GPIO_Mode_In_FL_No_IT 浮空输入无中断 GPIO_Mode_In_PU_No_IT 上拉输入无中断 GPIO_Mode_In_FL_IT 浮空输入有中断 GPIO_Mode_In_PU_IT 上拉输入有中断 GPIO_Mode_Out_OD_Low_Fast 开漏-输出低-高速 Output open-drain, low level, 10MHz GPIO_Mode_Out_PP_Low_Fast 推挽-输出低-高速 Output push-pull, low level, 10MHz GPIO_Mode_Out_OD_Low_Slow 开漏-输出低-低速 Output open-drain, low level, 2MHz GPIO_Mode_Out_PP_Low_Slow 推挽-输出低-低速 Output push-pull, low level, 2MHz GPIO_Mode_Out_OD_HiZ_Fast 开漏-输出高阻-高速 Output open-drain, high-impedance level, 10MHz GPIO_Mode_Out_PP_High_Fast 推挽-输出高-高速 Output push-pull, high level, 10MHz GPIO_Mode_Out_OD_HiZ_Slow 开漏-输出高阻-低速 Output open-drain, high-impedance level, 2MHz GPIO_Mode_Out_PP_High_Slow 推挽-输出高-低速 Output push-pull, high level, 2MHz
