最近一直在学STM8 代码里面一直出现u8 * / u16等等
类似
#include"stm8s.h"
/*芯片唯一的ID地址 96位*/
define UNIQUE_ID_START_ADDR 0x48CD
u8 i;
s16 temp;
s8 t;
u8 * pUniqueId;
int main( void )
return 0;
一直不理解什么是u8 今天再网上好好的找找发现u8 是unsigned int 8的意思。如果是标准的C语言表达方式应该是
unsigned int 8
但是STM就变成了u8 一开始很郁闷不知道是什么意思。但是现在这样一想
volatile signed 32也就变成了
vs32
说到底,ST搞这么多花样嘛,也就是开发人员强行偷了个懒,结果搞得我们初学者头晕。不过怎么样变化都是基于标准C的。
可以参考
//stdint.h 这里是C语言的标准表达方式
//第36行开始
typedef signed char int8_t; // 标准表达方式 signed char 等同于 int8_t;
typedef signed short int int16_t;
typedef signed int int32_t;// 如果是在32位环境里,int代表4个字节32位
typedef signed __int64 int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned __int64 uint64_t;
typedef signed char int_least8_t;
typedef signed short int int_least16_t;
typedef signed int int_least32_t;
typedef signed __int64 int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned __int64 uint_least64_t;
typedef signed int int_fast8_t;
typedef signed int int_fast16_t;
typedef signed int int_fast32_t;
typedef signed __int64 int_fast64_t;
typedef unsigned int uint_fast8_t;
typedef unsigned int uint_fast16_t;
typedef unsigned int uint_fast32_t;
typedef unsigned __int64 uint_fast64_t;
typedef signed int intptr_t;
typedef unsigned int uintptr_t;
typedef signed __int64 intmax_t;
typedef unsigned __int64 uintmax_t;
关于STM32 为了兼容旧版本的
typedef int32_t s32;
typedef int16_t s16;
typedef int8_t s8;
typedef const int32_t sc32;
typedef const int16_t sc16;
typedef const int8_t sc8;
typedef __IO int32_t vs32;
typedef __IO int16_t vs16;
typedef __IO int8_t vs8;
typedef __I int32_t vsc32;
typedef __I int16_t vsc16;
typedef __I int8_t vsc8;
typedef uint32_t u32;
typedef uint16_t u16;
typedef uint8_t u8;
typedef const uint32_t uc32;
typedef const uint16_t uc16;
typedef const uint8_t uc8;
typedef __IO uint32_t vu32;
typedef __IO uint16_t vu16;
typedef __IO uint8_t vu8;
typedef __I uint32_t vuc32;
typedef __I uint16_t vuc16;
typedef __I uint8_t vuc8;
可以作为参考理解。
以上
**修改下,更加容易理解的地方应该是在这里
/*!< Signed integer types */
typedef signed short int16_t;
typedef signed long int32_t;
/*!< Unsigned integer types */
typedef unsigned short uint16_t;
typedef unsigned long uint32_t;
这里就能看出,int8_t 应该是 singed char 也就是说声明新的类型名来代替原有的类型名,这样的好处就是定义一种新的数据类型,这种类型又可以用来声明属于该类型的变量,大多数情况typedef用来定义一种结构体,因为原有数据类型不够用了。
有个例子
自定义数据类型
经常用来将结构定义成一个数据类型~如:
typedef struct student{
char name[10];
char kemu[10];
double mark;
}student;
这样就可以直接定义数据
student stu;
stu.name = '张三';
stu.kemu = '语文';
stu.mark = 97.5;
用起来也比较方便。
以上
