嵌入式 > 技术百科 > 详情
MSP430按键中断Ⅱ
发布时间:2024-12-03 发布时间:
#include
typedef unsigned char uchar;
typedef unsigned int uint;
#define keyin (P1IN & 0X0F)
#define wei_h P5OUT |= BIT5
#define wei_l P5OUT &= BIT5
#define duan_l P6OUT &= ~BIT6
#define duan_h P6OUT |= BIT6
uchar table[16] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
//uchar num = 0;
  uint keyval=0;
void delay(int z)
  int i,j;
  for(i=z;i>0;i--)
    for(j=112;j>0;j--);
void display(uchar dat)
  P4OUT = table[dat];
  duan_h;
  duan_l;
  P4OUT = 0x00;
  wei_h;
  wei_l;
void main( void )
//  uint temp,keyval;
  P1IES = 0X0F;         //下降沿触发
  P1IE = 0X0F;
  P1DIR = 0XF0;
  P1OUT = 0X00;
//  P1DIR = 0XFF;P1OUT = 0XFF;
  P4DIR = 0XFF;P4OUT = 0X00;
  P5DIR = 0XFF;P5OUT = 0XF7;
  P6DIR = 0XFF;
  _EINT();
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  while(1)
    LPM1;
#pragma vector = PORT1_VECTOR
__interrupt void PORT1_ISR(void)
  if(P1IFG & 0X0F)
    switch(P1IFG)
    case 0x01:
      if(keyin == 0x0e)
        delay(20);
        if(keyin == 0x0e)
          while(keyin != 0x0f)
            keyval = 1;
          display(keyval);
          P1IFG = 0;            //必须软件清除
          return;
    case 0x02:
      if(keyin == 0x0d)
        delay(20);
        if(keyin == 0x0d)
            keyval = 1;
          display(keyval);
          P1IFG = 0;            //必须软件清除
          return;
    case 0x03:
      if(keyin == 0x0b)
        delay(20);
        if(keyin == 0x0b)
            keyval = 1;
          display(keyval);
          P1IFG = 0;            //必须软件清除
          return;
    case 0x04:
      if(keyin == 0x07)
        delay(20);
        if(keyin == 0x07)
            keyval = 1;
          display(keyval);
          P1IFG = 0;            //必须软件清除
          return;
浅谈IP技术在网络电视中的应用
