简介:在IAR下开发不会自动生成stm8_interrupt_vector.c文件,但是在STVD下会产生该文件,并生成中断向量表 _vectab ,如果要使用stm8_it.c中的函数结构文件来处理中断函数则需要用以下代码替换生成的stm8_interrupt_vector.c。
/* BASIC INTERRUPT VECTORS TABLE FOR STM8 devices
* Copyright (c) 2011 STMicroelectronics
#include "stm8s_it.h"
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
u8 interrupt_instruction;
interrupt_handler_t interrupt_handler;
struct interrupt_vector const _vectab[] = {
{0x82, (interrupt_handler_t)_stext}, /* RESET */
{0x82, (interrupt_handler_t)TRAP_IRQHandler}, /* TRAP - Software interrupt */
{0x82, (interrupt_handler_t)TLI_IRQHandler}, /* irq0 - External Top Level interrupt (TLI) */
{0x82, (interrupt_handler_t)AWU_IRQHandler}, /* irq1 - Auto Wake Up from Halt interrupt */
{0x82, (interrupt_handler_t)CLK_IRQHandler}, /* irq2 - Clock Controller interrupt */
{0x82, (interrupt_handler_t)EXTI_PORTA_IRQHandler}, /* irq3 - External interrupt 0 (GPIOA) */
{0x82, (interrupt_handler_t)EXTI_PORTB_IRQHandler}, /* irq4 - External interrupt 1 (GPIOB) */
{0x82, (interrupt_handler_t)EXTI_PORTC_IRQHandler}, /* irq5 - External interrupt 2 (GPIOC) */
{0x82, (interrupt_handler_t)EXTI_PORTD_IRQHandler}, /* irq6 - External interrupt 3 (GPIOD) */
{0x82, (interrupt_handler_t)EXTI_PORTE_IRQHandler}, /* irq7 - External interrupt 4 (GPIOE) */
#if defined (STM8S208) || defined (STM8AF52Ax)
{0x82, (interrupt_handler_t)CAN_RX_IRQHandler}, /* irq8 - CAN Rx interrupt */
{0x82, (interrupt_handler_t)CAN_TX_IRQHandler}, /* irq9 - CAN Tx/ER/SC interrupt */
#elif defined (STM8S903)
{0x82, (interrupt_handler_t)EXTI_PORTF_IRQHandler}, /* irq8 - External interrupt 5 (GPIOF) */
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq9 - Reserved */
#else /*STM8S207, STM8S105 or STM8AF62Ax or STM8AF626x*/
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq8 - Reserved */
#endif /* STM8S208 or STM8AF52Ax */
{0x82, (interrupt_handler_t)SPI_IRQHandler}, /* irq10 - SPI End of transfer interrupt */
{0x82, (interrupt_handler_t)TIM1_UPD_OVF_TRG_BRK_IRQHandler}, /* irq11 - TIM1 Update/Overflow/Trigger/Break interrupt */
{0x82, (interrupt_handler_t)TIM1_CAP_COM_IRQHandler}, /* irq12 - TIM1 Capture/Compare interrupt */
#ifdef STM8S903
{0x82, (interrupt_handler_t)TIM5_UPD_OVF_BRK_TRG_IRQHandler}, /* irq13 - TIM5 Update/Overflow/Break/Trigger interrupt */
{0x82, (interrupt_handler_t)TIM5_CAP_COM_IRQHandler}, /* irq14 - TIM5 Capture/Compare interrupt */
#else /*STM8S208, STM8S207, STM8S105 or STM8S103 or STM8AF62Ax or STM8AF52Ax or STM8AF626x*/
{0x82, (interrupt_handler_t)TIM2_UPD_OVF_BRK_IRQHandler}, /* irq13 - TIM2 Update/Overflow/Break interrupt */
{0x82, (interrupt_handler_t)TIM2_CAP_COM_IRQHandler}, /* irq14 - TIM2 Capture/Compare interrupt */
#endif /*STM8S903*/
#if defined (STM8S208) || defined(STM8S207) || defined(STM8S007) || defined(STM8S105) || \
defined(STM8S005) || defined(STM8AF52Ax) || defined(STM8AF62Ax) || defined(STM8AF626x)
{0x82, (interrupt_handler_t)TIM3_UPD_OVF_BRK_IRQHandler}, /* irq15 - TIM3 Update/Overflow/Break interrupt */
{0x82, (interrupt_handler_t)TIM3_CAP_COM_IRQHandler}, /* irq16 - TIM3 Capture/Compare interrupt */
#else
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq15 - Reserved */
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq16 - Reserved */
#endif /*STM8S208, STM8S207, STM8S105 or STM8AF62Ax or STM8AF52Ax or STM8AF626x*/
#if defined (STM8S105) || defined (STM8S005) || defined(STM8AF626x)
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq17 - Reserved */
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq18 - Reserved */
#else
{0x82, (interrupt_handler_t)UART1_TX_IRQHandler}, /* irq17 - UART1 Tx complete interrupt */
{0x82, (interrupt_handler_t)UART1_RX_IRQHandler}, /* irq18 - UART1 Rx interrupt */
#endif /*STM8S105 or STM8AF626x */
{0x82, (interrupt_handler_t)I2C_IRQHandler}, /* irq19 - I2C interrupt */
#if defined(STM8S208) || defined(STM8S207) || defined(STM8S007) || defined(STM8AF52Ax) || defined(STM8AF62Ax)
{0x82, (interrupt_handler_t)UART3_TX_IRQHandler}, /* irq20 - UART3 Tx interrupt */
{0x82, (interrupt_handler_t)UART3_RX_IRQHandler}, /* irq21 - UART3 Rx interrupt */
#elif defined (STM8S105) || defined (STM8S005) || defined (STM8AF626x)
{0x82, (interrupt_handler_t)UART2_TX_IRQHandler}, /* irq20 - UART2 Tx interrupt */
{0x82, (interrupt_handler_t)UART2_RX_IRQHandler}, /* irq21 - UART2 Rx interrupt */
#else /* STM8S103, STM8S903 */
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq20 - Reserved */
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq21 - Reserved */
#endif /* STM8S208, STM8S207, STM8AF52Ax or STM8AF62Ax */
{0x82, (interrupt_handler_t)ADC2_IRQHandler}, /* irq22 - ADC2 end of conversion interrupt */
#else /* STM8S105, STM8S103, STM8S903 */
{0x82, (interrupt_handler_t)ADC1_IRQHandler}, /* irq22 - ADC1 end of conversion/Analog watchdog interrupts */
#ifdef STM8S903
{0x82, (interrupt_handler_t)TIM6_UPD_OVF_TRG_IRQHandler}, /* irq23 - TIM6 Update/Overflow/Trigger interrupt */
#else
{0x82, (interrupt_handler_t)TIM4_UPD_OVF_IRQHandler}, /* irq23 - TIM4 Update/Overflow interrupt */
#endif /*STM8S903*/
{0x82, (interrupt_handler_t)EEPROM_EEC_IRQHandler}, /* irq24 - FLASH interrupt */
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq25 - Reserved */
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq26 - Reserved */
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq27 - Reserved */
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq28 - Reserved */
{0x82, (interrupt_handler_t)NonHandledInterrupt}, /* irq29 - Reserved */
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
