说在前面:上一篇介绍了无线LED闪烁实现的OSAL部分,本篇介绍如何实现无线数据收发及数据处理:
上一篇是用SI跟着流程查看源码,我个人认为以架构的思维去了解代码能让人更清晰
::ZMain.c程序入口文件
这里chipcon_cstartup.s51是汇编的启动文件,ZMain.c相当于main文件,里面有main函数:
1 int main( void )
2 {
3 osal_int_disable( INTS_ALL );// Turn off interrupts 关中断
4 HAL_BOARD_INIT();// Initialization for board related stuff such as LEDs
5 zmain_vdd_check();// Make sure supply voltage is high enough to run 检查芯片是否上电正常
6 InitBoard( OB_COLD );// Initialize board I/O 初始化I/O,LED,Timer等
7 HalDriverInit();// Initialze HAL drivers 初始化硬件抽象层驱动模块
8 osal_nv_init( NULL );// Initialize NV System 初始化flash存储器
9 znpTestRF();// Initialize and check the ZNP RF Test Mode NV items.
10 ZMacInit();// Initialize the MAC 初始化MAC层
11 zmain_ext_addr();// Determine the extended address 确定IEEE64位地址
12
13 #if defined ZCL_KEY_ESTABLISH
14 zmain_cert_init();// Initialize the Certicom certificate information.
15 #endif
16
17 zgInit();// Initialize basic NV items 初始化非易失变量
18
19 #ifndef NONWK
20 afInit();// Since the AF isn't a task, call it's initialization routine
21 #endif
22
23 osal_init_system();// Initialize the operating system 初始化OS(重点介绍1)
24 osal_int_enable( INTS_ALL );// Allow interrupts 使能中断
25 InitBoard( OB_READY );// Final board initialization 最终板载初始化
26 zmain_dev_info();// Display information about this device 显示设备信息(这里有LCD屏幕)
27
28 #ifdef LCD_SUPPORTED/* Display the device info on the LCD 将信息显示在LCD上*/
29 zmain_lcd_init();
30 #endif
31
32 #ifdef WDT_IN_PM1
33 WatchDogEnable( WDTIMX );/* If WDT is used, this is a good place to enable it. */
34 #endif
35
36 osal_start_znp(); // No Return from here 执行操作系统(重点介绍2)
37
38 return 0; // Shouldn't get here.
39 } // main()
main主要是初始化,然后启动OS,进入大循环,根据任务优先级处理相应任务。
::OSAL_SampleApp.c任务数组及任务初始化文件
上篇讲到main函数核心有:
初始化最核心的是OSAL任务初始化:(这里的tasksArr是所有任务的索引,后文还会介绍)
1 /*********************************************************************
2 * GLOBAL VARIABLES
3 */
5 // The order in this table must be identical to the task initialization calls below in osalInitTask.
6 const pTaskEventHandlerFn tasksArr[] =
7 {
8 macEventLoop,
9 nwk_event_loop,
10 Hal_ProcessEvent,
11 #if defined( MT_TASK )
12 MT_ProcessEvent,
13 #endif
14 APS_event_loop,
15 #if defined ( ZIGBEE_FRAGMENTATION )
16 APSF_ProcessEvent,
17 #endif
18 ZDApp_event_loop,
19 #if defined ( ZIGBEE_FREQ_AGILITY ) || defined ( ZIGBEE_PANID_CONFLICT )
20 ZDNwkMgr_event_loop,
21 #endif
22 SampleApp_ProcessEvent
23 };
24
25 const uint8 tasksCnt = sizeof( tasksArr ) / sizeof( tasksArr[0] );
26 uint16 *tasksEvents;
27
28 /*********************************************************************
29 * FUNCTIONS
30 *********************************************************************/
31
32 /*********************************************************************
33 * @fn osalInitTasks
34 *
35 * @brief This function invokes the initialization function for each task.
36 *
37 * @param void
38 *
39 * @return none
40 */
41 void osalInitTasks( void )
42 {
43 uint8 taskID = 0;
44
45 // 分配内存,返回指向缓冲区的指针
46 tasksEvents = (uint16 *)osal_mem_alloc( sizeof( uint16 ) * tasksCnt);
47 // 设置所分配的内存空间单元值为0
48 osal_memset( tasksEvents, 0, (sizeof( uint16 ) * tasksCnt));
49
50 // 任务优先级由高向低依次排列,高优先级对应taskID 的值反而小
51 macTaskInit( taskID++ ); //macTaskInit(0) ,用户不需考虑
52 nwk_init( taskID++ ); //nwk_init(1),用户不需考虑
53 Hal_Init( taskID++ ); //Hal_Init(2) ,用户需考虑
54 #if defined( MT_TASK )
55 MT_TaskInit( taskID++ );
56 #endif
57 APS_Init( taskID++ ); //APS_Init(3) ,用户不需考虑
58 #if defined ( ZIGBEE_FRAGMENTATION )
59 APSF_Init( taskID++ );
60 #endif
61 ZDApp_Init( taskID++ ); //ZDApp_Init(4) ,用户需考虑
62 #if defined ( ZIGBEE_FREQ_AGILITY ) || defined ( ZIGBEE_PANID_CONFLICT )
63 ZDNwkMgr_Init( taskID++ );
64 #endif
65 //用户创建的任务
66 SampleApp_Init( taskID ); // SampleApp_Init _Init(5) ,用户需考虑
67 }
::SampApp.c文件APP任务实现文件
承接上面66行,SampleApp_Init( uint8 task_id )负责初始化本工程定制化任务无线LED闪烁相关的初始化工作:
上篇讲过OS启动后进入大循环,扫描当前优先级最高的任务执行!
其中若osal_run_task执行了本工程定制化任务的消息,通过调用tasksArr[idx](上面 OSAL_SampleApp.c中讲的任务数组)就相当于调用了SampleApp_ProcessEvent函数,将消息传送给任务处理函数:
1 //用户应用任务的事件处理函数
2 uint16 SampleApp_ProcessEvent( uint8 task_id, uint16 events )
3 {
4 afIncomingMSGPacket_t *MSGpkt;
5 (void)task_id; // Intentionally unreferenced parameter
7 if ( events & SYS_EVENT_MSG ) //接收系统消息再进行判断
8 {
9 //接收属于本应用任务SampleApp的消息,以SampleApp_TaskID标记
10 MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( SampleApp_TaskID );
11 while ( MSGpkt )
12 {
13 switch ( MSGpkt->hdr.event )
14 {
15 // Received when a key is pressed
16 case KEY_CHANGE://按键事件
17 SampleApp_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
18 break;
19
20 // Received when a messages is received (OTA) for this endpoint
21 case AF_INCOMING_MSG_CMD://接收数据事件,调用函数AF_DataRequest()接收数据
22 SampleApp_MessageMSGCB( MSGpkt );//调用回调函数对收到的数据进行处理(1、数据发送函数)
23 break;
24
25 // Received whenever the device changes state in the network
26 case ZDO_STATE_CHANGE:
27 //只要网络状态发生改变,就通过ZDO_STATE_CHANGE事件通知所有的任务。
28 //同时完成对协调器,路由器,终端的设置
29 SampleApp_NwkState = (devStates_t)(MSGpkt->hdr.status);
30 //if ( (SampleApp_NwkState == DEV_ZB_COORD)//实验中协调器只接收数据所以取消发送事件
31 if ( (SampleApp_NwkState == DEV_ROUTER) || (SampleApp_NwkState == DEV_END_DEVICE) )
32 {
33 // Start sending the periodic message in a regular interval.
34 //这个定时器只是为发送周期信息开启的,设备启动初始化后从这里开始
35 //触发第一个周期信息的发送,然后周而复始下去
36 osal_start_timerEx( SampleApp_TaskID,
37 SAMPLEAPP_SEND_PERIODIC_MSG_EVT,
38 SAMPLEAPP_SEND_PERIODIC_MSG_TIMEOUT );
39 }
40 else
41 {
42 // Device is no longer in the network
43 }
44 break;
45
46 default:
47 break;
48 }
49
50 // Release the memory 事件处理完了,释放消息占用的内存
51 osal_msg_deallocate( (uint8 *)MSGpkt );
52
53 // Next - if one is available 指针指向下一个放在缓冲区的待处理的事件,
54 //返回while ( MSGpkt )重新处理事件,直到缓冲区没有等待处理事件为止
55 MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( SampleApp_TaskID );
56 }
57
58 // return unprocessed events 返回未处理的事件
59 return (events ^ SYS_EVENT_MSG);
60 }
61
62 // Send a message out - This event is generated by a timer
63 // (setup in SampleApp_Init()).
64 if ( events & SAMPLEAPP_SEND_PERIODIC_MSG_EVT )
65 {
66 // Send the periodic message 处理周期性事件,
67 //利用SampleApp_SendPeriodicMessage()处理完当前的周期性事件,然后启动定时器
68 //开启下一个周期性事情,这样一种循环下去,也即是上面说的周期性事件了,
69 //可以做为传感器定时采集、上传任务
70 SampleApp_SendPeriodicMessage();
71
72 // Setup to send message again in normal period (+ a little jitter)
73 osal_start_timerEx( SampleApp_TaskID, SAMPLEAPP_SEND_PERIODIC_MSG_EVT,
74 (SAMPLEAPP_SEND_PERIODIC_MSG_TIMEOUT + (osal_rand() & 0x00FF)) );
75
76 // return unprocessed events 返回未处理的事件
77 return (events ^ SAMPLEAPP_SEND_PERIODIC_MSG_EVT);
78 }
79
80 // Discard unknown events
81 return 0;
82 }
接收函数:
1 //接收数据,参数为接收到的数据
2 void SampleApp_MessageMSGCB( afIncomingMSGPacket_t *pkt )
3 {
4 uint16 flashTime;
5 byte buf[3];
7 switch ( pkt->clusterId ) //判断簇ID
8 {
9 case SAMPLEAPP_PERIODIC_CLUSTERID: //收到广播数据
10 osal_memset(buf, 0 , 3);
11 osal_memcpy(buf, pkt->cmd.Data, 2); //复制数据到缓冲区中
12
13 if(buf[0] == 'D' && buf[1] == '1') //判断收到的数据是否为"D1"
14 {
15 HalLedBlink(HAL_LED_1, 0, 50, 500);//如果是则Led1间隔500ms闪烁
16 #if defined(ZDO_COORDINATOR) //协调器收到"D1"后,返回"D1"给终端,让终端Led1也闪烁
17 SampleApp_SendPeriodicMessage();
18 #endif
19 }
20 else
21 {
22 HalLedSet(HAL_LED_1, HAL_LED_MODE_ON);
23 }
24 break;
25
26 case SAMPLEAPP_FLASH_CLUSTERID: //收到组播数据
27 flashTime = BUILD_UINT16(pkt->cmd.Data[1], pkt->cmd.Data[2] );
28 HalLedBlink( HAL_LED_4, 4, 50, (flashTime / 4) );
29 break;
30 }
31 }
发送函数:
1 //分析发送周期信息
2 void SampleApp_SendPeriodicMessage( void )
3 {
4 byte SendData[3] = "D1";
6 // 调用AF_DataRequest将数据无线广播出去
7 if( AF_DataRequest( &SampleApp_Periodic_DstAddr,//发送目的地址+端点地址和传送模式
8 &SampleApp_epDesc,//源(答复或确认)终端的描述(比如操作系统中任务ID等)源EP
9 SAMPLEAPP_PERIODIC_CLUSTERID, //被Profile指定的有效的集群号
10 2, // 发送数据长度
11 SendData,// 发送数据缓冲区
12 &SampleApp_TransID, // 任务ID号
13 AF_DISCV_ROUTE, // 有效位掩码的发送选项
14 AF_DEFAULT_RADIUS ) == afStatus_SUCCESS ) //传送跳数,通常设置为AF_DEFAULT_RADIUS
15 {
16 }
17 else
18 {
19 HalLedSet(HAL_LED_1, HAL_LED_MODE_ON);
20 // Error occurred in request to send.
21 }
22 }
