CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);// 有些硬件会自动八分频 导致后面的计算出现错误
CLK_HSICmd(ENABLE); //打开内部的时钟函数
GPIO_Init(GPIOB, GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);
//TIM2_PWM_Init();
* TIM2 Frequency = TIM2 counter clock/(ARR + 1)
* 这里设置TIM2的计数频率为 24M/8/(2999+1)=1K 在这里计算频率
TIM2_TimeBaseInit(TIM2_PRESCALER_8, 999); //这里改变频率
* PWM1 Mode configuration: Channel1
* TIM2 Channel1 duty cycle = [TIM2_CCR1/(TIM2_ARR + 1)] * 100 = 50%
* TIM2 Channel2 duty cycle = [TIM2_CCR2/(TIM2_ARR + 1)] * 100 = 50%
/* 测试通道1 */
TIM2_OC2Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE, 499, TIM2_OCPOLARITY_HIGH);
TIM2_OC2PreloadConfig(ENABLE);
TIM2_Cmd(ENABLE);
BEEP_Init(BEEP_FREQUENCY_1KHZ);
BEEP_Cmd(ENABLE);
上面的频率可以直推蜂鸣器,功能更下面那两个BEEP函数是一样的 后面再试试用PWM做蜂鸣器不同的响法。
