#include
#include"ldc1314.h"
#include"lcd12864cog.h"
//#include"rtc.h"
#include
unsigned int Just_ch0,Just_ch1,Just_ch2,Just_ch3;
unsigned int Now_ch0,Now_ch1,Now_ch2,Now_ch3;
unsigned int PULSE_NUMBER = 0;
unsigned int beep=0;
int FIVE_DIV_TURNS_NUMBER = 0;//一圈的五分之一
float TURNS_NUMBER = 0;
float CIRCUM = 0.2041;//轮胎的周长,单位m
float ONE_PULSE_DISTANCE = 0.2041/390;
float RT_DISTANCE =0;//实时路程
unsigned int half_s=0;
int RTC_SEC=0;
#define BEEP_ON P7OUT|=BIT0;
#define BEEP_OFF P7OUT&=~BIT0;
#define BEEP_DIR P7DIR|=BIT0;
#define Right1 Just_ch0-Now_ch0
#define Right2 Just_ch3-Now_ch3
#define Left1 Just_ch1-Now_ch1
#define Left2 Just_ch2-Now_ch2
#define A_PWM_MOTOR TA0CCR3 //P1.4
#define B_PWM_MOTOR TA0CCR4 //P1.5
#define MOTOR_PWM_DUTY TA0CCR0 //周期长度
#define Normal_speed 3500
#define Turn_S_speed 3500
#define Turn_B_speed 2500
void initalRTC(void)
RTCCTL01 = RTCMODE + RTCBCD + RTCHOLD + RTCTEV_1;
RTCHOUR = 0x04;
RTCMIN = 0x30;
RTCSEC = 0x00;
RTCDAY = 0x01;
RTCMON = 0x01;
RTCYEAR = 0x2011;
RTCCTL01 &= ~RTCHOLD;//启动实时时钟
RTCPS1CTL = RT1IP_5 + RT1PSIE;
RTCPS0CTL = RT0IP_7 + RT0PSIE;
RTCCTL0 |= RTCRDYIE + RTCTEVIE;
void A_MOTOR(A_DIR,A_SPEED)//P1.4
if(A_DIR==1)//正转
P4OUT |= BIT1; P4OUT &= ~BIT2;
A_PWM_MOTOR = A_SPEED;
if(A_DIR==2)//反转
P4OUT |= BIT2; P4OUT &= ~BIT1;
if(A_DIR==3)
P4OUT |= BIT1+BIT2;
void B_MOTOR(B_DIR,B_SPEED)//P1.5
if(B_DIR==1)//正转
P4OUT |= BIT3; P3OUT &= ~BIT3;
B_PWM_MOTOR = B_SPEED;
if(B_DIR==2)//反转
P3OUT |= BIT3; P4OUT &= ~BIT3;
if(B_DIR==3)
P4OUT |= BIT3; P3OUT |= BIT3;
void CAR_WORK_MODE(Status,A_SPEED,B_SPEED)
if(Status==1)//前进
{ A_MOTOR(1,A_SPEED); B_MOTOR(1,B_SPEED); }
if(Status==2)//后退
{ A_MOTOR(2,A_SPEED); B_MOTOR(2,B_SPEED); }
if(Status==3)//左转
{ A_MOTOR(1,A_SPEED); B_MOTOR(3,B_SPEED); }
if(Status==4)//右转
{ A_MOTOR(3,A_SPEED); B_MOTOR(1,B_SPEED); }
if(Status==5)//停止
{ A_MOTOR(3,A_SPEED); B_MOTOR(3,B_SPEED); }
void L298N_IN14_INIT()
P4DIR|=BIT1+BIT2+BIT3; P3DIR|=BIT3;
P4OUT|=BIT1+BIT2+BIT3; P3OUT|=BIT3;
void MOTOR_PWM_SET(unsigned int PWM_DUTY)
TA0CCTL2 = CM_1 + SCS + CAP + CCIE;// 上升沿捕获,同步捕获,捕获模式,中断使能
P1DIR&=~BIT3;
P1SEL|=BIT3;//上升沿输入捕获引脚
P1DIR |= BIT4+BIT5;
P1SEL |= BIT4+BIT5;//电机PWM输出引脚
MOTOR_PWM_DUTY = PWM_DUTY;
TA0CCTL3 = OUTMOD_7;
TA0CCTL4 = OUTMOD_7;
TA0CTL = TASSEL_2 + MC_1 + TACLR;//增计数计数模式
void MOTOR_ENABLE()
P2DIR|=BIT7;
P2OUT|=BIT7;//电机驱动使能
void LCD_PORT_CONFIGRE()
cs_DIR; //宏定义在LCD头文件
cd_DIR;
reset_DIR;
sclk_DIR;
sda_DIR;
void LDC1314_FIRST_DATA()
LDC1314_INIT();
_delay_cycles(4000000);//上电延时待ldc1314初始化稳定第一次读值
LDC1314_Read();
Just_ch0 = SENSOR_CH[0];
Just_ch1 = SENSOR_CH[1];
Just_ch2 = SENSOR_CH[2];
Just_ch3 = SENSOR_CH[3];
void TIMER_INIT(unsigned int TIME)//定时时间 = TIME/32768
P4DIR|=BIT7;//定时时间显示,通过LED亮灭
TA1CCTL0 = CCIE;
TA1CCR0 = TIME;
TA1CTL = TASSEL_1 + MC_1 + TACLR;
void FIXED_DISAPPER()
display_string_8x16(1,70,"SES:");//时间分隔符
display_string_8x16(5,70,"DST:");//时间分隔符
int main(void)
WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
MOTOR_PWM_SET(10000);//10KHz的周期
L298N_IN14_INIT();
TIMER_INIT(1000);//定时时间 = TIME/32768
LDC1314_FIRST_DATA();
MOTOR_ENABLE();
BEEP_DIR;
BEEP_OFF;
LCD_PORT_CONFIGRE();
LCD_init();
delay(50);
clear_screen(); //上电清屏
FIXED_DISAPPER();
initalRTC();
__bis_SR_register(GIE);//总中断打开
while(1)
if((Now_ch0>180)||(Now_ch1>180)||(Now_ch2>180)||(Now_ch3>180))
beep=1;
if((Now_ch0<170)&&(Now_ch1<170)&&(Now_ch2<170)&&(Now_ch3<170))
beep=2;
switch(beep)
case 1: BEEP_ON;break;
case 2: BEEP_OFF;break;
default :break;
if((Right1==0)&&(Left1==0 )&&( Right2==0)&&(Left2==0))
CAR_WORK_MODE(1,Normal_speed,Normal_speed);
//内侧通道-小弯道转弯模式
if(((Left1==1)||(Right1==1))&&(Left2==0)&&(Right2==0))
while((Left1==1)&&(Right1==0)&&(Left2==0)&&(Right2==0))
CAR_WORK_MODE(4,Turn_S_speed ,Turn_S_speed);
while((Right1==1)&&(Left1==0)&&(Left2==0)&&(Right2==0))
CAR_WORK_MODE(3,Turn_S_speed ,Turn_S_speed);
//外侧通道-大弯道转弯模式
if((Left2==1)||(Right2==1)&&(Left1==0)&&(Right1==0))
while((Left2==1)&&(Right2==0)&&(Left1==0)&&(Right1==0))
CAR_WORK_MODE(4,Turn_B_speed,Turn_B_speed);
while(Right1==0)
;//等待转弯完成
while((Right2==1)&&(Left2==0)&&(Left1==0)&&(Right1==0))
CAR_WORK_MODE(3,Turn_B_speed,Turn_B_speed);
while(Left1==0)
;//等待转弯完成
//同侧线圈同时检测到时:
if(((Right1==1)&&(Right2==1))||((Left1==1)&&(Left2==1)))
while((Right1==0)&&(Right2==0))
while((Left1==0)&&(Left2==0))
#pragma vector=TIMER1_A0_VECTOR
__interrupt void TIMER1_A0_ISR(void)
P4OUT^=BIT7;//定时指示
_delay_cycles(50);
LDC1314_Read();
Now_ch0 = SENSOR_CH[0]; //读取
Now_ch1 = SENSOR_CH[1]; //右侧通道
Now_ch2 = SENSOR_CH[2]; //右侧通道
Now_ch3 = SENSOR_CH[3]; //读取
#pragma vector=TIMER0_A1_VECTOR
__interrupt void TIMER0_A1_ISR(void)
PULSE_NUMBER++;
if(PULSE_NUMBER==195)//1/5圈 整圈390
PULSE_NUMBER = 0;//清零,重新计数
//FIVE_DIV_TURNS_NUMBER++;
TURNS_NUMBER++;
//实时显示行驶路程:
RT_DISTANCE = TURNS_NUMBER*CIRCUM;
display_number_8x16(5,100,RT_DISTANCE,1);//实时路程,两位有效小数
TA0CCTL2 &=~CCIFG;//清除中断标志位
#pragma vector=RTC_VECTOR
__interrupt void RTC_ISR(void)
switch (__even_in_range(RTCIV, RTC_RT1PSIFG))
case RTC_NONE:
break;
case RTC_RTCRDYIFG:
// __bic_SR_register_on_exit(LPM3_bits);
break;
case RTC_RTCTEVIFG:
break;
case RTC_RTCAIFG:
break;
case RTC_RT0PSIFG:
// P4OUT ^= BIT7;
break;
case RTC_RT1PSIFG:
// P1OUT ^= BIT0; //产生0.5s的信号,通过加倍产生1s的信号
half_s++;
while(half_s==2)
half_s=0;
RTC_SEC++;
// while(RTC_SEC>delay_time)//RTC模块放在读值之前,需减去读值延时的时间
display_number_8x16(1,100,RTC_SEC,-1);
display_number_8x16(1,10,Now_ch0,-1);
break;
default:
break;
