嵌入式 > 技术百科 > 详情
MSP430F149模拟IIC读写24C02程序
发布时间:2025-05-23 发布时间:
板子上设置了EEPROM存储器,型号为AT24C02。
板子的硬件连接为:SCL--->P2.4,SDA--->P2.5。
直接了当,贴上程序!
复制代码
========================24cxx.h文件=========================#ifndef _24CXX_H_#define _24CXX_H_#include #define WRITE_ADDR  0xA0  //A0 A1 A2均接地#define READ_ADDR   0xA1  //A0 A1 A2均接地#define SDA_BIT   BIT5#define SCL_BIT   BIT4#define IIC_PORT_DIR P2DIR#define IIC_PORT_DATA P2OUT#define SDA_BIT_DATA  (P2IN & BIT5)#define SDA_OUT  (IIC_PORT_DIR |= SDA_BIT)#define SDA_IN    (IIC_PORT_DIR &= ~SDA_BIT)#define SDA_1     (IIC_PORT_DATA |= SDA_BIT)#define SDA_0     (IIC_PORT_DATA &= ~SDA_BIT)#define SCL_IN    (IIC_PORT_DIR &= ~SCL_BIT)#define SCL_OUT  (IIC_PORT_DIR |= SCL_BIT)#define SCL_1     (IIC_PORT_DATA |= SCL_BIT)#define SCL_0     (IIC_PORT_DATA &= ~SCL_BIT)void init_iic(void);void iic_start(void);void iic_stop(void);void iic_ack(void);void iic_no_ack(void);
unsigned char iic_test_ack(void);void iic_write(unsigned char data);
unsigned char iic_read(void);
unsigned char iic_write_data(unsigned char StartAddress,unsigned char *date,unsigned char bytes);
unsigned char iic_read_data(unsigned char StartAddress,unsigned char *date,unsigned char bytes);#endif
复制代码
复制代码
========================24cxx.c文件=========================#include "24cxx.h" #include "main.h"    //实际上需要包含延时#define CPU_F ((double)8000000)
                    //#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))                    //#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))/**IIC端口初始化*/void init_iic(void)
    SCL_OUT;    //SCL管脚为输出
    SDA_IN;        //SDA管脚为输入    SCL_0;
    iic_stop();
}/**IIC起始状态*/void iic_start(void)
    SDA_OUT;
    SDA_1;
    delay_us(5);
    SCL_1;
    delay_us(5);
    SDA_0;
    delay_us(5);
    SCL_0;
    delay_us(5);
}/**IIC停止状态*/void iic_stop(void)
    SDA_OUT;
    SCL_0;
    delay_us(5);
    SDA_0;
    delay_us(5);
    SCL_1;
    delay_us(5);
    SDA_1;
    delay_us(5);
}/**IIC应答*/void iic_ack(void)
    SDA_OUT;
    SDA_0;
    delay_us(5);
    SCL_1;
    delay_us(5);
    SCL_0;
    delay_us(5);
    SDA_1;
}/**IIC无应答*/void iic_no_ack(void)
    SDA_OUT;
    SDA_1;
    delay_us(5);
    SCL_1;
    delay_us(5);
    SCL_0;
    delay_us(5);
}/**IIC检测回应*/unsigned char iic_test_ack(void )
    unsigned char tmp;
    SDA_IN;                //设为输入
    delay_us(5);
    SCL_1;
    delay_us(5);
    tmp = SDA_BIT_DATA>>4;
    delay_us(5);
    SCL_0;
    delay_us(5);    return(tmp);
}/**IIC写字节*/void iic_write(unsigned char data)
    SDA_OUT;
    unsigned char i,temp;    for(i=0; i<8; i++)
        SDA_OUT;
        temp = data&0x80;        if(temp == 0x80)
            SDA_1;            //判断发送位,送数据到数据线上
        else
            SDA_0;
        delay_us(10);
        SCL_1;                //置时钟信号为高电平,使数据有效
        delay_us(5);
        SCL_0;
        delay_us(10);
        data=data<<1;
    SDA_IN;
    delay_us(5);
}/**IIC读字节*/unsigned char iic_read(void)
    unsigned char i,tmp;
    unsigned char byte = 0;
    SDA_IN;                    //置数为输入
    for(i=0; i<8; i++)
        SCL_1;
        delay_us(5);        byte = byte<<1;
        SDA_IN;
        tmp = SDA_BIT_DATA;        if(tmp == SDA_BIT)            byte = (byte|0x01);
        delay_us(10);
        SCL_0;
        delay_us(10);
    }    return(byte);
}/**IIC写数据
*输入:start_addr起始地址
*  n_bytes写入字节数
*  dest_date写入的数据源
*输出:无*/unsigned char iic_write_data(unsigned char start_addr, unsigned char *dest_date, unsigned char n_bytes)
    unsigned char i=0;
    iic_start();                //启动IIC
    iic_write(WRITE_ADDR);        //写24C02地址以
    if(iic_test_ack() != 0)        //检测应答
     return 1;
    iic_write(start_addr);        //写对24C02操作的地址
    if(iic_test_ack() != 0)     return 1;    for(i=0; i
复制代码
测试结果采用串口输出方式,main包含下面的步骤。
复制代码
unsigned char iic_buf[4] = {0x11,0x22,0x33,0x44}, iic_rdbuf[4],ret = 0;
init_iic();
printf("24c02 iic init ok\r\n");
printf("write=0x%x 0x%x 0x%x 0x%x\r\n",iic_buf[0],iic_buf[1],iic_buf[2],iic_buf[3]);
ret = iic_write_data(200,iic_buf,4);
printf("write:%s\r\n", ret > 0 ? "err" : "ok");
ret = iic_read_data(200,iic_rdbuf,4);
printf("read:%s\r\n", ret > 0 ? "err" : "ok");
printf("read=0x%x 0x%x 0x%x 0x%x\r\n",iic_rdbuf[0],iic_rdbuf[1],iic_rdbuf[2],iic_rdbuf[3]);
/*页写函数,写入起始地址,数据,字节数*/unsigned char EepromPageWrite(EEPROM_ADDR_TYPE address, unsigned char *pdata, unsigned char num)
    unsigned char pagestart = 0;    //计算起始页
    unsigned char pageend = 0;        //计算结束页-1
    unsigned char pageloop = 0;        //页写总循环数
    unsigned char pagebyte;            //页剩余字节数寄存器
    unsigned int pagedelay = 0;
    pagestart = EEPROM_PAGE_CAL(address);    //at24c01,02
    pageend = EEPROM_PAGE_CAL(address+num-1);
    //页写
    for (pageloop = 0; pageloop <= (pageend-pagestart); pageloop++)
    {        //计算本次写入的字节数
        pagebyte = (address|(EEPROM_PAGE_SIZE-1)) - address + 1;        if (num <= pagebyte)
            pagebyte = num;
        num -= pagebyte; //剩余字节数
        I2cSendStart();        if (0 == I2cSendByte(EEPROM_WRITE))            return(0);
浅谈IP技术在网络电视中的应用
