嵌入式 > 技术百科 > 详情
CRC16校验程序
发布时间:2025-09-19 发布时间:
//CRC16校验在通讯中应用广泛,这里不对其理论进行讨论,只对常见的3种
//实现方法进行测试。方法1选用了一种常见的查表方法,类似的还有512字
//节、256字等查找表的,至于查找表的生成,这里也略过。
// ---------------- POPULAR POLYNOMIALS ----------------
//  CCITT:      x^16 + x^12 + x^5 + x^0                 (0x1021)
//  CRC-16:     x^16 + x^15 + x^2 + x^0                 (0x8005)
#define         CRC_16_POLYNOMIALS      0x8005
//      CRC16计算方法1:使用2个256长度的校验表
const BYTE chCRCHTalbe[] =                                 // CRC 高位字节值表
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
const BYTE chCRCLTalbe[] =                                 // CRC 低位字节值表
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7,
0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E,
0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09, 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9,
0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC,
0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32,
0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D,
0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A, 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38,
0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF,
0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1,
0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4,
0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F, 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB,
0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA,
0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0,
0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97,
0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C, 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E,
0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89,
0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83,
0x41, 0x81, 0x80, 0x40
WORD CRC16_1(BYTE* pchMsg, WORD wDataLen)
        BYTE chCRCHi = 0xFF; // 高CRC字节初始化
        BYTE chCRCLo = 0xFF; // 低CRC字节初始化
        WORD wIndex;            // CRC循环中的索引
        while (wDataLen--)
                // 计算CRC
                wIndex = chCRCLo ^ *pchMsg++ ;
                chCRCLo = chCRCHi ^ chCRCHTalbe[wIndex];
                chCRCHi = chCRCLTalbe[wIndex] ;
        return ((chCRCHi << 8) | chCRCLo) ;
//      CRC16计算方法2:使用简单的校验表
const WORD wCRCTalbeAbs[] =
0x0000, 0xCC01, 0xD801, 0x1400, 0xF001, 0x3C00, 0x2800, 0xE401, 0xA001, 0x6C00, 0x7800, 0xB401, 0x5000,
0x9C01, 0x8801, 0x4400,
WORD CRC16_2(BYTE* pchMsg, WORD wDataLen)
        WORD wCRC = 0xFFFF;
        WORD i;
        BYTE chChar;
        for (i = 0; i < wDataLen; i++)
                chChar = *pchMsg++;
                wCRC = wCRCTalbeAbs[(chChar ^ wCRC) & 15] ^ (wCRC >> 4);
                wCRC = wCRCTalbeAbs[((chChar >> 4) ^ wCRC) & 15] ^ (wCRC >> 4);
        return wCRC;
//      CRC16计算方法3:使用直接结算的方法
WORD CRC16_3(BYTE* pchMsg, WORD wDataLen)
        BYTE i, chChar;
        WORD wCRC = 0xFFFF;
        while (wDataLen--)
                chChar = *pchMsg++;
                chChar = ByteInvert(chChar);
                wCRC ^= (((WORD) chChar) << 8);
                for (i = 0; i < 8; i++)
                        if (wCRC & 0x8000)
                                wCRC = (wCRC << 1) ^ CRC_16_POLYNOMIALS;
                        else
                                wCRC <<= 1;
        wCRC = WordInvert(wCRC);
        return wCRC;
//试验数据:
//      采用Metrowerks CodeWarrior在DSP56F80x平台上,对这3种方法
//进行了性能测试。
//                      代码大小(字)    额外存储空间(字)        执行时间(周期数)
//      方法1           32                      512                             540
//      方法2           57                      16                              1120
//      方法3           142*                    0                               4598
//说明:方法3的代码大小还包括字反转、字节反转程序(这里没有给出源码)
//结论:通常在存储空间没有限制的情况下,采用方法1是最好的,毕竟在
//通讯中,保障通讯速度是至关重要的。而方法2也不失为一种很好的方法,
//占用空间很少。而与方法2相比,方法3似乎不占有什么优势。
浅谈IP技术在网络电视中的应用
