//不说那么多了,直接上程序
void ADC1_DeInit(void)
ADC1->CSR = ADC1_CSR_RESET_VALUE;
ADC1->CR1 = ADC1_CR1_RESET_VALUE;
ADC1->CR2 = ADC1_CR2_RESET_VALUE;
ADC1->CR3 = ADC1_CR3_RESET_VALUE;
ADC1->TDRH = ADC1_TDRH_RESET_VALUE;
ADC1->TDRL = ADC1_TDRL_RESET_VALUE;
ADC1->HTRH = ADC1_HTRH_RESET_VALUE;
ADC1->HTRL = ADC1_HTRL_RESET_VALUE;
ADC1->LTRH = ADC1_LTRH_RESET_VALUE;
ADC1->LTRL = ADC1_LTRL_RESET_VALUE;
ADC1->AWCRH = ADC1_AWCRH_RESET_VALUE;
ADC1->AWCRL = ADC1_AWCRL_RESET_VALUE;
void ADC1_Init(ADC1_ConvMode_TypeDef ADC1_ConversionMode,
ADC1_Channel_TypeDef ADC1_Channel,
ADC1_PresSel_TypeDef ADC1_PrescalerSelection,
ADC1_ExtTrig_TypeDef ADC1_ExtTrigger,
FunctionalState ADC1_ExtTriggerState,
ADC1_Align_TypeDef ADC1_Align,
ADC1_SchmittTrigg_TypeDef ADC1_SchmittTriggerChannel,
FunctionalState ADC1_SchmittTriggerState)
/* Check the parameters */
assert_param(IS_ADC1_CONVERSIONMODE_OK(ADC1_ConversionMode));//单次还
是连续转换
assert_param(IS_ADC1_CHANNEL_OK(ADC1_Channel));
assert_param(IS_ADC1_PRESSEL_OK(ADC1_PrescalerSelection));
assert_param(IS_ADC1_EXTTRIG_OK(ADC1_ExtTrigger));
assert_param(IS_FUNCTIONALSTATE_OK(((ADC1_ExtTriggerState))));
assert_param(IS_ADC1_ALIGN_OK(ADC1_Align));
assert_param(IS_ADC1_SCHMITTTRIG_OK(ADC1_SchmittTriggerChannel));
assert_param(IS_FUNCTIONALSTATE_OK(ADC1_SchmittTriggerState));
/*-----------------CR1 & CSR configuration --------------------*/
/* Configure the conversion mode and the channel to convert
respectively according to ADC1_ConversionMode & ADC1_Channel values
& ADC1_Align values */
ADC1_ConversionConfig(ADC1_ConversionMode, ADC1_Channel, ADC1_Align);
/* Select the prescaler division factor according to
ADC1_PrescalerSelection values */
ADC1_PrescalerConfig(ADC1_PrescalerSelection);
/*-----------------CR2 configuration --------------------*/
/* Configure the external trigger state and event respectively
according to NewState, ADC1_ExtTrigger */
ADC1_ExternalTriggerConfig(ADC1_ExtTrigger, ADC1_ExtTriggerState);
/*------------------TDR configuration ---------------------------*/
/* Configure the schmitt trigger channel and state respectively
according to ADC1_SchmittTriggerChannel & ADC1_SchmittTriggerNewState
values */
ADC1_SchmittTriggerConfig(ADC1_SchmittTriggerChannel,
ADC1_SchmittTriggerState);
/* Enable the ADC1 peripheral */
ADC1->CR1 |= ADC1_CR1_ADON;
void ADC1_Cmd(FunctionalState NewState)
assert_param(IS_FUNCTIONALSTATE_OK(NewState));
if (NewState != DISABLE)
else /* NewState == DISABLE */
ADC1->CR1 &= (u8)(~ADC1_CR1_ADON);
void ADC1_StartConversion(void)
FlagStatus ADC1_GetFlagStatus(ADC1_Flag_TypeDef Flag)
u8 flagstatus = 0;
u8 temp = 0;
assert_param(IS_ADC1_FLAG_OK(Flag));
if ((Flag & 0x0F) == 0x01)
/* Get OVR flag status */
flagstatus = (u8)(ADC1->CR3 & ADC1_CR3_OVR);
else if ((Flag & 0xF0) == 0x10)
/* Get analog watchdog channel status */
temp = (u8)(Flag & 0x0F);
if (temp < 8)
flagstatus = (u8)(ADC1->AWSRL & (1 << temp));
else
flagstatus = (u8)(ADC1->AWSRH & (1 << (temp - 8)));
else /* Get EOC | AWD flag status */
flagstatus = (u8)(ADC1->CSR & Flag);
return ((FlagStatus)flagstatus);
u16 ADC1_GetConversionValue(void)
u16 temph = 0;
u8 templ = 0;
if (ADC1->CR2 & ADC1_CR2_ALIGN) /* Right alignment */
/* Read LSB first */
templ = ADC1->DRL;
/* Then read MSB */
temph = ADC1->DRH;
temph = (u16)(templ | (u16)(temph << (u8)8));
else /* Left alignment */
/* Read MSB firts*/
temph = ADC1->DRH;
/* Then read LSB */
templ = ADC1->DRL;
temph = (u16)((u16)(templ << (u8)6) | (u16)(temph << (u8)8));
return ((u16)temph);
//以下程序是用AN3即PB3进行AD转换,并将AD值放在 u16 ADVal
//初始化时调用:
GPIO_DeInit(GPIOB);
GPIO_Init(GPIOB, GPIO_PIN_3, GPIO_MODE_IN_FL_NO_IT);//设置IO为悬浮输入
ADC1_DeInit();
ADC1_Init(ADC1_CONVERSIONMODE_SINGLE,ADC1_CHANNEL_3,
ADC1_PRESSEL_FCPU_D6,ADC1_EXTTRIG_TIM,DISABLE,
ADC1_ALIGN_RIGHT,ADC1_SCHMITTTRIG_CHANNEL3,DISABLE);
/*单次转换*/ /*PB3/AN3*/ /*6分频*/ /*内部定时器1 TRG事件*/
/*禁止外部触发转换*/ /*数据右对齐 (低8字节在ADC_DRL寄存器,其余高字节
位在ADC_DRH寄存器)读顺序
应先读低位,再读高位字节*/
ADC1_Cmd(ENABLE);//允许进行AD转换
//进行AD取值时调用:
ADC1_StartConversion();//开始AD转换
while(0==ADC1_GetFlagStatus(ADC1_FLAG_EOC));//等待转换完成
ADC1_ClearFlag(ADC1_FLAG_EOC); //清除AD完成标志位
ADVal = ADC1_GetConversionValue();//读AD值
