#include
#define uchar unsigned char
#define uint unsigned int
#include "qqp.H"
#include "ascii hex(8x16).h"
#include "GB2312.h"
uint color[]={0xf800,0x07e0,0x001f,0xffe0,0x0000,0xffff,0x07ff,0xf81f};
void delay_us(uint t);
#define LCD_CONTROL_PORT P5OUT
#define LCD_CONTROL_DIR_PORT P5DIR
#define LCD_RST 0x01
#define LCD_RD 0x02
#define LCD_RS 0x04
#define LCD_CS 0x08
#define LCD_WR 0x10
void LCD_WR_REG(uchar index);
void LCD_WR_DA
void LCD_WR_CMD(uchar index,uint val);
unsigned int LCD_RD_REG16(uchar index);
void LCD_WR_Da
void LCD_Init();
void LCD_test();
void LCD_QQ();
void LCD_clear(uint p);
void DisplayChar(uchar casc,uchar postion_x,uchar postion_y);
void DisplayGB2312(uchar gb,uchar postion_x,uchar postion_y);
void DisplayString(uchar *s,uchar x,uchar y);//英文字符串显示.
t+=170;
while(--t);
void delay_ms(uint t)
uchar i,j;
while(--t)
j=5;
while(--j)
while(--i);
void SET_LCD_CONTROL_PORT()
LCD_CONTROL_DIR_PORT&=0X1F;
void SET_LCD_RST_HIGH(){LCD_CONTROL_PORT|=LCD_RST; };
void SET_LCD_RST_LOW() {LCD_CONTROL_PORT&=~LCD_RST;};
void SET_LCD_RD_HIGH(){LCD_CONTROL_PORT|=LCD_RST;};
void SET_LCD_RD_LOW() {LCD_CONTROL_PORT&=~LCD_RD;};
void SET_LCD_RS_HIGH(){LCD_CONTROL_PORT|=LCD_RS; };
void SET_LCD_RS_LOW() {LCD_CONTROL_PORT&=~LCD_RS;};
void SET_LCD_CS_HIGH(){LCD_CONTROL_PORT|=LCD_CS; };
void SET_LCD_CS_LOW() {LCD_CONTROL_PORT&=~LCD_CS;};
void SET_LCD_WR_HIGH(){LCD_CONTROL_PORT|=LCD_WR; };
void SET_LCD_WR_LOW() {LCD_CONTROL_PORT&=~LCD_WR;};
void SET_LCD_DA
P4DIR&=0XFF;
P4OUT|=lcd_da
unsigned int GET_LCD_DA
unsigned int lcd_da
P4DIR|=0X00;
lcd_da
return(lcd_da
SET_LCD_RS_LOW();
SET_LCD_CS_LOW ( );
// DA
SET_LCD_DA
SET_LCD_WR_LOW();
SET_LCD_WR_HIGH();
SET_LCD_CS_HIGH();
SET_LCD_RS_LOW();
void LCD_WR_DA
SET_LCD_RS_HIGH();
SET_LCD_CS_LOW();
// DA
SET_LCD_DA
SET_LCD_WR_LOW();
SET_LCD_WR_HIGH();
SET_LCD_CS_HIGH();
SET_LCD_RS_LOW();
SET_LCD_RS_LOW();
SET_LCD_CS_LOW();
//DA
SET_LCD_DA
SET_LCD_WR_LOW();
SET_LCD_WR_HIGH();
SET_LCD_CS_HIGH();
SET_LCD_RS_LOW();
SET_LCD_RS_HIGH();
SET_LCD_CS_LOW();
// DA
SET_LCD_DA
SET_LCD_WR_LOW();
SET_LCD_WR_HIGH();
SET_LCD_CS_HIGH();
SET_LCD_RS_LOW();
SET_LCD_RS_HIGH();
SET_LCD_CS_LOW();
// DA
SET_LCD_DA
SET_LCD_WR_LOW();
SET_LCD_WR_HIGH();
SET_LCD_CS_HIGH();
SET_LCD_RS_LOW();
unsigned int pd,ppd;
SET_LCD_RS_LOW();
SET_LCD_CS_LOW();
_nop_();
_nop_();
SET_LCD_DA
_nop_();
_nop_();
SET_LCD_WR_LOW();
_nop_();
_nop_();
SET_LCD_WR_HIGH();
_nop_();
_nop_();
SET_LCD_RS_HIGH();
_nop_();
_nop_();
// DA
SET_LCD_DA
_nop_();
_nop_();
SET_LCD_RD_LOW();
_nop_();
_nop_();
SET_LCD_RD_HIGH();
pd=GET_LCD_DA
// pd = DA
pd = pd<<8;
_nop_();
_nop_();
// DA
SET_LCD_DA
SET_LCD_RD_LOW();
_nop_();
_nop_();
SET_LCD_RD_HIGH();
ppd=GET_LCD_DA
pd = pd + ppd;
SET_LCD_CS_HIGH();
SET_LCD_RS_LOW();
return pd;
void LCD_WR_Da
//SET_LCD_RS_HIGH();
//SET_LCD_CS_LOW();
// DA
SET_LCD_DA
SET_LCD_WR_LOW();
SET_LCD_WR_HIGH();
// DA
SET_LCD_DA
SET_LCD_WR_LOW();
SET_LCD_WR_HIGH();
//SET_LCD_CS_HIGH();
//SET_LCD_RS_LOW();
void LCD_Init()
SET_LCD_CONTROL_PORT();
// LCD_RST = 0;
SET_LCD_RST_LOW();
delay_ms(200);
// LCD_RST = 1;
SET_LCD_RST_HIGH();
delay_ms(200);
//initializing funciton 1
delay_us(10);
LCD_WR_CMD(0xA1,0x00);
LCD_WR_CMD(0xA0,0x00);
delay_us(10);
LCD_WR_CMD(0x70,0xC8); //Start osc
delay_ms(20);
//Power Setting
LCD_WR_CMD(0x72,0xA3);
LCD_WR_CMD(0x73,0x04);
LCD_WR_CMD(0x75,0x45);
LCD_WR_CMD(0x76,0x23);
LCD_WR_CMD(0x77,0x08);
LCD_WR_CMD(0x78,0x08);
LCD_WR_CMD(0x79,0x00);
LCD_WR_CMD(0x7F,0xF0);
LCD_WR_CMD(0x71,0x81);
delay_ms(2);
LCD_WR_CMD(0x0D,0x23);
//delay_us(10);
LCD_WR_CMD(0x11,0x00);
LCD_WR_CMD(0x12,0x00);
LCD_WR_CMD(0x21,0x37);
//delay_us(10);
LCD_WR_CMD(0x22,0x02);
//delay_us(10);
LCD_WR_CMD(0x23,0x24);
LCD_WR_CMD(0x24,0x13);
LCD_WR_CMD(0x25,0x0A);
LCD_WR_CMD(0x26,0x82);
LCD_WR_CMD(0x27,0x01);
LCD_WR_CMD(0x1E,0x25);
LCD_WR_CMD(0x1F,0x59);
//GAMMA Setting
LCD_WR_CMD(0x30,0x0777);
LCD_WR_CMD(0x31,0x0444);
LCD_WR_CMD(0x32,0x0555);
LCD_WR_CMD(0x33,0x0444);
LCD_WR_CMD(0x34,0x0333);
LCD_WR_CMD(0x35,0x0333);
LCD_WR_CMD(0x36,0x0333);
LCD_WR_CMD(0x37,0x0333);
LCD_WR_CMD(0x38,0x0444);
LCD_WR_CMD(0x39,0x0555);
LCD_WR_CMD(0x3A,0x0666);
LCD_WR_CMD(0x3B,0x0666);
LCD_WR_CMD(0x3C,0x0777);
LCD_WR_CMD(0x3D,0x0777);
LCD_WR_CMD(0x3E,0x0777);
LCD_WR_CMD(0x3F,0x0777);
LCD_WR_CMD(0x40,0x0777);
LCD_WR_CMD(0x41,0x0777);
LCD_WR_CMD(0x42,0x0777);
LCD_WR_CMD(0x43,0x0777);
LCD_WR_CMD(0x44,0x0777);
LCD_WR_CMD(0x45,0x0777);
LCD_WR_CMD(0x46,0x0777);
LCD_WR_CMD(0x47,0x0777);
LCD_WR_CMD(0x48,0x0777);
LCD_WR_CMD(0x49,0x0777);
LCD_WR_CMD(0x4A,0x0777);
LCD_WR_CMD(0x4B,0x0777);
LCD_WR_CMD(0x4C,0x0777);
LCD_WR_CMD(0x4D,0x0666);
LCD_WR_CMD(0x4E,0x0666);
LCD_WR_CMD(0x4F,0x0666);
LCD_WR_CMD(0x85,0x74); //在手机和MP4播视频时很重要.
LCD_WR_CMD(0x00,0x04);
LCD_WR_CMD(0x01,0x07);
//LCD display area setting
LCD_WR_CMD(0x02,0x00);
LCD_WR_CMD(0x03,0x0000);
LCD_WR_CMD(0x04,0xEF);
LCD_WR_CMD(0x05,0x013F);
LCD_WR_CMD(0x06,0x00);
LCD_WR_CMD(0x07,0x0000);
LCD_WR_CMD(0x08,0xEF);
LCD_WR_CMD(0x09,0x013F);
LCD_WR_CMD(0x0A,0x00);
LCD_WR_CMD(0x0B,0x00);
LCD_WR_CMD(0x0C,0x00);
LCD_WR_CMD(0x14,0x00);
LCD_WR_CMD(0x15,0x00);
LCD_WR_CMD(0x16,0x00);
LCD_WR_CMD(0x17,0x01FF);
LCD_WR_CMD(0x18,0x01FF);
LCD_WR_CMD(0x13,0x00);
LCD_WR_CMD(0x19,0x01FF);
LCD_WR_CMD(0x1B,0x01FF);
LCD_WR_CMD(0x1C,0x01FF);
LCD_WR_CMD(0x1A,0x01FF);
LCD_WR_CMD(0x1D,0x0E);
LCD_WR_CMD(0x10,0x06); //开显示.
LCD_WR_REG(0x0E);
delay_us(10);
void LCD_test()
uint temp,num,i;
uchar n;
LCD_WR_REG(0x0E);
SET_LCD_CS_LOW();
SET_LCD_RS_HIGH();
for(n=0;n<8;n++)
temp=color[n];
for(num=40*240;num>0;num--)
LCD_WR_Da
for(n=0;n<8;n++)
LCD_WR_REG(0x0E);
SET_LCD_CS_LOW();
SET_LCD_RS_HIGH();
temp=color[n];
for(i=0;i<240;i++)
for(num=0;num<320;num++)
LCD_WR_Da
SET_LCD_CS_HIGH();
void LCD_QQ()
uint temp,num;
const unsigned int *p;
uchar n,c,g;
//显示小QQ图标
for(g=0;g<8;g++)
for(c=0;c<6;c++)
LCD_WR_CMD(0x02,c*40);
LCD_WR_CMD(0x03,g*40);
LCD_WR_CMD(0x04,c*40+39);
LCD_WR_CMD(0x05,g*40+39);
LCD_WR_REG(0x0E);
SET_LCD_CS_LOW();
SET_LCD_RS_HIGH();
p = (uint*)gImage_qqp;
for(num=0;num<1600;num++) //
LCD_WR_Da
//delay_ms(100);
SET_LCD_CS_HIGH();
uint i,j;
LCD_WR_REG(0x0E);
SET_LCD_CS_LOW();
SET_LCD_RS_HIGH();
for(i=0;i<320;i++)
for(j=0;j<240;j++)
LCD_WR_Da
SET_LCD_CS_HIGH();
//8X16点阵的字符显示函数
//参数说明:
// casc:字符对应字模中的位置
// x:显示位置第几列,每行是240/8 ==30列
// y:显示位置第几行,整屏是320/16==20行
uchar cTemp;
uchar i,j,b;
const uchar *p;
LCD_WR_CMD(0x02,postion_x*8); //x start point
LCD_WR_CMD(0x03,postion_y*16); //y start point
LCD_WR_CMD(0x04,postion_x*8+7); //x end point
LCD_WR_CMD(0x05,postion_y*16+15); //y end point
LCD_WR_REG(0x0E);
SET_LCD_CS_LOW();
SET_LCD_RS_HIGH();
p=ascii;
p+=casc*16;
for(j=0;j<16;j++)
b=*(p+j);
for(i=0;i<8;i++)
if(b&0x80)
LCD_WR_Da
else
LCD_WR_Da
b=b<<1;
SET_LCD_CS_HIGH();
//16X16点阵的汉字显示函数
//参数说明:
// gb:汉字对应字模中的位置
// x:显示位置第几列
// y:显示位置第几行
uchar cTemp;
uchar i,j,b;
const uchar *p;
LCD_WR_CMD(0x02,postion_x*16); //x start point
LCD_WR_CMD(0x04,postion_x*16+15); //x end point
LCD_WR_REG(0x0E);
SET_LCD_CS_LOW();
SET_LCD_RS_HIGH();
p=(char*)GB2132;
p+=gb*32;
for(j=0;j<32;j++)
b=*(p+j);
for(i=0;i<8;i++)
if(b&0x80)
LCD_WR_Da
else
LCD_WR_Da
b=b<<1;
SET_LCD_CS_HIGH();
void DisplayString(uchar *s,uchar x,uchar y)//英文字符串显示.
while (*s)
DisplayChar(*s,x,y);
if(++x>=30)
x=0;
if(++y>=20)
y=0;
s++;
void main()
uchar x=0;
uchar y=0;
uchar i;
LCD_Init();
LCD_clear(0);
// delay_ms(1000);
// LCD_test();
// delay_ms(2000);
// LCD_clear(0);
// LCD_QQ();
// delay_ms(2000);
/* delay_ms(2000);
LCD_clear(0);
DisplayString("LTM024D250 testing!",0,0);
delay_ms(500);
LCD_clear(0);
for(i=2;i<8;i++)
DisplayGB2312(i-2,i*2,0);
DisplayString("2009",4,0);
DisplayString( "06",10,0);
DisplayString( "15",14,0);
DisplayString( "14",18,0);
DisplayString( "30",22,0);
DisplayString( "22",26,0);
for(i=0;i<128;i++)
DisplayChar(i,x,y);
if(++x>=30)
x=0;
if(++y>=20)
y=0;
while(1) ;
