程序要写出自己的风格
** 这是学习 msp430g2553 单片机时写的 1602 的程序 **
** 时间精确到us,基本不出乱码 **
** P1为数据输出端口 **
** rs 接
p2.1 **
** rw
接地 **
** en 接
p2.0 **
#include
#include
#define rs_0 P2OUT&=~BIT1
#define rs_1 P2OUT|=BIT1
#define en_0 P2OUT&=~BIT0
#define en_1 P2OUT|=BIT0
char
table_1[]={"SHOU BU NIAO L !"};
char
table_2[]={"2012.8.02"};
unsigned int num;
unsigned int con_1,con_2;
void LCD1602_write_command(unsigned int com)
rs_0;
P1OUT=com;
__delay_cycles(500);
en_1;
en_0;
void LCD1602_write_data(unsigned int dat)
rs_1;
P1OUT=dat;
en_1;
en_0;
void LCD1602_init()
LCD1602_write_command(0x38); //5*7点阵,双行显示
LCD1602_write_command(0x0c); //0x0f 有光标,
LCD1602_write_command(0x01); //清屏
LCD1602_write_command(0x06); //写入数据后,光标右移,显示屏不动
LCD1602_write_command(0x80);
void main ()
con_1=strlen(table_1);
con_2=strlen(table_2);
WDTCTL=WDTPW+WDTHOLD;
P1DIR =0XFF;
P2DIR=0XFF;
LCD1602_init();
for(num=0;num
LCD1602_write_data(table_1[num]);
__delay_cycles(1000);
LCD1602_write_command(0x80+0x40);
for(num=0;num
LCD1602_write_data(table_2[num]);
while(1);
