#ifndef _I2C_H
#define _I2C_H
#define SDA_1 P4OUT|=0x02 //SDA = 1
#define SDA_0 P4OUT&=~0x02 //SDA = 0
#define SCL_1 P4OUT|=0x01 //SCL = 1
#define SCL_0 P4OUT&=~0x01 //SCL = 0
#define SDA_IN P4DIR&=~0x02; //I/O口为输入
#define SDA_OUT P4DIR|=0x02 //I/0口为输出
#define J_SDA_1_or_0 (P4IN&0x02)==0x02
//--------以下为24C64读写子函数
//DELAY 函数程序//功能:延时子程序
statIC void Delay(unsigned int n)
while(n!=0)
{n--;}
//START 函数程序
//功能:开始闪存操作
void Start(void)
SDA_OUT;
SDA_1;
Delay(10);
SCL_1;
Delay(10);
SDA_0;
Delay(10);
SCL_0;
Delay(10);
//STOP 函数程序
//功能:停止闪存操作
void Stop(void)
SDA_0;
Delay(10);
SCL_1;
Delay(10);
SDA_1;
Delay(10);
void TX_Byte(unsigned char WritEDAta)
unsigned char i,j;
j=WriteData;
SDA_OUT;
for (i=0; i<8; i++)
if ((j&0x80)==0)
{ SDA_0;}
else
{ SDA_1;}
j <<=1;
Delay(10);
SCL_1;
Delay(10);
SCL_0;
Delay(10);
unsigned char RX_Byte(void)
unsigned char i;
unsigned char TempData = 0;
SDA_IN;
for (i=0; i<8; i++)
Delay(10);
SCL_1;
Delay(10);
TempData <<= 1;
if (J_SDA_1_or_0)
{ TempData++; }
SCL_0;
Delay(10);
SDA_OUT;
return(TempData);
//ACK 函数程序
//功能:挂高电平表示闪存时钟信号
void ReceiveAck(void)
SDA_IN;
SCL_1;
Delay(10);
while (J_SDA_1_or_0)
SCL_0;
SDA_OUT;
Delay(10);
unsigned char ReadWord(unsigned long int unit/*address*/)
unsigned char LowAdd = 0;
unsigned char HighAdd = 0;
LowAdd = (unsigned char)unit;
HighAdd = (unsigned char)(unit >> 8);
SDA_OUT;
Start();
TX_Byte(0xa0);
ReceiveAck();
TX_Byte(HighAdd);
ReceiveAck();
TX_Byte(LowAdd);
ReceiveAck();
Start();
TX_Byte(0xa1);
ReceiveAck();
TempData = RX_Byte();
Stop();
Delay(8000);
return(TempData);
void WriteWord(unsigned long int unit/*address*/, unsigned char WriteData)
Start();
TX_Byte(0xa0);
ReceiveAck();
TX_Byte(HighAdd);
ReceiveAck();
TX_Byte(LowAdd);
ReceiveAck();
TX_Byte(WriteData);
ReceiveAck();
Stop();
Delay(8000);
#endif
