printed circuit board14、 多层印制线路板:mulitlayer prited wiring board15、 刚性印制板:rigid printed board16、 刚性单面印制板:rigid single-sided printed borad17、 刚性双面印制板:rigid double-sided printed borad18、 刚性多层印制板:rigid multilayer printed board19、 挠性多层印制板:flexible multilayer printed board20、 挠性印制板:flexible printed board21、 挠性单面印制板:flexible single-sided printed board22、 挠性双面印制板:flexible double-sided printed board23、 挠性印制电路:flexible printed circuit (FPC)24、 挠性印制线路:flexible printed wiring25、 刚性印制板:flex-rigid printed board, rigid-flex printed board26、 刚性双面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed27、 刚性多层印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board28、 齐平印制板:flush printed board29、 金属芯印制板:metal core printed board30、 金属基印制板:metal base printed board31、 多重布线印制板:mulit-wiring printed board32、 陶瓷印制板:ceramic substrate printed board33、 导电胶印制板:electroconductive paste printed board34、 模塑电路板:molded circuit board35、 模压印制板:stamped printed wiring board36、 顺序层压多层印制板:sequentially-laminated mulitlayer37、 散线印制板:discrete wiring board38、 微线印制板:micro wire board39、 积层印制板:buile-up printed board40、 积层多层印制板:build-up mulitlayer printed board (BUM)41、 积层挠印制板:build-up flexible printed board42、 表面层合电路板:surface laminar circuit (SLC)43、 埋入凸块连印制板:B2it printed board44、 多层膜基板:multi-layered film substrate(MFS)45、 层间全内导通多层印制板:ALIVH multilayer printed board46、 载芯片板:chip on board (COB)47、 埋电阻板:buried resistance board48、 母板:mother board49、 子板:daughter board50、 背板:backplane51、 裸板:bare board52、 键盘板夹心板:copper-invar-copper board53、 动态挠性板:dynamic flex board54、 静态挠性板:static flex board55、 可断拼板:break-away planel56、 电缆:cable57、 挠性扁平电缆:flexible flat cable (FFC)58、 薄膜开关:membrane switch59、 混合电路:hybrid circuit60、 厚膜:thick film61、 厚膜电路:thick film circuit62、 薄膜:thin film63、 薄膜混合电路:thin film hybrid circuit64、 互连:interconnection65、 导线:conductor trace line66、 齐平导线:flush conductor67、 传输线:transmission line68、 跨交:crossover69、 板边插头:edge-board contact70、 增强板:stiffener71、 基底:substrate72、 基板面:real estate73、 导线面:conductor side 74、 元件面:component side75、 焊接面:solder side76、 印制:printing77、 网格:grid78、 图形:pattern79、 导电图形:conductive pattern80、 非导电图形:non-conductive pattern81、 字符:legend82、 标志:mark
