** 四个按键数值调整,一个移位,两个加减,一个确定
** 针对0~65536数值区间,任意数值
** light
** 2012-3-28
//数值调整结构
typedef struct _num_cal
unsigned int num_temp; //变量值
unsigned int bit; //位
unsigned int bit_max; //位数
unsigned int tmp_bit[5]; //存放各个位值
}num_cal;
num_cal num_cal_tmp; //数值调整结构全局变量
** number_calc
** temp_value : 要调整的值
** bit_max :数据位数
** 2012-3-28
void number_calc(unsigned int temp_value,unsigned int bit_max)
num_cal_tmp.num_temp = temp_value;
num_cal_tmp.tmp_bit[0] = num_cal_tmp.num_temp%10;
num_cal_tmp.tmp_bit[1] = (num_cal_tmp.num_temp%100)/10;
num_cal_tmp.tmp_bit[2] = (num_cal_tmp.num_temp%1000)/100;
num_cal_tmp.tmp_bit[3] = (num_cal_tmp.num_temp%10000)/1000;
num_cal_tmp.tmp_bit[4] = num_cal_tmp.num_temp/10000;
num_cal_tmp.bit_max = bit_max - 1;
switch (key_value):
case key_back: //移动光标,由低位向高位移动
num_cal_tmp.bit++;
if( num_cal_tmp.bit > num_cal_tmp.bit_max )
num_cal_tmp.bit = 0;
break;
case key_up: //加
num_cal_tmp.tmp_bit[num_cal_tmp.bit]++;
if( num_cal_tmp.tmp_bit[num_cal_tmp.bit] > 9)
num_cal_tmp.tmp_bit[num_cal_tmp.bit] = 0;
break;
case key_down: //减
if( num_cal_tmp.tmp_bit[num_cal_tmp.bit] == 0)
num_cal_tmp.tmp_bit[num_cal_tmp.bit] = 9;
else
num_cal_tmp.tmp_bit[num_cal_tmp.bit]--;
break;
case key_enter: //确定键
temp_value = num_cal_tmp.tmp_bit[4]*10000+num_cal_tmp.tmp_bit[3]*1000+num_cal_tmp.tmp_bit[2]*100+num_cal_tmp.tmp_bit[1]*10+num_cal_tmp.tmp_bit[0];
break;
